* posix/include/semaphore.h, posix/include/rtems/posix/mutex.h,
posix/inline/rtems/posix/mutex.inl: Fix typos.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h,
score/include/rtems/score/tod.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
* posix/Makefile.am: Remove posixtime.h.
* posix/src/clockgetres.c, posix/src/clockgettime.c,
posix/src/clocksettime.c: Remove posixtime.h.
Require CLOCK_PROCESS_CPUTIME_ID, CLOCK_THREAD_CPUTIME_ID.
* posix/src/posixtime.h: Remove.
* Makefile.am: Reformat.
* posix/Makefile.am: Reformat.
* posix/Makefile.am: Add posixtime.h.
Use CLOCK_PROCESS_CPUTIME_ID, CLOCK_THREAD_CPUTIME_ID.
Include posix/src/posixtime.h.
* posix/src/posixtime.h: New.
* posix/src/mqueuegetattr.c,
score/inline/rtems/score/schedulerpriority.inl: Remove warnings.
PR 1759/cpukit
* posix/src/cancel.c, posix/src/pthreaddetach.c,
posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c,
posix/src/pthreadjoin.c, posix/src/pthreadkill.c,
posix/src/pthreadsetschedparam.c: Some POSIX pthread services did not
support using Classic API Task Ids.
* libcsupport/src/sleep_noposix.c: Remove.
* libcsupport/Makefile.am: Reflect changes above.
* posix/src/sleep.c, posix/src/usleep.c: Remove.
* posix/Makefile.am: Reflect changes above.
* configure.ac: Error out if libc doesn't provide sleep, usleep.
* posix/include/rtems/posix/mqueue.h: Relocate "extern C++" guards.
* posix/include/rtems/posix/key.h: Add missing includes.
* posix/include/mqueue.h: Relocate "extern C++" guards.
* libmisc/capture/capture.c, posix/src/keyfreememory.c,
posix/src/pthread.c, score/include/rtems/score/wkspace.h,
score/src/objectextendinformation.c,
score/src/objectnamespaceremove.c, score/src/objectsetname.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/wkspace.c: Many places were checking for a NULL pointer
before calling _Workspace_Free. By moving the check into
_Workspace_Free, we eliminate a number of conditional paths and make
it harder to return a NULL pointer.
* posix/src/aio_cancel.c: Fixed ending of if braces.
2011-01-17 Alin Rus <alin.codejunkie@gmail.com>
* posix/src/aio_misc.c: Add debug information. Fixed idle_threads/
active_threads issues. Fixed infinite loop in rtems_aio_handle().
* posix/src/aio_misc.c: Fix rtems_aio_remove_req did not iterate
over chain.
* posix/src/aio_cancel.c: Add debug information. Add check for
bad file descriptor. Add else branch for cancel request on empty
IQ chain.
* posix/src/aio_cancel.c: Use perfd field not next_fd.
* configure.ac, posix/src/signal_2.c: sighandler_t is defined
conditionally in some versions of newlib and unconditionally in
others. Make sure we always compile.
* libfs/src/dosfs/fat_file.c, libfs/src/imfs/imfs_debug.c,
libfs/src/imfs/imfs_directory.c, libfs/src/imfs/imfs_getchild.c,
posix/src/killinfo.c, score/inline/rtems/score/schedulerpriority.inl,
score/inline/rtems/score/watchdog.inl, score/src/apiext.c,
score/src/chain.c, score/src/coremsgflushsupp.c,
score/src/coremsginsert.c, score/src/objectshrinkinformation.c,
score/src/schedulerpriorityyield.c,
score/src/threadqdequeuepriority.c,
score/src/threadqenqueuepriority.c,
score/src/threadqextractpriority.c, score/src/threadqfirstfifo.c,
score/src/threadqfirstpriority.c, score/src/threadyieldprocessor.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/watchdogreportchain.c: Avoid chain API violations.
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/scheduler.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl: New files.
* posix/include/rtems/posix/aio_misc.h, posix/src/aio_misc.c: Small
fixes.
* posix/src/psignalunblockthread.c: Formatting.
* posix/src/mutextimedlock.c: Check status local variable not
lock_status.
* Makefile.am, configure.ac, posix/Makefile.am, posix/src/pthread.c:
* posix/src/pthreadattrgetguardsize.c, posix/src/pthreadattrgetstack.c,
posix/src/pthreadattrsetguardsize.c, posix/src/pthreadattrsetstack.c:
New files.
* posix/src/psignal.c: Fixed NULL pointer access.
* posix/src/killinfo.c: Ensure interested is non-NULL before using it.
Coverity Id 164/UNINIT
Coverity Id 165/UNINIT
* posix/src/prwlockinit.c, posix/src/pspininit.c,
score/include/rtems/score/corespinlock.h,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl: Add initialization helpers
for score rwlock and spinlock. Use them from POSIX.
* posix/src/aio_cancel.c: Spray pthread_mutex_unlocks.
* posix/src/aio_read.c: aio_nbytes is always >= 0.
* posix/src/aio_write.c: aio_nbytes is always >= 0.
Fix typo in comment.
CID 79/DEADCODE
CID 78/DEADCODE
CID 77/DEADCODE
CID 76/DEADCODE
* posix/src/condtimedwait.c, posix/src/mutextimedlock.c,
posix/src/semtimedwait.c: Resolve various dead code issues identified
by Coverity scanner.
* posix/include/rtems/posix/aio_misc.h: Add decl for aio_request_queue.
* posix/src/aio_misc.c: Add aio_request_queue.
* posix/include/rtems/posix/aio_misc.h: Remove rtems_aio_request_s,
rtems_aio_request_chain_s, rtems_aio_queue_s;
* posix/include/aio.h: Separate LIO-modes from LIO-opcodes (From
freebsd).
* posix/include/aio.h: Add LIO_SYNC.
* posix/include/rtems/posix/aio_misc.h: Add aio_request_queue,
Cosmetics.
* posix/src/aio_cancel.c, posix/src/aio_fsync.c, posix/src/aio_misc.c:
Rework.
rtems_aio_queue_s.size (Unused).
* posix/src/aio_misc.c: Remove aio_request_queue.size.
Cosmetics.
* posix/Makefile.am: Reflect aio-changes.
* posix/src/aio_misc.c: New.
* posix/src/aio_error.c, posix/src/aio_read.c,
* posix/src/aio_return.c, posix/src/aio_write.c:
New implementation.
* posix/include/aio.h: Extend struct aiocb.
* posix/include/rtems/posix/aio_misc.h: New.
PR 1615/cpukit
* posix/src/keyrundestructors.c: Improved POSIX compliance. Now we may
have an unlimited number of iterations.
* posix/include/aio.h, posix/src/aio_return.c:
Let aio_return return ssize_t (Mandated by POSIX).
PR 1599/cpukit
* posix/src/psignalunblockthread.c, posix/src/pthreadkill.c,
rtems/src/signalsend.c, score/include/rtems/score/percpu.h,
score/src/threaddispatch.c, score/src/threadready.c,
score/src/threadresume.c, score/src/threadsetstate.c,
score/src/threadstartmultitasking.c, score/src/threadsuspend.c,
score/src/threadyieldprocessor.c: Rename _Context_Switch_necessary to
_Thread_Dispatch_necessary to more properly reflect the intent.
* posix/src/psignalunblockthread.c: Clean up and simplify.
* posix/src/condinit.c, posix/src/condwaitsupp.c,
posix/src/psignalunblockthread.c: Clean up some signal interruption
code.
* posix/src/keycreate.c: Fix typo.
