* | Wait_support: removed the calls to mutex core to posix status codes | Mark Johannes | 1996-08-12 | 1 | -2/+2 | |
* | mutex.h: removes the promotion of core status code to POSXI status codes | Mark Johannes | 1996-08-12 | 1 | -12/+0 | |
* | fixed spacing ; moved a dummy MP support routine to clean up printout. | Joel Sherrill | 1996-08-12 | 1 | -9/+10 | |
* | _POSIX_Mutex_Get: made null id an error | Joel Sherrill | 1996-08-12 | 1 | -0/+5 | |
* | pthread_mutex_getprioceiling: added error check for null old_ceiling | Joel Sherrill | 1996-08-12 | 1 | -2/+4 | |
| | | | | | pthread_mutex_setprioceiling: added comment indicating an error was impossible to generate. | |||||
* | mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status | Mark Johannes | 1996-08-12 | 1 | -0/+12 | |
* | _POSIX_Condition_variables_Wait_support: added ↵ | Mark Johannes | 1996-08-12 | 1 | -4/+5 | |
| | | | | _POSIX_Mutex_From_core_mutex_status for the two calls to the mutex manager | |||||
* | _POSIX_Condition_variables_Signal_support: added setting mutex back to NULL | Mark Johannes | 1996-08-12 | 1 | -5/+7 | |
| | | | | | | if the queue has been emptied of waiting tasks. _POSIX_Condition_variables_Wait_support: added error check for different mutexesfor the same condition variable. Also added _Thread_queue_Enter_critical_section | |||||
* | pthread_mutexattr_setprioceiling: fixed typo | Joel Sherrill | 1996-08-12 | 1 | -1/+1 | |
* | pthread_mutexattr_setprioceiling: valid priority ceiling check looked at | Joel Sherrill | 1996-08-12 | 1 | -1/+1 | |
| | | | | value in attribute structure instead of passed in priority | |||||
* | pthread_mutexattr_getprotocol: added check for attribute structure being | Joel Sherrill | 1996-08-12 | 1 | -1/+1 | |
| | | | | initialized | |||||
* | added code to catch NULL pointers for return values passed to get routines | Joel Sherrill | 1996-08-09 | 1 | -6/+9 | |
* | sched_yield: was not invoking the dispatcher. | Joel Sherrill | 1996-08-09 | 1 | -1/+3 | |
* | merged remote object id and invalid id error cases. | Joel Sherrill | 1996-08-09 | 1 | -6/+3 | |
* | _POSIX_signals_Clear_signals: added this routine | Mark Johannes | 1996-08-08 | 1 | -12/+36 | |
| | | | | _POSIX_signals_Get_highest: changed initial starting signal to SIGHUP, still needs SIGFIRSTNOTRT | |||||
* | added ss_high_priority field to support sporadic server. | Joel Sherrill | 1996-08-08 | 1 | -0/+1 | |
* | sporadic server debugged and working. This required minor changes in all | Joel Sherrill | 1996-08-07 | 1 | -20/+40 | |
| | | | | sporadic server related routines. | |||||
* | _POSIX_Mutex_From_core_mutex_status: added priority ceiling violation case | Mark Johannes | 1996-08-07 | 1 | -0/+2 | |
* | _POSIX_Threads_Delete_extension: reorder to eliminate use of local pointer | Joel Sherrill | 1996-08-06 | 1 | -6/+9 | |
| | | | | | | variable before set. pthread_join: using local variable so user can pass NULL pointer as argument | |||||
* | POSIX_Mutex_Default_attributes: changed prio_ceiling to maximum priority | Mark Johannes | 1996-08-06 | 1 | -1/+2 | |
* | pthread_getspecific: use local variable so references to tcb are completed | Joel Sherrill | 1996-08-06 | 1 | -1/+6 | |
| | | | | before enabling dispatching | |||||
* | added page delimiters for comment blocks | Joel Sherrill | 1996-08-01 | 2 | -11/+25 | |
* | Fixed default vectors initialization, sigaction which had a redundant | Mark Johannes | 1996-07-15 | 1 | -42/+64 | |
| | | | | if clause for DFT action. | |||||
* | basic test cases passed | Joel Sherrill | 1996-07-04 | 1 | -4/+35 | |
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 16 | -64/+64 | |
* | *** empty log message *** | Joel Sherrill | 1996-07-02 | 1 | -1/+22 | |
* | initial modifications to support sigtimedwait. | Joel Sherrill | 1996-06-15 | 1 | -9/+30 | |
* | fields for init threads stuff said tasks. | Joel Sherrill | 1996-06-14 | 1 | -2/+2 | |
* | sigtimedwait passes initial test cases of timeout and simple satisfaction. | Mark Johannes | 1996-06-13 | 1 | -1/+5 | |
* | added queued signals and cleaned up setting of process wide signals so | Joel Sherrill | 1996-06-13 | 1 | -68/+148 | |
| | | | | it occurs in only one place. | |||||
* | config.h: added maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 2 | -1/+4 | |
| | | | | psignal.h: fixed typo. | |||||
* | basic test cases for kill() and alarm(). | Joel Sherrill | 1996-06-13 | 2 | -11/+63 | |
| | | | | | kill() in particular needs more test cases for full coverage. The search for a thread interested in this signal has a lot of paths. | |||||
* | added prototype for manager initialization routine. | Joel Sherrill | 1996-06-13 | 1 | -0/+2 | |
* | basic kill() which send a signal to pthread_self() appears to work. | Joel Sherrill | 1996-06-12 | 1 | -7/+18 | |
* | initial implementation of blocking signal routines -- sigwait, sigwaitinfo, | Joel Sherrill | 1996-06-12 | 1 | -34/+227 | |
| | | | | sigtimedwait, sigsuspend, and pause. | |||||
* | added comment to make sure we add unblock of thread | Joel Sherrill | 1996-06-11 | 1 | -0/+2 | |
* | first attempt at adding algorithm to select the thread which will | Joel Sherrill | 1996-06-11 | 2 | -23/+255 | |
| | | | | receive a process-directed signal. | |||||
* | deleted field for signals_global_pending. | Joel Sherrill | 1996-06-11 | 1 | -1/+0 | |
* | tested blocking a signal, sending it to self, then unblocking it. | Joel Sherrill | 1996-06-11 | 2 | -32/+61 | |
| | | | | | make minimum stack size for posix threads double that of the cpu's minimum requirement. | |||||
* | Basic signal functionality appears to work. pthread_kill() can successfully | Joel Sherrill | 1996-06-11 | 3 | -9/+31 | |
| | | | | | | | send signals to the current thread or to another blocked thread. nanosleep() can be interrupted by a signal and return the time remaining. Post switch extension added to dispatch posix signal handlers. | |||||
* | new file. | Joel Sherrill | 1996-06-11 | 1 | -1/+1 | |
* | added psignal.h | Joel Sherrill | 1996-06-10 | 1 | -0/+13 | |
* | first attempt at the routine which vectors signals. | Joel Sherrill | 1996-06-10 | 2 | -12/+328 | |
* | *** empty log message *** | Joel Sherrill | 1996-06-10 | 1 | -1/+1 | |
* | changed code which set errno and then returned -1 to use the macro | Joel Sherrill | 1996-06-07 | 5 | -56/+32 | |
| | | | | set_errno_and_return_minus_one. | |||||
* | key destructor is now run at correct point in pthread_exit() sequence and | Joel Sherrill | 1996-06-07 | 3 | -104/+173 | |
| | | | | | | | | should be correct for other apis as well. missing page numbers added on some references. initial attempt at sig_procmask() and pthread_sigmask(). | |||||
* | in newlib now | Joel Sherrill | 1996-06-06 | 1 | -0/+4 | |
* | Removed assert's from routines which return the error ENOSYS. | Joel Sherrill | 1996-06-06 | 1 | -12/+0 | |
* | process oriented scheduler routines now return ENOSYS | Joel Sherrill | 1996-06-06 | 1 | -4/+8 | |
* | removed timer_getoverrun() since it was also in ptimer.c | Joel Sherrill | 1996-06-06 | 1 | -11/+0 | |
