path: root/cpukit/pppd (follow)
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | * kern/Makefile.am, lib/Makefile.am, libc/Makefile.am, net/Makefile.am, netinet/Makefile.am, nfs/Makefile.am, pppd/Makefile.am, rtems/Makefile.am, rtems_servers/Makefile.am, rtems_webserver/Makefile.am, wrapup/Makefile.am: Include compile.am
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-263-3/+3
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-123-6/+6
* Patches rtems-rc-20000118-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-031-0/+44
| | | | | | | | | | | | | | | | | that contains the automake files for libnetworking plus a couple of minor fixes. [Now only one unused/unsupported Makefile.in remains (./c/src/lib/libbsp/hppa1.1/pxfl/Makefile.in).] To apply: patch -p1 < rtems-rc-20000118-7.diff /bin/sh rtems-rc-20000118-7.rm /bin/sh rtems-rc-20000118-7.add ./bootstrap Notes: * I have tested this one by building all BSPs for m68k, powerpc, sh and unix with toolchains built since last weekend. * I did not touch libnetworking's directory layout.
* Comments added and some messages translated from Polish.Joel Sherrill2000-01-031-1/+46
* Made prototype of ChapReceiveSuccess and ChapReceiveFailure match.Joel Sherrill1999-12-211-2/+2
* Added port of ppp-2.3.5 from Tomasz Domin <dot@comarch.pl> of ComArch SA.Joel Sherrill1999-11-3033-0/+13622
Tomasz only tested this on the mpc823. The official site for the original source for this PPP implementation is: ftp://cs.anu.edu.au/pub/software/ppp NOTE: As of 11/30/1999, the current version of this source is 2.3.10.
