path: root/cpukit/pppd (follow)
* 2005-05-20 Sergei Organov <osv@topconrd.ru>Joel Sherrill2005-05-201-4/+12
| | | | | | PR 750/networking * libnetworking/pppd/sys-rtems.c: Avoid NULL dereference in wait_input().
* 2005-05-08 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-05-081-1/+1
| | | | * libnetworking/pppd/Makefile.am: CPPFLAGS += -D__BSD_VISIBLE.
* 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-02-031-4/+3
| | | | | | | PR 755/rtems * libnetworking/pppd/ipcp.c: Include <rtems/bsdnet/servers.h>. Remove local declarations of rtems_bsdnet_nameservers, rtems_bsdnet_nameservers_count.
* 2005-01-31 Sergei Organov <osv@topconrd.ru>Joel Sherrill2005-01-312-16/+16
| | | | | | | | | | | PR 771/pppd * libnetworking/pppd/chat.c, libnetworking/pppd/rtemsmain.c: The fix committed to fix PR736 breaks pppd. chat.c should have its own static ttyfd for pppd to work correctly. The symptom is that second invokation of chat (for connect script) fails due to pppd_ttyfd set to -1 by previous chat invokation (for init script). In addition, this patch fixes leaving of dangling pointer in the abort_stbring[] by chat_send().
* 2005-01-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2005-01-206-31/+32
| | | | | | | | PR 736/pppd * libnetworking/pppd/chat.c, libnetworking/pppd/demand.c, libnetworking/pppd/pppd.h, libnetworking/pppd/rtemsmain.c, libnetworking/pppd/sys-rtems.c, libnetworking/pppd/utils.c: ttyfd should not be static and should have a name more specific to pppd.
* 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-071-1/+1
| | | | | | | | * libchip/Makefile.am, libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-021-17/+8
| | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am: Remove build-variant support.
* 2004-10-19 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-10-191-1/+1
| | | | | * libnetworking/pppd/rtemspppd.c: rtems_task_priority priority. * libnetworking/rtems_telnetd/telnetd.c: Eliminate rtems_unsigned32.
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-291-1/+1
| | | | | | * aclocal/rtems-cpu-subdirs.m4, libchip/shmdr/shm_driver.h, libnetworking/pppd/utils.c: i960 obsoleted and all references removed.
* Remove stray white spaces.Ralf Corsepius2004-04-153-3/+0
* 2004-04-03 Wilfried Busalski <w.busalski@lancier-monitoring.de>Joel Sherrill2004-04-031-101/+144
| | | | | PR 599/pppd * libnetworking/pppd/chat.c: Fre memory that is allocated to fix leak.
* 2004-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-091-1/+0
| | | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, libnetworking/rtems_webserver/Makefile.am, optman/Makefile.am, support/Makefile.am: Don't include lib.am.
* 2004-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-02-031-1/+3
| | | | | | | * libnetworking/rtems_webserver/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_telnetd/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/rtems_servers/Makefile.am: Add PREINSTALL_DIRS. * libnetworking/pppd/Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-151-21/+19
| | | | | | | | | | | | | * Makefile.am: Remove wrapup. * pppd/Makefile.am: Build libpppd. Use automake-compilation rules. * rtems_servers/Makefile.am: Build libftpd. Use automake-compilation rules. * rtems_telnetd/Makefile.am: Build libtelnetd. Use automake-compilation rules. * rtems_webserver/Makefile.am: Build libhttpd. Use automake-compilation rules. * wrapup/Makefile.am: Remove (Unused).
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+3
| | | | | | | | * pppd/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * rtems_servers/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-121-2/+1
| | | | | | | * pppd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * rtems_servers/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * rtems_telnetd/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES. * rtems_webserver/Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* 2003-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-091-1/+1
| | | | | | * Makefile.am: Cosmetics. * pppd/Makefile.am: Cosmetics. * wrapup/Makefile.am: Cosmetics.
* 2003-12-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-021-1/+1
| | | | | | | | * pppd/Makefile.am: Remove all-local: $(ARCH). * rtems_servers/Makefile.am: Remove all-local: $(ARCH). * rtems_telnetd/Makefile.am: Remove all-local: $(ARCH). * rtems_webserver/Makefile.am: Remove all-local: $(ARCH). * wrapup/Makefile.am: Remove all-local: $(ARCH).
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-8/+20
| | | | | | | | | * Makefile.am: Reformat. Apply dirstamps to preinstallation. * pppd/Makefile.am: Ditto. * rtems_servers/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto. * wrapup/Makefile.am: Ditto.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | Makefile.am: Reflect having moved automake. pppd/Makefile.am: Reflect having moved automake. rtems_servers/Makefile.am: Reflect having moved automake. rtems_telnetd/Makefile.am: Reflect having moved automake. rtems_webserver/Makefile.am: Reflect having moved automake. wrapup/Makefile.am: Reflect having moved automake.
* 2003-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-07-251-6/+7
| | | | | | | | * configure.ac: Remove (Merged into ../configure.ac). * .cvsignore, Makefile.am, pppd/Makefile.am, rtems_servers/Makefile.am, rtems_telnetd/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Reflect having merged configure.ac into ../configure.ac
* 2003-06-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-06-131-1/+3
| | | | * pppd/chat.c: Removed warnings.
* 2003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-281-1/+1
| | | | * pppd/fsm.c: Make peer_mru global again.
* 2003-05-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-05-162-30/+1
| | | | | * pppd/magic.c: Remove *rand48. * pppd/chap.c: Remove prototypes of *rand48.
* 2003-04-10 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-109-76/+67
| | | | | | | | | | PR 371/pppd * pppd/auth.c, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/lcp.c, pppd/options.c, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c: Change many symbols to static. There are still global symbols in rtemspppd.h which might need to be changed or converted into member of a structure which is dereferenced with a pointer that is managed as a per task variable. But this patch should avoid many conflicts.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-241-39/+0
* 2003-02-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-061-14/+14
| | | | | * pppd/chat.c: Convert routines with common names to static. This included get_char(), put_char(), and character() among others.
* 2003-01-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-161-8/+1
| | | | | | | | | * wrapup/Makefile.am: Don't include @RTEMS_BSP@.cfg. * pppd/Makefile.am: Don't include @RTEMS_BSP@.cfg. Eliminate *_O_FILES. * rtems_servers/Makefile.am: Ditto. * rtems_webserver/Makefile.am: Ditto. * rtems_telnetd/Makefile.am: Ditto.
* 2002-11-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-041-0/+4
| | | | * pppd/auth.c, rtems_webserver/uemf.h: Removed warnings.
* 2002-09-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-09-071-0/+1
| | | | | * pppd/ipcp.c, rtems_servers/ftpd.c: Add include files to resolve warnings.
* 2002-08-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-141-0/+2
| | | | | | | * rtems_servers/ftpd.c: Remove unused variable buf. * pppd/md5.c: #include <string.h> to make gcc31 happy. * rtems_telnetd/telnetd.c: #include <string.h> to make gcc31 happy. * rtems_webserver/webmain.c: Remove unused variable dir, cp.
* 2002-08-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-121-1/+1
| | | | * pppd/utils.c: Include i960 in varargs conditional to avoid error.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | * pppd/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_servers/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_telnetd/Makefile.am: Use .$(OBJEXT) instead of .o. * rtems_webserver/Makefile.am: Use .$(OBJEXT) instead of .o. * wrapup/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-07-254-5/+5
| | | | | * pppd/chap.c, pppd/fsm.c, pppd/fsm.h, pppd/upap.c: Per PR255 fix prototype mismatches.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-181-2/+2
| | | | * pppd/utils.c: Adapt to gcc-3.x.
| | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * arpa/Makefile.am: Remove AUTOMAKE_OPTIONS. * kern/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * lib/Makefile.am: Remove AUTOMAKE_OPTIONS. * libc/Makefile.am: Remove AUTOMAKE_OPTIONS. * machine/Makefile.am: Remove AUTOMAKE_OPTIONS. * net/Makefile.am: Remove AUTOMAKE_OPTIONS. * netinet/Makefile.am: Remove AUTOMAKE_OPTIONS. * nfs/Makefile.am: Remove AUTOMAKE_OPTIONS. * pppd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_servers/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_telnetd/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems_webserver/Makefile.am: Remove AUTOMAKE_OPTIONS. * sys/Makefile.am: Remove AUTOMAKE_OPTIONS. * vm/Makefile.am: Remove AUTOMAKE_OPTIONS. * wrapup/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-02-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-02-274-6/+31
| | | | | | * net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h, pppd/sys-rtems.c: Add server with pap-authorization capabilities as well as eliminate some warnings.
* 2001-02-01 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-011-1/+8
| | | | | | * pppd/rtemspppd.c (rtems_pppd_disconnect): Modified to avoid bringing the link down too fast. NOTE: Mike reports successfully running at 56K baud on a direct link.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-02-011-0/+24
| | | | * pppd/rtemsdialer.h: New file missed in previous commit.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-3116-121/+171
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * Makefile.am, configure.ac, net/Makefile.am, net/bpf.h, net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h, net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h, net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h, net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h, net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c, net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c, pppd/upap.h, pppd/utils.c, pppd/example/README, pppd/example/netconfig.h, wrapup/Makefile.am: Modified. * net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h, net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file. * modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c, modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-1/+0
| | | | | * pppd/sys-rtems.c: Remove unused variable status from dodefaultroute.
* 2001-10-12 Mike Siers <mikes@poliac.com>Joel Sherrill2001-10-129-308/+683
| | | | | | | | | | | * Update to stable working state. Congratulations Mike! :) * modem_example: Directory removed. * modem_example/16550.h, modem_example/README, modem_example/modem.c, modem_example/modem.h, modem_example/ppp.c, modem_example/ppp.h, modem_example/pppcompress.c: Files removed. * pppd/example/pppd.options: New file. * pppd/README, pppd/STATUS, pppd/cbcp.c, pppd/cbcp.h, pppd/chat.c, pppd/pppd.h, pppd/rtemsmain.c: Updated.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-271-1/+1
| | | | | | | | | | | | | | | * machine/Makefile.am: Use 'PREINSTALL_FILES ='. * net/Makefile.am: Use 'PREINSTALL_FILES ='. * netinet/Makefile.am: Use 'PREINSTALL_FILES ='. * vm/Makefile.am: Use 'PREINSTALL_FILES ='. * pppd/Makefile.am: Use 'PREINSTALL_FILES ='. * sys/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_servers/Makefile.am: Use 'PREINSTALL_FILES ='. * arpa/Makefile.am: Use 'PREINSTALL_FILES ='. * nfs/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_webserver/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * rtems_telnetd/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-173-2/+36
| | | | | | * pppd/STATUS: Updated by Joel based upon email from Mike. * pppd/cbcp.c, pppd/cbcp.h: Readded files. These support callback functionality that has not even been compiled under RTEMS yet.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-162-1/+48
| | | | | | * pppd/example/Makefile: Removed. * pppd/example/Makefile-user: Added was Makefile. Renamed to avoid bootstrap -c clobbering it.
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-1640-1892/+8412
| | | | | | | | | | | | | | | | | | | | | | | | | | * Update of PPPD to 2.3.11 from 2.3.5 and addition of an example application. Mike's notes on the modifications: - renamed error() function because of namespace problems - removed calls to the exit() funciton - removed extra files from the pppd source directory - defined pppd task constant values in rtemspppd.h - modifyied example code to get actual tick per second value - placed the pppd 2.3.11 man page file (pppd.8) into the pppd directory * pppd/cbcp.c, pppd/cbcp.h, pppd/main.c, pppd/ppp_tty.c, pppd/pppmain.c, pppd/rtems-ppp.c, pppd/rtems-ppp.c: Deleted. * pppd/pppd.8, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/utils.c, pppd/example/Makefile, pppd/example/README, pppd/example/init.c, pppd/example/netconfig.h, pppd/example/ppp.conf, pppd/example/pppdapp.c, pppd/example/system.h: New files. * modem/ppp_tty.c, net/if_ppp.h, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.h, pppd/upap.c, pppd/upap.h: Modified.
* 2001-04-20 Radzislaw Galler <rgaller@et.put.poznan.pl>Joel Sherrill2001-04-201-1/+3
| | | | | | | * modem/ppp.c, pppd/main.c, pppd/pppmain.c, pppd/rtems-ppp.c, pppd/modem_example/modem.c, pppd/modem_example/ppp.c: Translated Polish comments and other strings into English * pppd/STATUS: Updated to reflect the changes
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-255-9/+14
| | | | | | | | | | | | * wrapup/Makefile.am: Added modem subdir. * configure.in, Makefile.am: Added modem subdir. * net/Makefile.am: Added if_pppvar.h, pppcompress.h. * pppd/Makefile.am: Added pppmain.c (which needs work). * pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c, pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler <Thomas.Doerfler@imd-systems.de> and cosmetic changes by me. Actually main.c and ppp_tty.c should be scratched. The modem subdir has the real ppp_tty.c and the real pppd main is in pppmain.c.
* 2000-10-18 Chris Johns <ccj@acm.org>Joel Sherrill2000-10-181-1/+1
| | | | * pppd/ipxcp.c: Fixed a typo.
* 2000-09-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-221-0/+1
| | | | | | | | | | * machine/types.h, pppd/pppd.h, rtems/rtems_bsdnet_internal.h, rtems_webserver/webmain.c: machine/types.h should not have included rtems.h. It is now including precisely the least amount of low level, yet portable .h files to get the basic RTEMS types defined. This rippled into other files since rtems_bsdnet_internal.h used machine/types.h to include rtems.h.
