* | pppd: Fix warnings | Sebastian Huber | 2016-04-25 | 2 | -2/+2 |
* | cpukit: pppd: fix compile warning | Peng Fan | 2016-04-13 | 13 | -53/+0 |
| | | | | | | rcsid is defined, but not used. So discard it. Signed-off-by: Peng Fan <van.freenix@gmail.com> | ||||
* | Delete or rename MIN/MAX macros and defines | Sebastian Huber | 2014-11-21 | 1 | -8/+1 |
| | | | | Include <sys/param.h> if necessary to get the MIN()/MAX() macros. | ||||
* | pppd: Import change from NetBSD | Sebastian Huber | 2014-09-30 | 1 | -1/+1 |
| | | | | | This avoids the use of gethostbyname() in case the "noipdefault" option is given. The gethostbyname() uses DNS by default. | ||||
* | pppd: Fix warnings | Sebastian Huber | 2014-09-30 | 1 | -2/+11 |
* | Regenerate all preinstall.am files. | Chris Johns | 2014-08-29 | 1 | -6/+6 |
| | | | | | With this patch the preinstall.am files are in a set order and not dependent on now perl implements a hash. | ||||
* | pppd: Delete example | Sebastian Huber | 2014-04-10 | 8 | -340/+0 |
| | | | | This example is available via testsuites/samples/pppd. | ||||
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | Remove CVS Id Strings (manual edits after script) | Joel Sherrill | 2012-05-11 | 5 | -17/+0 |
| | | | | | | These modifications were required by hand after running the script. In some cases, the file names did not match patterns. In others, the format of the file did not match any common patterns. | ||||
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+4 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-18 | 1 | -2/+1 |
| | | | | * pppd/options.c: Remove unused var "ok". | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 15 | -73/+73 |
* | Remove stray ';' introducing unreachable code. | Ralf Corsepius | 2009-01-05 | 1 | -1/+1 |
* | #include <stdint.h> instead of <rtems/stdint.h>. | Ralf Corsepius | 2008-12-11 | 1 | -1/+1 |
* | Add missing initializers. | Ralf Corsepius | 2008-09-08 | 7 | -142/+147 |
* | Stop using old-style function-definitions. | Ralf Corsepius | 2008-08-26 | 14 | -705/+705 |
* | Use stdbool.h. Remove local bool. | Ralf Corsepius | 2008-08-20 | 1 | -2/+1 |
* | Add prototypes. | Ralf Corsepius | 2008-08-03 | 1 | -22/+22 |
* | 2008-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-05-13 | 1 | -1/+1 |
| | | | | | * pppd/example/system.h: Fix path in example -- NOT COMPILED WITH CPUKIT. | ||||
* | Convert to using C99 fixed-size types instead of BSD fixed-size types. | Ralf Corsepius | 2007-09-16 | 12 | -121/+121 |
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 1 | -8/+1 |
| | | | | * pppd/Makefile.am: Reflect moving out md*. | ||||
* | Remove (moved to libmd) | Ralf Corsepius | 2007-06-12 | 4 | -725/+0 |
* | Remove md5 and md4 from libpppd.a. | Ralf Corsepius | 2007-06-12 | 1 | -1/+8 |
| | | | | Add pppd/libmd.a. | ||||
* | Don't include pppd.h. | Ralf Corsepius | 2007-06-12 | 1 | -1/+0 |
* | Include <rtems/stdint.h> instead of <stdint.h>. | Ralf Corsepius | 2007-05-09 | 3 | -2/+3 |
* | 2007-05-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-05-09 | 1 | -1/+1 |
| | | | | | PR 1243 * pppd/auth.c (set_allowed_addrs): Remove bogus dereference. | ||||
* | 2007-04-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-16 | 1 | -2/+2 |
| | | | | * pppd/utils.c: Use uintptr_t instead of unsigned long. | ||||
* | Include <net/ppp_comp.h> instead of <net/ppp-comp.h>. | Ralf Corsepius | 2007-03-27 | 2 | -2/+2 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-27 | 15 | -240/+229 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-27 | 9 | -178/+170 |
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2006-11-18 | 1 | -1/+1 |
* | Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING). | Ralf Corsepius | 2006-11-18 | 1 | -1/+1 |
* | Fix the bug in name change. The UNTIMEOUT macro did not use the ppp version. | Chris Johns | 2006-09-06 | 1 | -1/+1 |
* | * pppd/rtems.main.c, pppd/pppd.h: renamed 'untimeout' | Till Straumann | 2006-09-01 | 2 | -2/+2 |
| | | | | | to 'pppuntimeout' to avoid name clash with [future] bsdnet kernel routine. | ||||
* | *** empty log message *** | Joel Sherrill | 2006-09-01 | 3 | -19/+23 |
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-31 | 2 | -22/+22 |
| | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/include/sys/ioccom.h, libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c, libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h, libnetworking/net/if.c, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c, libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings due to improper use of int which shows up on 16 bit targets. Added ioctl_command_t since IOCTL command argument does not reliably fit into 16 bits. | ||||
* | * pppd/sys-rtems.c: fixed error message so that the correct | Till Straumann | 2006-07-13 | 1 | -1/+1 |
| | | | | ioctl is reported. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -3/+3 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-10 | 1 | -5/+5 |
* | 2005-11-07 Michael Siers <mikes@poliac.com> | Joel Sherrill | 2005-11-07 | 2 | -0/+22 |
| | | | | | * pppd/rtemspppd.c, pppd/rtemspppd.h: Per confirmation from Michael add missing copyright notice. | ||||
* | 2005-11-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-01 | 1 | -1/+1 |
| | | | | * pppd/Makefile.am: Fix typo. | ||||
* | New. | Ralf Corsepius | 2005-10-27 | 1 | -0/+2 |
