* | Split unistd.c file into sysconf.c and sleep.c. | Joel Sherrill | 1999-11-05 | 2 | -0/+68 |
* | Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since RTEMS | Joel Sherrill | 1999-11-03 | 5 | -8/+9 |
| | | | | internal symbols are supposed to have leading underscores. | ||||
* | Added prototype of _POSIX_Semaphore_Delete to avoid warnings. | Joel Sherrill | 1999-11-03 | 1 | -0/+12 |
* | Added prototype of POSIX_Thread_cancel_run to avoid warnings. | Joel Sherrill | 1999-11-03 | 1 | -0/+12 |
* | Split types.s into individual files. | Joel Sherrill | 1999-11-02 | 11 | -171/+302 |
* | Final tuning required to drop out POSIX timers. | Joel Sherrill | 1999-11-02 | 3 | -46/+58 |
* | *** empty log message *** | Joel Sherrill | 1999-11-02 | 3 | -921/+979 |
* | Split cancel.c into multiple files. | Joel Sherrill | 1999-11-02 | 7 | -182/+272 |
* | Missed these in the initial split up. | Joel Sherrill | 1999-11-02 | 2 | -0/+177 |
* | Split key.c into multiple files. | Joel Sherrill | 1999-11-02 | 6 | -225/+290 |
* | Wrong routine was initially cut into this file. | Joel Sherrill | 1999-11-02 | 1 | -14/+6 |
* | Split time.c into multiple files. | Joel Sherrill | 1999-11-02 | 13 | -365/+573 |
* | Split condition variables into multiple files. | Joel Sherrill | 1999-11-02 | 14 | -482/+537 |
* | Split the POSIX semaphore manager into multiple files. | Joel Sherrill | 1999-11-02 | 17 | -585/+829 |
* | Split some more stuff out of psignal.c. | Joel Sherrill | 1999-11-02 | 6 | -235/+341 |
* | Split mutex.c into multiple files. | Joel Sherrill | 1999-11-02 | 22 | -702/+1029 |
* | Split mqueue into multiple files. | Joel Sherrill | 1999-11-02 | 1 | -0/+28 |
* | Removed warnings. | Joel Sherrill | 1999-11-02 | 1 | -2/+2 |
* | Split mqueue.c into a variety of files. | Joel Sherrill | 1999-11-02 | 16 | -672/+1120 |
* | Now much closer to working. | Joel Sherrill | 1999-11-02 | 1 | -7/+61 |
* | Added assert in case _Objects_Get_information fails since this | Joel Sherrill | 1999-11-02 | 1 | -0/+4 |
| | | | | should NEVER occur. | ||||
* | Commented out lines causing warning. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added #define for SEM_FAILED. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added include of <sys/siginfo.h>. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 |
* | Added message queues and semaphores. | Joel Sherrill | 1999-11-02 | 1 | -1/+3 |
* | Added name to id support routine. | Joel Sherrill | 1999-11-01 | 1 | -0/+15 |
* | Removed routines that had already been separated into their own files. | Joel Sherrill | 1999-11-01 | 1 | -505/+0 |
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca> | Joel Sherrill | 1999-10-25 | 1 | -0/+8 |
| | | | | | to initialize the pthread cancellation fields. This is a patch to _POSIX_Threads_Create_extension that fixes the problem. | ||||
* | Fixed core dump caused when output parameter (otimer) was NULL. | Joel Sherrill | 1999-10-21 | 1 | -3/+7 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 4 | -13/+13 |
| | | | | where wrapup left pieces out of the librtemsall.a. | ||||
* | Applied patch rtems-rc-19990820-6.diff.gz from | Joel Sherrill | 1999-09-07 | 4 | -0/+62 |
| | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> which converted many Makefile.in's to Makefile.am's. This added a lot of files. | ||||
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca> to add | Joel Sherrill | 1999-08-30 | 1 | -1/+13 |
| | | | | | support for return codes from POSIX threads that do an implicit exit by returning from the bottom of the main function. | ||||
* | Honor 0 as PID of caller. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | New file to implement signal(2). | Joel Sherrill | 1999-07-01 | 1 | -0/+50 |
* | Removed check for initialized ID at request of Rosimildo DaSilva | Joel Sherrill | 1999-05-14 | 1 | -0/+23 |
| | | | | | <rdasilva@connecttel.com> who encountered random failures in his port of omniORB2. | ||||
* | Made all calls to _Thread_Yield_processor consistent in how they are | Joel Sherrill | 1999-05-07 | 1 | -2/+3 |
| | | | | wrapped by calls to _Thread_Enable_dispatch and _Thread_Disable_dispatch. | ||||
* | Patch from Jiri Gaisler <jgais@ws.estec.esa.nl> to allow stacksize | Joel Sherrill | 1999-05-07 | 2 | -1/+2 |
| | | | | of POSIX Init thread to be user configured. | ||||
* | Repairing damage and recovering changes including C++ wrappers.. | Joel Sherrill | 1999-04-26 | 5 | -4/+44 |
* | Recovered changes since CVS file was corrupted. | Joel Sherrill | 1999-04-26 | 1 | -1/+9 |
* | The default action for real-time signals is supposed to be SIGACTION_TERMINATE. | Joel Sherrill | 1999-04-19 | 1 | -15/+15 |
| | | | | | Jiri Gaisler caught this and submitted a patch but a subsequent patch backed it out accidentally. | ||||
* | Added include of rtems/posix/cancel.h. | Joel Sherrill | 1999-04-15 | 1 | -0/+1 |
* | Removed alarm(), killinfo() and pause() because they are now in their own file. | Joel Sherrill | 1999-04-15 | 1 | -372/+1 |
* | Now compiles and is included in normal build even though it is untested. | Joel Sherrill | 1999-04-15 | 2 | -67/+75 |
| | | | | Added multiprocessing conditional. | ||||
* | Cleaned up. | Joel Sherrill | 1999-04-15 | 1 | -3/+6 |
* | Now compiles and is included in normal build even though it is untested. | Joel Sherrill | 1999-04-15 | 2 | -8/+11 |
* | Enabled cancellation information in POSIX API thread extension structure. | Joel Sherrill | 1999-04-15 | 1 | -2/+0 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to correct the | Joel Sherrill | 1999-04-12 | 2 | -30/+931 |
| | | | | --enable-tests problem a better way. | ||||
* | Added line to initialize timer_max. | Joel Sherrill | 1999-04-12 | 1 | -0/+2 |
* | When compiled in debug mode, the POSIX threads inline file was not | Joel Sherrill | 1999-03-31 | 1 | -0/+1 |
| | | | | included and we ended up with undefined references. | ||||
* | Fixed typo where _POSIX_signals_Clear_process_signals was not prototyped | Joel Sherrill | 1999-03-30 | 1 | -1/+1 |
| | | | | and _POSIX_signals_Set_process_signals was done twice. |
