* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+4 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -4/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-10-18 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-10-18 | 1 | -2/+1 |
| | | | | * pppd/options.c: Remove unused var "ok". | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 15 | -73/+73 |
* | Remove stray ';' introducing unreachable code. | Ralf Corsepius | 2009-01-05 | 1 | -1/+1 |
* | #include <stdint.h> instead of <rtems/stdint.h>. | Ralf Corsepius | 2008-12-11 | 1 | -1/+1 |
* | Add missing initializers. | Ralf Corsepius | 2008-09-08 | 7 | -142/+147 |
* | Stop using old-style function-definitions. | Ralf Corsepius | 2008-08-26 | 14 | -705/+705 |
* | Use stdbool.h. Remove local bool. | Ralf Corsepius | 2008-08-20 | 1 | -2/+1 |
* | Add prototypes. | Ralf Corsepius | 2008-08-03 | 1 | -22/+22 |
* | 2008-05-13 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-05-13 | 1 | -1/+1 |
| | | | | | * pppd/example/system.h: Fix path in example -- NOT COMPILED WITH CPUKIT. | ||||
* | Convert to using C99 fixed-size types instead of BSD fixed-size types. | Ralf Corsepius | 2007-09-16 | 12 | -121/+121 |
* | 2007-06-12 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-06-12 | 1 | -8/+1 |
| | | | | * pppd/Makefile.am: Reflect moving out md*. | ||||
* | Remove (moved to libmd) | Ralf Corsepius | 2007-06-12 | 4 | -725/+0 |
* | Remove md5 and md4 from libpppd.a. | Ralf Corsepius | 2007-06-12 | 1 | -1/+8 |
| | | | | Add pppd/libmd.a. | ||||
* | Don't include pppd.h. | Ralf Corsepius | 2007-06-12 | 1 | -1/+0 |
* | Include <rtems/stdint.h> instead of <stdint.h>. | Ralf Corsepius | 2007-05-09 | 3 | -2/+3 |
* | 2007-05-09 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-05-09 | 1 | -1/+1 |
| | | | | | PR 1243 * pppd/auth.c (set_allowed_addrs): Remove bogus dereference. | ||||
* | 2007-04-16 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2007-04-16 | 1 | -2/+2 |
| | | | | * pppd/utils.c: Use uintptr_t instead of unsigned long. | ||||
* | Include <net/ppp_comp.h> instead of <net/ppp-comp.h>. | Ralf Corsepius | 2007-03-27 | 2 | -2/+2 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-27 | 15 | -240/+229 |
* | Eliminate __P(). | Ralf Corsepius | 2007-03-27 | 9 | -178/+170 |
* | Regenerate. | Ralf Corsepius | 2007-01-08 | 1 | -2/+2 |
* | Regenerate. | Ralf Corsepius | 2006-11-18 | 1 | -1/+1 |
* | Replace AM_CONDITIONAL(HAS_NETWORKING) with AM_CONDITIONAL(LIBNETWORKING). | Ralf Corsepius | 2006-11-18 | 1 | -1/+1 |
* | Fix the bug in name change. The UNTIMEOUT macro did not use the ppp version. | Chris Johns | 2006-09-06 | 1 | -1/+1 |
* | * pppd/rtems.main.c, pppd/pppd.h: renamed 'untimeout' | Till Straumann | 2006-09-01 | 2 | -2/+2 |
| | | | | | to 'pppuntimeout' to avoid name clash with [future] bsdnet kernel routine. | ||||
* | *** empty log message *** | Joel Sherrill | 2006-09-01 | 3 | -19/+23 |
* | 2006-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-08-31 | 2 | -22/+22 |
| | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/include/sys/ioccom.h, libcsupport/src/ioctl.c, libnetworking/kern/uipc_mbuf.c, libnetworking/libc/inet_addr.c, libnetworking/net/ethernet.h, libnetworking/net/if.c, libnetworking/net/if_ethersubr.c, libnetworking/net/if_ppp.c, libnetworking/net/if_pppvar.h, libnetworking/net/if_var.h, libnetworking/net/ppp_tty.c, libnetworking/netinet/in_cksum.c, libnetworking/nfs/bootp_subr.c, libnetworking/rtems/rtems_bsdnet_internal.h, libnetworking/sys/mbuf.h, pppd/md4.c, pppd/pppd.h: Remove warnings due to improper use of int which shows up on 16 bit targets. Added ioctl_command_t since IOCTL command argument does not reliably fit into 16 bits. | ||||
* | * pppd/sys-rtems.c: fixed error message so that the correct | Till Straumann | 2006-07-13 | 1 | -1/+1 |
| | | | | ioctl is reported. | ||||
* | Regenerate. | Ralf Corsepius | 2006-01-14 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -0/+4 |
* | Remove all-local. | Ralf Corsepius | 2006-01-12 | 1 | -2/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -1/+1 |
* | Regenerate. | Ralf Corsepius | 2006-01-12 | 1 | -3/+3 |
* | Cleanups | Ralf Corsepius | 2006-01-12 | 1 | -4/+0 |
* | Regenerate. | Ralf Corsepius | 2006-01-10 | 1 | -5/+5 |
* | 2005-11-07 Michael Siers <mikes@poliac.com> | Joel Sherrill | 2005-11-07 | 2 | -0/+22 |
| | | | | | * pppd/rtemspppd.c, pppd/rtemspppd.h: Per confirmation from Michael add missing copyright notice. | ||||
* | 2005-11-01 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-11-01 | 1 | -1/+1 |
| | | | | * pppd/Makefile.am: Fix typo. | ||||
* | New. | Ralf Corsepius | 2005-10-27 | 1 | -0/+2 |
* | Misc. minor fixes. | Ralf Corsepius | 2005-10-26 | 6 | -12/+14 |
* | Regenerate | Ralf Corsepius | 2005-10-26 | 1 | -12/+24 |
* | Install rtemsdialer.h, rtemspppd.h to $(includedir)/rtems. | Ralf Corsepius | 2005-10-26 | 1 | -9/+6 |
* | Remove (unused). | Ralf Corsepius | 2005-10-26 | 2 | -1520/+0 |
* | 2005-09-19 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-09-19 | 1 | -18/+2 |
| | | | | * libnetworking/pppd/Makefile.am: Use preinstall.am. | ||||
* | New. | Ralf Corsepius | 2005-09-19 | 1 | -0/+27 |
* | 2005-05-20 Sergei Organov <osv@topconrd.ru> | Joel Sherrill | 2005-05-20 | 1 | -4/+12 |
| | | | | | | PR 750/networking * libnetworking/pppd/sys-rtems.c: Avoid NULL dereference in wait_input(). | ||||
* | 2005-05-08 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-05-08 | 1 | -1/+1 |
| | | | | * libnetworking/pppd/Makefile.am: CPPFLAGS += -D__BSD_VISIBLE. | ||||
* | 2005-02-03 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-02-03 | 1 | -4/+3 |
| | | | | | | | PR 755/rtems * libnetworking/pppd/ipcp.c: Include <rtems/bsdnet/servers.h>. Remove local declarations of rtems_bsdnet_nameservers, rtems_bsdnet_nameservers_count. |
