* | + Comment cleanup | Jennifer Averett | 2000-01-13 | 4 | -15/+12 | |
* | Removed referance to rtems error. | Jennifer Averett | 2000-01-13 | 1 | -1/+2 | |
| | | | | Added correct include file. | |||||
* | Debugged and yellow line tested routines. | Jennifer Averett | 2000-01-12 | 3 | -41/+71 | |
* | + Modified return codes | Jennifer Averett | 2000-01-12 | 1 | -16/+27 | |
| | | | | | + Added messsage size check + Debugged and yellowed out routine | |||||
* | + Added signal processing. | Jennifer Averett | 2000-01-12 | 1 | -1/+3 | |
| | | | | + Yellow line tested source. | |||||
* | + Modified to correct return codes. | Jennifer Averett | 2000-01-12 | 1 | -2/+5 | |
| | | | | | + Removed extra flag attribute from message queue structure. + Yellow-lined all posix message queue routines. | |||||
* | + Changed call from core flush to core close routine. This flushes waiting | Jennifer Averett | 2000-01-12 | 1 | -2/+4 | |
| | | | | queues as well as the messages. | |||||
* | + Removed name validation code (this was already done in nametoid. | Jennifer Averett | 2000-01-12 | 1 | -41/+6 | |
* | Fixed spacing. | Joel Sherrill | 2000-01-11 | 1 | -1/+1 | |
* | This code did not return properly when a process oriented signal | Joel Sherrill | 2000-01-11 | 1 | -6/+5 | |
| | | | | was pending. Reported by Wayne Bullaughey <wayneb@cacdsp.com>. | |||||
* | Don't look at the object information structure for threads/tasks | Joel Sherrill | 2000-01-10 | 2 | -17/+28 | |
| | | | | | for APIs that are not configured. This resulted in weird behavior when ITRON was disabled on some targets. | |||||
* | Added support for simple binary semaphores in addition to the high | Joel Sherrill | 2000-01-05 | 1 | -1/+5 | |
| | | | | | | | | | | | | power binary/mutex style semaphores already supported by RTEMS. This was done at the request of Eric Norum <eric@cls.usask.ca> in support of his effort to port EPICS to RTEMS. This change consisted of changing the nesting_allowed boolean into a lock_nesting_behavior enumerated value as well as allowing the core mutex object to optionally support ensuring that the holder of a binary semaphore released it. Finally, a more subtle enhancement was to allow the non-holder to release a priority inheritance/ceiling mutex and still allow the holding task to return to its original priority. | |||||
* | Added priority conversion between POSIX and core. | Jennifer Averett | 2000-01-05 | 1 | -2/+17 | |
* | Added priority conversion between POSIX and core priorities. | Jennifer Averett | 2000-01-05 | 1 | -2/+29 | |
* | + Changed priority to the POSIX priority type. | Jennifer Averett | 2000-01-05 | 1 | -9/+46 | |
| | | | | | | | + Added priority validation + Changed to call correct core routine. + Added priority conversion + Resolved return type problems. | |||||
* | + Added check for reading from a write only queue. | Jennifer Averett | 2000-01-05 | 1 | -1/+12 | |
| | | | | + Added ability to return message priority from the core. | |||||
* | + Added check for name greater than PATH_MAX. | Jennifer Averett | 2000-01-05 | 1 | -0/+3 | |
* | + Changed to resonable default values for maxmsg and msgsize. | Jennifer Averett | 2000-01-05 | 1 | -3/+11 | |
| | | | | + Added oflag tracking. | |||||
* | Added mqueuetranslatereturncode.c. | Jennifer Averett | 2000-01-05 | 1 | -1/+1 | |
* | Added routines to translate to and from the core message queue return codes. | Jennifer Averett | 2000-01-05 | 1 | -0/+68 | |
* | Added this file to contain an example program. | Joel Sherrill | 2000-01-04 | 1 | -0/+27 | |
* | Removed warnings. | Joel Sherrill | 2000-01-04 | 2 | -4/+4 | |
* | + Added routine to remove from namespace. | Jennifer Averett | 1999-12-23 | 1 | -0/+13 | |
* | + Added check for name greater than PATH_MAX | Jennifer Averett | 1999-12-23 | 1 | -0/+14 | |
* | + Debugged. | Jennifer Averett | 1999-12-23 | 2 | -40/+61 | |
* | + Filled in routine. | Jennifer Averett | 1999-12-23 | 1 | -1/+15 | |
* | + Initial debug | Jennifer Averett | 1999-12-23 | 1 | -0/+6 | |
* | + Made work | Jennifer Averett | 1999-12-23 | 1 | -15/+55 | |
| | | | | | + Added checks for valid attribute maxmsg and msgsize + Added check for ENAMETOOLONG | |||||
* | + Fixed errno response to match the POSIX manual. | Jennifer Averett | 1999-12-23 | 1 | -1/+1 | |
* | Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-29 | 2 | -7/+20 | |
| | | | | | | | | | | | | | | | | | | | | | | | which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working) | |||||
* | Made sure POSIX would build with MP enabled. | Joel Sherrill | 1999-11-29 | 7 | -10/+127 | |
* | Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 3 | -3/+113 | |
| | | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib." | |||||
* | Fixed dispatching and cleaned up code. | Jennifer Averett | 1999-11-22 | 2 | -30/+14 | |
* | + Corrected enable/disable of dispatch. | Jennifer Averett | 1999-11-22 | 1 | -23/+31 | |
| | | | | + Cleaned up code. | |||||
* | + Updated comments. | Jennifer Averett | 1999-11-22 | 1 | -9/+20 | |
| | | | | + Corrected enable/disable of dispatch. | |||||
* | + Corrected bug in error check. | Jennifer Averett | 1999-11-22 | 1 | -2/+1 | |
* | + Added description of routine to comment. | Jennifer Averett | 1999-11-22 | 1 | -0/+4 | |
* | + Corrected error processing code. | Jennifer Averett | 1999-11-22 | 1 | -14/+15 | |
* | + Added checks for NULL and NULL string names (for sem_open & sem_unlink). | Jennifer Averett | 1999-11-22 | 1 | -1/+7 | |
* | + Cleaned up comments. | Jennifer Averett | 1999-11-22 | 1 | -6/+16 | |
* | Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1999-11-22 | 1 | -6/+6 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | .. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams. | |||||
* | Added EINVAL for passing a NULL pointer in. | Jennifer Averett | 1999-11-18 | 1 | -0/+4 | |
* | + Debuged to the point that you could open, unlink and close a semaphore. | Jennifer Averett | 1999-11-18 | 4 | -30/+29 | |
| | | | | but all paths have not been checked, yet. | |||||
* | Added a routine to remove a semaphore name from its namespace. | Jennifer Averett | 1999-11-18 | 1 | -0/+15 | |
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 69 | -138/+69 | |
* | Return a reasonable error other than ENOSYS. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
* | Added call to _Watchdog_Remove to remove the sporadic timer. It was | Joel Sherrill | 1999-11-16 | 1 | -0/+1 | |
| | | | | being reinserted onto the ticks chain. | |||||
* | Removed nanosleep() since it is now in its own file. | Joel Sherrill | 1999-11-15 | 1 | -21/+0 | |
* | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1999-11-09 | 1 | -1/+1 | |
| | | | | for RTEMS. | |||||
* | sem_close was accidentally lost in the split. | Joel Sherrill | 1999-11-09 | 1 | -0/+47 | |
