Update #2514.
Set default thread processor affinity to all processors of the
pre-allocated set. This allows to constify the
_POSIX_Threads_Default_attributes.
Update #2514.
Simplify
* pthread_attr_setstack(), and
* pthread_attr_setstacksize().
Update #2514.
Update #2514.
Close #3174.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
Use the timestamps only for uptime based values. Use struct timespec
for the absolute time values (TOD).
Update #2740.
This was accidentally removed during a merge conflict by
89fc9345dea5c675f8d93546fa3c723918d3279a.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
For semaphore object pointer and object validation see
POSIX_SEMAPHORE_VALIDATE_OBJECT().
Destruction or close of a busy semaphore returns an error status. The
object is not flushed.
POSIX semaphores are now available in all configurations and no longer
Update #2514.
Update #3116.
Reduce size of pthread_once_t and make it zero-initialized.
Update #3142.
Update #3164.
Close #3153.
Close #3137.
Close #3126.
Close #3125.
Check iop reference count in close() and return -1 with errno set to
EBUSY in case the file descriptor is still in use.
Update #3132.
Update #3132.
Update #3132.
The top-level IO library structures should contain no special-case data.
Update #2859.
Since we have only one process, sharing between processes is trivial.
Close #3124.
We should only use the address used to initialize the mutex object
according to POSIX, "2.9.9 Synchronization Object Copies and Alternative
Mappings".
http://pubs.opengroup.org/onlinepubs/9699919799/functions/V2_chap02.html#tag_15_09_09
Update #3113.
Update #2132.
Update #2133.
Avoid void pointer arithmetic.
Updates #2859.
Use the libio mutex lock instead of the mmap mappings lock.
Updates #2859.
Operarations are already protected by mmap_mappings_lock.
Updates #2859.
The loop that checks if the current address is already mapped uses
the same local variable for the chanin node as the newly allocated
chain node so the allocated chain node gets over written.
Added a new local variable for the loop that checks the address
Updates #2859.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
The original CPU_COPY() support of Newlib <sys/cpuset.h> had the
parameters in the wrong order. This is fixed in Newlib since
2017-05-22.
Update #3023.
Close #3010.
Update #2859.
This version of mmap comes from early work done
on the RTL code base circa 2012.
Update #2859.
Closes #2957.
Update #2859.
Add the special thread queue name _Thread_queue_Object_name to mark
thread queues embedded in an object with identifier. Using the special
thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for
this purpose since the thread wait information and thread state are
protected by different SMP locks in separate critical sections. Remove
STATES_THREAD_QUEUE_WITH_IDENTIFIER.
Add and use _Thread_queue_Object_initialize().
Update #2858.
Update #2859.
Add POSIX shared memory manager (Shm). Includes a hook-based
approach for the backing memory storage that defaults to the
Workspace, and a test is provided using the heap. A test is
also provided for the basic use of mmap'ing a shared memory
object. This test currently fails at the mmap stage due to
no support for mmap.
