path: root/cpukit/pppd/chat.c (follow)
* 2002-02-27 Ilya Alexeev <ilya@continuum.ru>Joel Sherrill2002-02-271-1/+1
| | | | | | * net/if_ppp.c, pppd/auth.c, pppd/chat.c, pppd/pppd.h, pppd/sys-rtems.c: Add server with pap-authorization capabilities as well as eliminate some warnings.
* 2001-01-31 Mike Siers <mikes@poliac.com>Joel Sherrill2002-01-311-11/+9
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Nice Update of PPPD support which eliminates the requiremetn that drivers be in the termios TASK_DRIVEN mode. Mike did significant testing and reports that it seems to be more stable and handle larger packets better. This patch replaces the termios tasks with more general pppd network driver tasks. The functions pppinput() and pppstart() get called from the interrupt service routine. * Makefile.am, configure.ac, net/Makefile.am, net/bpf.h, net/ethernet.h, net/if.c, net/if.h, net/if_arp.h, net/if_dl.h, net/if_ethersubr.c, net/if_llc.h, net/if_loop.c, net/if_ppp.h, net/if_pppvar.h, net/if_types.h, net/netisr.h, net/ppp-comp.h, net/ppp_defs.h, net/pppcompress.h, net/radix.c, net/radix.h, net/raw_cb.c, net/raw_cb.h, net/raw_usrreq.c, net/route.c, net/route.h, net/rtsock.c, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/cbcp.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.8, pppd/pppd.h, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/upap.c, pppd/upap.h, pppd/utils.c, pppd/example/README, pppd/example/netconfig.h, wrapup/Makefile.am: Modified. * net/bsd-comp.c, net/if_ppp.c, net/ppp-deflate.c, net/ppp.h, net/ppp_tty.c, net/pppcompress.c, net/zlib.c, net/zlib.h: New file. * modem/, modem/.cvsignore, modem/Makefile.am, modem/ppp.c, modem/ppp.h, modem/ppp_tty.c, modem/pppcompress.c: Subdirectory removed.
* 2001-10-12 Mike Siers <mikes@poliac.com>Joel Sherrill2001-10-121-263/+153
| | | | | | | | | | | * Update to stable working state. Congratulations Mike! :) * modem_example: Directory removed. * modem_example/16550.h, modem_example/README, modem_example/modem.c, modem_example/modem.h, modem_example/ppp.c, modem_example/ppp.h, modem_example/pppcompress.c: Files removed. * pppd/example/pppd.options: New file. * pppd/README, pppd/STATUS, pppd/cbcp.c, pppd/cbcp.h, pppd/chat.c, pppd/pppd.h, pppd/rtemsmain.c: Updated.
* 2001-08-16 Mike Siers <mikes@poliac.com>Joel Sherrill2001-08-161-112/+34
| | | | | | | | | | | | | | | | | | | | | | | | | | * Update of PPPD to 2.3.11 from 2.3.5 and addition of an example application. Mike's notes on the modifications: - renamed error() function because of namespace problems - removed calls to the exit() funciton - removed extra files from the pppd source directory - defined pppd task constant values in rtemspppd.h - modifyied example code to get actual tick per second value - placed the pppd 2.3.11 man page file (pppd.8) into the pppd directory * pppd/cbcp.c, pppd/cbcp.h, pppd/main.c, pppd/ppp_tty.c, pppd/pppmain.c, pppd/rtems-ppp.c, pppd/rtems-ppp.c: Deleted. * pppd/pppd.8, pppd/rtemsmain.c, pppd/rtemspppd.c, pppd/rtemspppd.h, pppd/sys-rtems.c, pppd/utils.c, pppd/example/Makefile, pppd/example/README, pppd/example/init.c, pppd/example/netconfig.h, pppd/example/ppp.conf, pppd/example/pppdapp.c, pppd/example/system.h: New files. * modem/ppp_tty.c, net/if_ppp.h, pppd/Makefile.am, pppd/README, pppd/STATUS, pppd/auth.c, pppd/ccp.c, pppd/ccp.h, pppd/chap.c, pppd/chap.h, pppd/chap_ms.c, pppd/chap_ms.h, pppd/chat.c, pppd/demand.c, pppd/fsm.c, pppd/fsm.h, pppd/ipcp.c, pppd/ipcp.h, pppd/ipxcp.c, pppd/ipxcp.h, pppd/lcp.c, pppd/lcp.h, pppd/magic.c, pppd/magic.h, pppd/options.c, pppd/patchlevel.h, pppd/pathnames.h, pppd/pppd.h, pppd/upap.c, pppd/upap.h: Modified.
* 2000-11-25 Antti P Miettinen <antti.p.miettinen@nokia.com>Joel Sherrill2000-11-251-0/+4
| | | | | | | | | | | | * wrapup/Makefile.am: Added modem subdir. * configure.in, Makefile.am: Added modem subdir. * net/Makefile.am: Added if_pppvar.h, pppcompress.h. * pppd/Makefile.am: Added pppmain.c (which needs work). * pppd/chat.c, pppd/fsm.c, pppd/fsm.h, pppd/ipxcp.c, pppd/main.c, pppd/ppp_tty.c, pppd/upap.c: Changes from Thomas Doerfler <Thomas.Doerfler@imd-systems.de> and cosmetic changes by me. Actually main.c and ppp_tty.c should be scratched. The modem subdir has the real ppp_tty.c and the real pppd main is in pppmain.c.
* Added port of ppp-2.3.5 from Tomasz Domin <dot@comarch.pl> of ComArch SA.Joel Sherrill1999-11-301-0/+1004
Tomasz only tested this on the mpc823. The official site for the original source for this PPP implementation is: ftp://cs.anu.edu.au/pub/software/ppp NOTE: As of 11/30/1999, the current version of this source is 2.3.10.
