* | Stop using old-style function-definitions. | Ralf Corsepius | 2008-08-26 | 14 | -705/+705 |
* | Use stdbool.h. Remove local bool. | Ralf Corsepius | 2008-08-20 | 1 | -2/+1 |
* | Add prototypes. | Ralf Corsepius | 2008-08-03 | 1 | -22/+22 |
* | 2008-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-05-13 | 1 | -1/+1 |
| | | | | | * pppd/example/system.h: Fix path in example -- NOT COMPILED WITH CPUKIT. | ||||
* | Convert to using C99 fixed-size types instead of BSD fixed-size types. | Ralf Corsepius | 2007-09-16 | 12 | -121/+121 |
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 1 | -8/+1 |
| | | | | * pppd/Makefile.am: Reflect moving out md*. | ||||
* | Remove (moved to libmd) | Ralf Corsepius | 2007-06-12 | 4 | -725/+0 |
* | Remove md5 and md4 from libpppd.a. | Ralf Corsepius | 2007-06-12 | 1 | -1/+8 |
| | | | | Add pppd/libmd.a. | ||||
* | Don't include pppd.h. | Ralf Corsepius | 2007-06-12 | 1 | -1/+0 |
* | Include <rtems/stdint.h> instead of <stdint.h>. | Ralf Corsepius | 2007-05-09 | 3 | -2/+3 |
* | 2007-05-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-05-09 | 1 | -1/+1 |
| | | | | | PR 1243 * pppd/auth.c (set_allowed_addrs): Remove bogus dereference. | ||||
* | 2007-04-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-16 | 1 | -2/+2 |
| | | | | * pppd/utils.c: Use uintptr_t instead of unsigned long. | ||||
* | Include <net/ppp_comp.h> instead of <net/ppp-comp.h>. | Ralf Corsepius | 2007-03-27 | 2 | -2/+2 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-27 | 15 | -240/+229 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-27 | 9 | -178/+170 |
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2006-11-18 | 1 | -1/+1 |
* | Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING). | Ralf Corsepius | 2006-11-18 | 1 | -1/+1 |
* | Fix the bug in name change. The UNTIMEOUT macro did not use the ppp version. | Chris Johns | 2006-09-06 | 1 | -1/+1 |
* | * pppd/rtems.main.c, pppd/pppd.h: renamed 'untimeout' | Till Straumann | 2006-09-01 | 2 | -2/+2 |
| | | | | | to 'pppuntimeout' to avoid name clash with [future] bsdnet kernel routine. | ||||
* | *** empty log message *** | Joel Sherrill | 2006-09-01 | 3 | -19/+23 |
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-31 | 2 | -22/+22 |
| | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/include/sys/ioccom.h, libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c, libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h, libnetworking/net/if.c, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c, libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings due to improper use of int which shows up on 16 bit targets. Added ioctl_command_t since IOCTL command argument does not reliably fit into 16 bits. | ||||
* | * pppd/sys-rtems.c: fixed error message so that the correct | Till Straumann | 2006-07-13 | 1 | -1/+1 |
| | | | | ioctl is reported. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -3/+3 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-10 | 1 | -5/+5 |
* | 2005-11-07 Michael Siers <mikes@poliac.com> | Joel Sherrill | 2005-11-07 | 2 | -0/+22 |
| | | | | | * pppd/rtemspppd.c, pppd/rtemspppd.h: Per confirmation from Michael add missing copyright notice. | ||||
* | 2005-11-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-01 | 1 | -1/+1 |
| | | | | * pppd/Makefile.am: Fix typo. | ||||
* | New. | Ralf Corsepius | 2005-10-27 | 1 | -0/+2 |
* | Misc. minor fixes. | Ralf Corsepius | 2005-10-26 | 6 | -12/+14 |
* | Regenerate | Ralf Corsepius | 2005-10-26 | 1 | -12/+24 |
* | Install rtemsdialer.h, rtemspppd.h to $(includedir)/rtems. | Ralf Corsepius | 2005-10-26 | 1 | -9/+6 |
* | Remove (unused). | Ralf Corsepius | 2005-10-26 | 2 | -1520/+0 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -18/+2 |
| | | | | * libnetworking/pppd/Makefile.am: Use preinstall.am. | ||||
* | New. | Ralf Corsepius | 2005-09-19 | 1 | -0/+27 |
* | 2005-05-20 Sergei Organov <osv@topconrd.ru> | Joel Sherrill | 2005-05-20 | 1 | -4/+12 |
| | | | | | | PR 750/networking * libnetworking/pppd/sys-rtems.c: Avoid NULL dereference in wait_input(). | ||||
* | 2005-05-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-08 | 1 | -1/+1 |
| | | | | * libnetworking/pppd/Makefile.am: CPPFLAGS += -D__BSD_VISIBLE. | ||||
* | 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-03 | 1 | -4/+3 |
| | | | | | | | PR 755/rtems * libnetworking/pppd/ipcp.c: Include <rtems/bsdnet/servers.h>. Remove local declarations of rtems_bsdnet_nameservers, rtems_bsdnet_nameservers_count. | ||||
* | 2005-01-31 Sergei Organov <osv@topconrd.ru> | Joel Sherrill | 2005-01-31 | 2 | -16/+16 |
| | | | | | | | | | | | PR 771/pppd * libnetworking/pppd/chat.c, libnetworking/pppd/rtemsmain.c: The fix committed to fix PR736 breaks pppd. chat.c should have its own static ttyfd for pppd to work correctly. The symptom is that second invokation of chat (for connect script) fails due to pppd_ttyfd set to -1 by previous chat invokation (for init script). In addition, this patch fixes leaving of dangling pointer in the abort_stbring[] by chat_send(). | ||||
* | 2005-01-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-01-20 | 6 | -31/+32 |
| | | | | | | | | PR 736/pppd * libnetworking/pppd/chat.c, libnetworking/pppd/demand.c, libnetworking/pppd/pppd.h, libnetworking/pppd/rtemsmain.c, libnetworking/pppd/sys-rtems.c, libnetworking/pppd/utils.c: ttyfd should not be static and should have a name more specific to pppd. | ||||
* | 2005-01-07 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-07 | 1 | -1/+1 |
| | | | | | | | | * libchip/Makefile.am, libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am, librdbg/Makefile.am, optman/Makefile.am, support/Makefile.am: Eliminate CFLAGS_OPTIMIZE_V. | ||||
* | 2005-01-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-02 | 1 | -17/+8 |
| | | | | | | | * libnetworking/pppd/Makefile.am, libnetworking/rtems_servers/Makefile.am, libnetworking/rtems_telnetd/Makefile.am: Remove build-variant support. | ||||
* | 2004-10-19 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-10-19 | 1 | -1/+1 |
| | | | | | * libnetworking/pppd/rtemspppd.c: rtems_task_priority priority. * libnetworking/rtems_telnetd/telnetd.c: Eliminate rtems_unsigned32. | ||||
* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 1 | -1/+1 |
| | | | | | | * aclocal/rtems-cpu-subdirs.m4, libchip/shmdr/shm_driver.h, libnetworking/pppd/utils.c: i960 obsoleted and all references removed. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 3 | -3/+0 |
* | 2004-04-03 Wilfried Busalski <w.busalski@lancier-monitoring.de> | Joel Sherrill | 2004-04-03 | 1 | -101/+144 |
| | | | | | PR 599/pppd * libnetworking/pppd/chat.c: Fre memory that is allocated to fix leak. |
