Closes #2956.
The rtrace command interfaces to the RTEMS Trace Linker's trace
buffering data allowing users to capture and report trace data.
* Makefile.am updated and preinstall.am regenerated.
* mprotect.c had a prototype removed now that we have mman.h
* mmap.c, munmap.c: New stub files.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), crypt_sha256_r() and
crypt_sha512_r().
This is a merge of the RTL project.
This module makes it easy to redirect and capture stdout, stderr or any
other fd in your application.
The captured data can be sent off board, for example using syslog,
or buffered and displayed in a web page.
not updated.
This handler is necessary to implement the KQUEUE(2) system calls.
Add <sys/event.h> from FreeBSD 8.4.
This handler is necessary to implement the SELECT(2) and POLL(2) system
calls.
Add <sys/poll.h> from FreeBSD 8.4.
utf8proc is a small library for processing UTF-8 encoded Unicode strings.
Some features are Unicode normalization, stripping of default ignorable characters, case folding and detection of grapheme cluster boundaries.
For the time beeing utf8proc is intended to be used for normalizing and folding UTF-8 strings
for comparison purposes when adding UTF-8 support to the FAT file system.
These two header files were installed from libnetworking even
when networking was disabled. This patch moves them to a
non-networking location and updates uio.h to match the FreeBSD 8.x
source being used for the USB stack and TCP/IP stack upgrade.
- cpukit/include/memory.h
Move from cpukit/libnetworking/memory.h. No changes
- cpukit/include/sys/uio.h
Move from cpukit/libnetworking/sys/uio.h. Replace with FreeBSD 8.x version.
- cpukit/include/sys/_iovec.h
New. FreeBSD 8.x file supporting <sys/uio.h>.
- cpukit/Makefile.am
Reflect movement of <memory.h> and <sys/uio.h>.
- cpukit/preinstall.am
Regenerate
- cpukit/libnetworking/nfs/bootp_subr.c
Eliminate use of uio_procp field no longer in FreeBSD structure. This
field was set and never read so eliminating the set has no impact.
* libmisc/devnull/devzero.c, libmisc/devnull/devzero.h: New files.
* libmisc/Makefile.am, Makefile.am, preinstall.am: Reflect changes
above.
PR 1762/cpukit
* Makefile.am, preinstall.am, libmisc/Makefile.am, wrapup/Makefile.am:
Add generic serial mouse driver and mouse parser. The parser code was
in the pc386 BSP but was generic so cleaned up and placed here.
Serial mouse driver itself is new.
* libmisc/mouse/README, libmisc/mouse/mouse_parser.c,
libmisc/mouse/mouse_parser.h, libmisc/mouse/serial_mouse.c,
libmisc/mouse/serial_mouse.h: New files.
* libblock/include/rtems/media.h, libblock/src/media-desc.c,
libblock/src/media-dev-ident.c, libblock/src/media-path.c,
libblock/src/media-server.c, libblock/src/media.c: New files.
* Makefile.am, preinstall.am, libblock/Makefile.am: Reflect changes
above.
PR 1555/cpukit
* Makefile.am, preinstall.am: Install md4.h and md5.h headers.
* libfs/src/rfs/rtems-rfs-bitmaps.c,
libfs/src/rfs/rtems-rfs-bitmaps.h,
libfs/src/rfs/rtems-rfs-bitmaps-ut.c,
libfs/src/rfs/rtems-rfs-block.c, libfs/src/rfs/rtems-rfs-block.h,
libfs/src/rfs/rtems-rfs-block-pos.h,
libfs/src/rfs/rtems-rfs-buffer-bdbuf.c,
libfs/src/rfs/rtems-rfs-buffer.c,
libfs/src/rfs/rtems-rfs-buffer-devio.c,
libfs/src/rfs/rtems-rfs-buffer.h, libfs/src/rfs/rtems-rfs-data.h,
libfs/src/rfs/rtems-rfs-dir.c, libfs/src/rfs/rtems-rfs-dir.h,
libfs/src/rfs/rtems-rfs-dir-hash.c,
libfs/src/rfs/rtems-rfs-dir-hash.h,
libfs/src/rfs/rtems-rfs-file.c, libfs/src/rfs/rtems-rfs-file.h,
libfs/src/rfs/rtems-rfs-file-system.c,
libfs/src/rfs/rtems-rfs-file-system-fwd.h,
libfs/src/rfs/rtems-rfs-file-system.h,
libfs/src/rfs/rtems-rfs-format.c,
libfs/src/rfs/rtems-rfs-format.h, libfs/src/rfs/rtems-rfs-group.c,
libfs/src/rfs/rtems-rfs-group.h, libfs/src/rfs/rtems-rfs.h,
libfs/src/rfs/rtems-rfs-inode.c, libfs/src/rfs/rtems-rfs-inode.h,
libfs/src/rfs/rtems-rfs-link.c, libfs/src/rfs/rtems-rfs-link.h,
libfs/src/rfs/rtems-rfs-mutex.c, libfs/src/rfs/rtems-rfs-mutex.h,
libfs/src/rfs/rtems-rfs-rtems.c,
libfs/src/rfs/rtems-rfs-rtems-dev.c,
libfs/src/rfs/rtems-rfs-rtems-dir.c,
libfs/src/rfs/rtems-rfs-rtems-file.c,
libfs/src/rfs/rtems-rfs-rtems.h,
libfs/src/rfs/rtems-rfs-rtems-utils.c,
libfs/src/rfs/rtems-rfs-shell.c, libfs/src/rfs/rtems-rfs-shell.h,
libfs/src/rfs/rtems-rfs-trace.c, libfs/src/rfs/rtems-rfs-trace.h:
New.
* Makefile.am, preinstall.am, libfs/Makefile.am,
wrapup/Makefile.am: Updated with the RFS support.
* libfs/README: Updated after 10 years.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk-driver.c: Updated to the new error reporting
in libblock.
* libmisc/shell/main_ls.c, libmisc/shell/print-ls.c: Fix printing
the size in long mode.
* libnetworking/nfs/bootp_subr.c,
libnetworking/rtems/rtems_bootp.c,
libnetworking/rtems/rtems_bsdnet_internal.h: Return the BOOTP/DHCP
to the forever behaviour of 4.9 with the ability to call BOOTP and
control the process if required.
* Makefile.am, preinstall.am: Added statvfs.h.
* libcsupport/Makefile.am: Add statvfs.c.
* libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c:
New.
* libcsupport/include/rtems/libio.h: Add a file system handler for
the statvfs call.
* libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c,
libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the
statvfs handler to NULL.
* include/rtems/fs.h: Add a second node access field for the RFS
file system to hold a directory offset while the existing field
holds the inode number. This save a rescan of the directory when
working with directories.
* libblock/include/rtems/bdbuf.h: Added references and user fields
to the buffer descriptor.
* libblock/src/bdbuf.c: Added dynamic buffer support for different
block sizes. Fixed a number of bugs.
* libblock/src/blkdev.c: Release the disk device on an error.
* libblock/src/diskdevs.c: Set the block size to the media block
size during initialisation of the disk device.
libblock/src/ramdisk.c: Updated the drivers to handle variable
block sizes.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any
buffers when an error occurs. The FAT buffer layer hangs onto a
single buffer while mounted. This should be fixed.
* sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain,
rtems_chain_is_node_off_chain, and rtems_chain_previous.
* score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain,
and _Chain_Is_node_off_chain.
* libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c,
libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h:
New shell commands.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and
mknod commands.
* libmisc/shell/hexdump-display.c: Fixed the reopen bug which
showed up as a free with a bad pointer.
* libmisc/shell/main_mount.c: List the user adding file system
when listing the available file systems to mount.
* libmisc/shell/utils-cp.c: Remove the fixed static copy buffer
and use a large dynamic buffer.
* score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c,
score/src/objectallocate.c, score/src/objectfree.c: Remove
warnings.
* Makefile.am, preinstall.am, libmisc/Makefile.am: Changed the name of
mw-fb directory into fb. Relocated files.
* libmisc/fb/fb.h, libmisc/fb/mw_uid.c, libmisc/fb/mw_uid.h: New files.
* libmisc/mw-fb/fb.h, libmisc/mw-fb/mw_uid.c, libmisc/mw-fb/mw_uid.h:
Removed.
Add new BSP Boot Command Line helper routines. Recently boot_card()
has grown the ability to have a command line string pointer. These
routines provide an interface to that string.
* Makefile.am, preinstall.am, libmisc/Makefile.am: changed the
references to mw_fb.h into fb.h
* libmisc/mw-fb/mw_fb.h: renamed fb.h
Add the stringto family of string to number converters. These are
error checking wrappers for the strtoXXX methods and do their best to
return false if the conversion failed. The error checking required
for this is tedious and error prone. Hence better to have in a family
of helper routines.
* libmisc/stringto/stringto.h, libmisc/stringto/stringto_template.h,
libmisc/stringto/stringtodouble.c, libmisc/stringto/stringtofloat.c,
libmisc/stringto/stringtoint.c, libmisc/stringto/stringtolong.c,
libmisc/stringto/stringtolonglong.c,
libmisc/stringto/stringtounsignedchar.c,
libmisc/stringto/stringtounsignedint.c,
libmisc/stringto/stringtounsignedlong.c,
libmisc/stringto/stringtounsignedlonglong.c: New files.
libmisc/shell/shell.c, libmisc/shell/shell.h, telnetd/check_passwd.c,
telnetd/telnetd.c, telnetd/telnetd.h:
Generalized login check.
* libmisc/shell/login.h, libmisc/shell/login_check.c,
libmisc/shell/login_prompt.c: New files.
* libmisc/stackchk/check.c: Changed format for blown stack message.
* libcsupport/src/libio_sockets.c: Removed superfluous cast.
* libnetworking/rtems/ftpfs.h: Documentation.
* Makefile.am, preinstall.am, libcsupport/src/mknod.c,
libcsupport/src/open.c, libcsupport/src/pipe.c, libfs/Makefile.am,
libfs/preinstall.am, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_creat.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_initsupp.c,
libfs/src/imfs/imfs_mknod.c, libfs/src/imfs/imfs_stat.c,
libfs/src/imfs/memfile.c: Initial commit of POSIX pipe support.
* libfs/src/imfs/imfs_fifo.c, libfs/src/pipe/fifo.c,
libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: New files.
* Makefile.am, preinstall.am, libcsupport/Makefile.am,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio.h, libcsupport/src/base_fs.c,
libcsupport/src/libio_init.c, libcsupport/src/newlibc_exit.c,
libcsupport/src/newlibc_init.c, libcsupport/src/sync.c,
libfs/Makefile.am, libfs/src/imfs/deviceio.c,
sapi/include/confdefs.h: Merge GSOC project code to add simple device
only filesystem (devfs), optionally completely drop out filesystem,
and to clean up disabling newlib reentrancy support. This dropped 17K
from the minimum.exe for sparc/sis and arm/rtl22xx_t now has a 15K
code space.
* libcsupport/src/__usrenv.c, libcsupport/src/newlibc_reent.c,
libfs/src/devfs/devclose.c, libfs/src/devfs/devfs.h,
libfs/src/devfs/devfs_eval.c, libfs/src/devfs/devfs_init.c,
libfs/src/devfs/devfs_mknod.c, libfs/src/devfs/devfs_node_type.c,
libfs/src/devfs/devfs_show.c, libfs/src/devfs/devioctl.c,
libfs/src/devfs/devopen.c, libfs/src/devfs/devread.c,
libfs/src/devfs/devstat.c, libfs/src/devfs/devwrite.c,
libfs/src/imfs/deviceerrno.c: New files.
* libcsupport/src/newlibc.c: Removed.
* libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h,
libblock/src/nvdisk-sram.c,
libblock/src/nvdisk.c: New. A Non-volatile memory disk drive.
* Makefile.am, preinstall.am, libblock/Makefile.am: Updated for
the NV disk driver.
libblock/include/rtems/flashdisk.h to the installed header list.
* libblock/Makefile.am: Add flashdisk.c to the files to build.
* libblock/include/rtems/flashdisk.h, libblock/src/flashdisk.c:
New.
* ChangeLog, preinstall.am, libmisc/Makefile.am, libmisc/shell/cmds.c,
libmisc/shell/shell.c, libmisc/shell/shell.h: Split shell commands
into multiple files and add initial stages of command configuration.
This seems to work but the monitor commands need to be integrated
this way and the ability to configure user commands needs to be
tested.
* libmisc/shell/cat_file.c, libmisc/shell/cmd_alias.c,
libmisc/shell/cmd_cat.c, libmisc/shell/cmd_cd.c,
libmisc/shell/cmd_chdir.c, libmisc/shell/cmd_chmod.c,
libmisc/shell/cmd_chroot.c, libmisc/shell/cmd_date.c,
libmisc/shell/cmd_dir.c, libmisc/shell/cmd_exit.c,
libmisc/shell/cmd_help.c, libmisc/shell/cmd_id.c,
libmisc/shell/cmd_logoff.c, libmisc/shell/cmd_ls.c,
libmisc/shell/cmd_mallocdump.c, libmisc/shell/cmd_mdump.c,
libmisc/shell/cmd_medit.c, libmisc/shell/cmd_mfill.c,
libmisc/shell/cmd_mkdir.c, libmisc/shell/cmd_mmove.c,
libmisc/shell/cmd_mwdump.c, libmisc/shell/cmd_pwd.c,
libmisc/shell/cmd_rm.c, libmisc/shell/cmd_rmdir.c,
libmisc/shell/cmd_tty.c, libmisc/shell/cmd_umask.c,
libmisc/shell/cmd_whoami.c, libmisc/shell/internal.h,
libmisc/shell/shellconfig.c, libmisc/shell/shellconfig.h,
libmisc/shell/str2int.c: New files.
