reduce size of data area.
IMFS: Fixed creation of symbolic links to avoid a compiler warning.
DOSFS: Use LibBlock instead of read() to read the boot record.
* itron/include/rtems/itron/task.h, itron/src/del_tsk.c,
itron/src/exd_tsk.c, itron/src/task.c,
posix/include/rtems/posix/threadsup.h, posix/src/cancel.c,
posix/src/cancelrun.c, posix/src/pthread.c, posix/src/pthreadexit.c,
posix/src/setcancelstate.c, posix/src/setcanceltype.c,
posix/src/testcancel.c, rtems/src/taskdelete.c,
score/inline/rtems/score/object.inl, score/src/objectclose.c,
score/src/threadclose.c: Make all task delete/exit/cancel routines
follow the same critical section pattern. Also ensure that POSIX
cancelation routines are run at thread exit.
* posix/src/keycreate.c, posix/src/pthreadequal.c,
rtems/src/semtranslatereturncode.c,
score/cpu/powerpc/rtems/score/powerpc.h,
score/src/threadblockingoperationcancel.c: Fix compilation errors
when --enable-rtems-debug is used.
* posix/src/key.c: Include <limits.h>
* posix/src/psignal.c, rtems/src/tasks.c: Do not attempt to process
a NULL extension block.
* posix/Makefile.am: Make clock_settime() available always just like
clock_gettime().
* itron/include/rtems/itron/task.h, itron/src/cre_tsk.c,
posix/src/pthreadcreate.c, rtems/src/taskcreate.c,
rtems/src/taskdelete.c, rtems/src/timerserver.c,
score/src/threadclose.c, score/src/threadcreateidle.c,
score/src/threadinitialize.c: Switch task create and delete
operations to using API Allocator Mutex. This moves almost all uses
of the RTEMS Workspace from dispatching disabled to mutex protected
which should improve deterministic behavior. The implementation was
carefully done to allow task create and delete extensions to invoke
more services. In particular, a task delete extension should be able
to do mutex and file operations.
* posix/src/mqueueunlink.c, score/Makefile.am,
score/inline/rtems/score/object.inl: Enhance
_Objects_Namespace_remove() to handle freeing object names which are
strings. All changed _Objects_Close() to call
_Objects_Namespace_remove(). The resulting code was then moved from
inline routines to function calls.
* score/src/objectclose.c, score/src/objectnamespaceremove.c: New files.
* posix/src/clockgettime.c, posix/src/clocksettime.c,
Minor modifications to improve testability.
* posix/src/pthreadcreate.c: Add NULL check for thread entry.
* posix/src/pthreadinitthreads.c: Clean up error paths.
* libcsupport/preinstall.am, posix/preinstall.am: Revert temporary
changes which aid in coverage testing.
* posix/src/cond.c, posix/src/key.c, posix/src/mqueuenametoid.c,
posix/src/mutex.c, posix/src/pbarrier.c, posix/src/prwlock.c,
posix/src/pspin.c, posix/src/pthread.c, posix/src/ptimer.c,
posix/src/semaphorenametoid.c: Add option for all POSIX objects
whether named or unnamed to have a string name. If the API does
not directly support having a name, then the user must explicitly
assign it using rtems_object_set_name().
* rtems/src/rtemsobjectgetapiclassname.c: Improved testability.
* score/include/rtems/score/object.h,
score/src/objectgetnameasstring.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c: Modifications required to pass testing of
recently modified object name operations. Also eliminated
multiprocessing related code that was not reachable.
* posix/src/timersettime.c: Fix to remove warning.
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectgetclassinfo.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New files.
* rtems/src/rtemsidtoname.c: Removed.
* posix/src/mqueuesendsupp.c: Remove warning.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/prwlockinit.c, posix/src/pspininit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectextendinformation.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
* posix/include/rtems/posix/timer.h, posix/src/cleanuppop.c,
posix/src/cleanuppush.c, posix/src/mqueueclose.c,
posix/src/timergettime.c, posix/src/timersettime.c,
score/include/rtems/score/timespec.h:
* posix/Makefile.am, posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/mutex.h, posix/inline/rtems/posix/cond.inl,
posix/inline/rtems/posix/mutex.inl: Do not include POSIX Mutex or
Condition Variable object get helpers because they are more
complicated than the norm. They can implicitly perform a create. They
cross the line as being too complex and large to inline since they
negatively impact size and binary test coverage.
* posix/src/condget.c, posix/src/mutexget.c: New files.
* posix/src/keycreate.c, rtems/src/eventseize.c,
score/include/rtems/score/interr.h: Rearranged source to allow more
test coverage.
* posix/src/pthreadcreate.c: Add commit.
* posix/src/pthreadinitthreads.c: Fix line length.
* posix/src/killinfo.c: Clean up and eliminate some dead code paths.
* posix/include/rtems/posix/timer.h: Include rtems/score/object.h.
* posix/Makefile.am, posix/src/kill.c, posix/src/killinfo.c: Split file
and resolved copyright information.
* posix/src/kill_r.c: New file.
* posix/src/ualarm.c: Fixed bug where iteration did not work correctly.
* posix/src/psignalunblockthread.c: Remove source that
* posix/src/psignalchecksignal.c: Make assert active during debug mode
only
* posix/src/psignal.c: Move source around to enable path testing
* posix/src/timergettime.c: Include rtems/score/timespec.h
* posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h,
posix/include/mqueue.h, posix/include/sched.h,
posix/include/semaphore.h, posix/include/rtems/posix/cancel.h,
posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c,
posix/src/cleanuppush.c, posix/src/cond.c,
posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c,
posix/src/condattrinit.c, posix/src/condattrsetpshared.c,
posix/src/condbroadcast.c, posix/src/conddefaultattributes.c,
posix/src/conddestroy.c, posix/src/condinit.c,
posix/src/condsignal.c, posix/src/condsignalsupp.c,
posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c,
posix/src/keycreate.c, posix/src/keydelete.c,
posix/src/keysetspecific.c, posix/src/mqueue.c,
posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c,
posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c,
posix/src/mqueueopen.c, posix/src/mqueuereceive.c,
posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c,
posix/src/mqueueunlink.c, posix/src/mutex.c,
posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c,
posix/src/mutextrylock.c, posix/src/mutexunlock.c,
posix/src/psignal.c, posix/src/psignalchecksignal.c,
posix/src/psignalunblockthread.c, posix/src/ptimer.c,
posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c,
posix/src/semwait.c, posix/src/setcancelstate.c,
posix/src/setcanceltype.c, posix/src/sysconf.c,
posix/src/testcancel.c: Add missing copyright statements.
* posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/timer.h, score/src/objectget.c: Split POSIX
Timer implementation into multiple files. Add obvious error checks
for NULL parameters. Attempt to reduce include files.
* posix/src/timercreate.c, posix/src/timerdelete.c,
posix/src/timergetoverrun.c, posix/src/timergettime.c,
posix/src/timerinserthelper.c, posix/src/timersettime.c,
posix/src/timertsr.c: New files.
* posix/src/ptimer1.c: Removed.
* posix/src/sleep.c, posix/src/usleep.c: Add copyright header.
* rtems/src/ratemonreportstatistics.c, rtems/src/timerserver.c:
Minor cleanup to improve testability and eliminate dead code.
* libcsupport/preinstall.am, posix/preinstall.am, rtems/Makefile.am,
rtems/preinstall.am, sapi/Makefile.am, sapi/preinstall.am,
score/Makefile.am, score/preinstall.am: Revert testing patch.
* posix/src/sched_rr_get_interval.c: Fix warning.
* posix/Makefile.am, posix/src/clockgetcpuclockid.c,
posix/src/clockgetenableattr.c, posix/src/clockgettime.c,
posix/src/devctl.c, posix/src/execl.c, posix/src/execle.c,
posix/src/execlp.c, posix/src/execv.c, posix/src/execve.c,
posix/src/execvp.c, posix/src/fork.c, posix/src/mutexinit.c,
posix/src/pthreadatfork.c, posix/src/pthreadgetcpuclockid.c,
posix/src/pthreadkill.c, posix/src/semaphorecreatesupp.c,
posix/src/sysconf.c, posix/src/wait.c, posix/src/waitpid.c: Split
files into one function per file.
* posix/src/aio_cancel.c, posix/src/aio_error.c, posix/src/aio_fsync.c,
posix/src/aio_read.c, posix/src/aio_return.c,
posix/src/aio_suspend.c, posix/src/aio_write.c,
posix/src/lio_listio.c, posix/src/sched_getparam.c,
posix/src/sched_getprioritymax.c, posix/src/sched_getprioritymin.c,
posix/src/sched_getscheduler.c, posix/src/sched_rr_get_interval.c,
posix/src/sched_setparam.c, posix/src/sched_setscheduler.c,
posix/src/sched_yield.c: New files.
* posix/src/aio.c, posix/src/sched.c, posix/src/types.c: Removed.
* libcsupport/preinstall.am, posix/preinstall.am, posix/src/aio.c,
posix/src/clockgettime.c, posix/src/clocksetenableattr.c,
posix/src/clocksettime.c, posix/src/devctl.c,
posix/src/pthreadcreate.c, posix/src/pthreadgetcpuclockid.c,
posix/src/types.c, rtems/preinstall.am, sapi/Makefile.am,
sapi/preinstall.am, score/Makefile.am, score/preinstall.am: Eliminate
POSIX_NOT_IMPLEMENTED(). Return ENOSYS instead.
* posix/src/adjtime.c: Clean up and verify against behavior documented
in GNU/Linux man page provided with Fedora 7.
* posix/preinstall.am: Revert debug patch.
* Makefile.am, configure.ac, posix/Makefile.am, wrapup/Makefile.am:
Move Ada support code that is untestable from the Standard RTEMS Test
Suite into its own directory. All code in score, posix, rtems, and
sapi should be testable by the Standard RTEMS Test Suites. It was
buried under POSIX before so this should be a clearer location
anyway.
* libgnat/.cvsignore, libgnat/Makefile.am, libgnat/ada_intrsupp.c,
libgnat/adasupp.c: New files.
* posix/src/ada_intrsupp.c, posix/src/adasupp.c: Removed.
* libcsupport/src/malloc.c, libmisc/monitor/mon-command.c,
posix/preinstall.am, posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c,
posix/src/mutexdestroy.c, posix/src/mutexinit.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/include/rtems/sptables.h,
sapi/src/exinit.c, score/include/rtems/system.h,
score/include/rtems/score/mpci.h, score/src/mpci.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* posix/Makefile.am: Restructed to move the
OBJECTS_LOCAL case to the top of the switch statement and
eliminate the fall-through return of POSIX_BOTTOM_REACHED. These
changes produced simplier assembly code and allowed for complete
test coverage. Also applied some consistency to the functions
that translate the core status codes to POSIX status codes.
* posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c,
posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspindestroy.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c,
rtems/src/timerfireafter.c, score/include/rtems/system.h,
score/include/rtems/score/coresem.h: Restructed to move the
* posix/src/mutextranslatereturncode.c,
posix/src/semaphoretranslatereturncode.c: New files.
* posix/src/mutexfromcorestatus.c: Removed.
* posix/inline/rtems/posix/priority.inl: Fix typo.
* posix/Makefile.am, posix/preinstall.am, posix/src/cancel.c,
posix/src/condsignalsupp.c, posix/src/condwaitsupp.c,
posix/src/mqueueunlink.c, posix/src/mutexattrdestroy.c,
posix/src/mutexunlock.c, posix/src/semaphorecreatesupp.c,
posix/src/semaphoredeletesupp.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/semunlink.c,
posix/src/types.c, score/cpu/powerpc/rtems/old-exceptions/cpu.h:
Remove all pretense of POSIX MP support. The support in place was
only a shell. This should make maintenance easier.
* posix/include/rtems/posix/condmp.h,
posix/include/rtems/posix/mqueuemp.h,
posix/include/rtems/posix/mutexmp.h,
posix/include/rtems/posix/pthreadmp.h,
posix/include/rtems/posix/semaphoremp.h, posix/src/condmp.c,
posix/src/mutexmp.c, posix/src/semaphoremp.c: Removed.
* posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c,
rtems/include/rtems/rtems/barrier.h,
score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c,
score/src/corerwlockrelease.c: Fixed several implementation errors.
* posix/src/mprotect.c: Update comments.
* posix/Makefile.am: Add support for Ada95 interrupt tasks. This
will require gcc 4.3 or newer.
* posix/src/ada_intrsupp.c: New file.
PR 1266/cpukit
* posix/src/keycreate.c, posix/src/keyrundestructors.c: Use API instead
of class for key indexing.
Miscellaneous changes made after a review against the POSIX spec.
* posix/src/pbarrierinit.c, posix/src/prwlockinit.c: If the caller
passes a NULL in the attributes parameter, default attributes are used.
* posix/src/prwlockdestroy.c: If there is at least one thread
waiting, do not allow deletion.
* posix/src/prwlockwrlock.c: Corrected parameter passed to the core
operation used to obtain a RWLock for writing.
* posix/src/pspinlocktranslatereturncode.c,
score/include/rtems/score/corespinlock.h,
score/src/corespinlockrelease.c: If the current thread is not the
holder of the lock, do not allow an unlock and return EPERM.
* score/src/corerwlockobtainwrite.c: Corrected to use the operation
for queueing with a timeout handler.
