* itron/Makefile.am, itron/src/eventflags.c, itron/src/fmempool.c,
itron/src/itronintr.c, itron/src/itrontime.c, itron/src/network.c,
itron/src/port.c, itron/src/sysmgmt.c, itron/src/task.c,
itron/src/vmempool.c, posix/Makefile.am, posix/src/pthread.c,
rtems/src/taskinitusers.c, rtems/src/tasks.c,
sapi/include/confdefs.h, sapi/src/io.c: Various modification to
reduce executable size. Most were refactoring of files. Split ITRON
API files. Implemented mechanism to avoid initialization task/thread
loop being linked in when that style of task initialization was not
being used.
* itron/src/acp_por.c, itron/src/act_cyc.c, itron/src/cal_por.c,
itron/src/chg_iXX.c, itron/src/clr_flg.c, itron/src/cre_flg.c,
itron/src/cre_mpf.c, itron/src/cre_mpl.c, itron/src/cre_por.c,
itron/src/def_alm.c, itron/src/def_cyc.c, itron/src/def_exc.c,
itron/src/def_int.c, itron/src/def_svc.c, itron/src/del_flg.c,
itron/src/del_mpf.c, itron/src/del_mpl.c, itron/src/del_por.c,
itron/src/dis_int.c, itron/src/dly_tsk.c, itron/src/ena_int.c,
itron/src/fwd_por.c, itron/src/get_blf.c, itron/src/get_blk.c,
itron/src/get_tim.c, itron/src/get_ver.c, itron/src/itroninittasks.c,
itron/src/loc_cpu.c, itron/src/nget_nod.c, itron/src/nget_ver.c,
itron/src/nrea_dat.c, itron/src/nwri_dat.c, itron/src/pacp_por.c,
itron/src/pcal_por.c, itron/src/pget_blf.c, itron/src/pget_blk.c,
itron/src/pol_flg.c, itron/src/ref_alm.c, itron/src/ref_cfg.c,
itron/src/ref_cyc.c, itron/src/ref_flg.c, itron/src/ref_iXX.c,
itron/src/ref_mpf.c, itron/src/ref_mpl.c, itron/src/ref_por.c,
itron/src/ref_sys.c, itron/src/rel_blf.c, itron/src/rel_blk.c,
itron/src/ret_int.c, itron/src/ret_tmr.c, itron/src/ret_wup.c,
itron/src/rpl_rdv.c, itron/src/set_flg.c, itron/src/set_tim.c,
itron/src/tacp_por.c, itron/src/tcal_por.c, itron/src/tget_blf.c,
itron/src/tget_blk.c, itron/src/twai_flg.c, itron/src/unl_cpu.c,
itron/src/wai_flg.c, posix/src/pthreadinitthreads.c: New files.
* posix/src/usleep.c, libcsupport/src/readlink.c:
Update API to SUSv3.
* posix/Makefile.am: Unconditionally build src/sleep.c,
src/usleep.c.
* posix/src/nanosleep.c: Include rtems/score/timespec.h instead of
rtems/posix/time.h.
* posix/Makefile.am: Fix formatting.
* posix/Makefile.am, posix/include/rtems/posix/time.h,
posix/src/adjtime.c, posix/src/alarm.c, posix/src/clockgetres.c,
posix/src/condtimedwait.c, posix/src/mqueuetimedreceive.c,
posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c,
posix/src/nanosleep.c, posix/src/posixtimespecabsolutetimeout.c,
posix/src/pthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c,
posix/src/sched.c, posix/src/semtimedwait.c,
posix/src/sigtimedwait.c, posix/src/ualarm.c,
rtems/src/clocktodtoseconds.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl, score/src/coretod.c,
score/src/coretodget.c, score/src/coretodgetuptime.c,
score/src/coretodset.c, score/src/coretodtickle.c: Provide timespec
manipulation routines in the SuperCore. Use them everywhere possible.
This lead to significant cleanup in the API routines and eliminated
some of the same code from the POSIX API. At this point, the
SuperCore keeps time in POSIX timespec format properly from 1970. You
just cannot set it before 1988 in keeping with RTEMS traditional
behavior.
* score/include/rtems/score/timespec.h, score/src/timespecaddto.c,
score/src/timespecfromticks.c, score/src/timespecisvalid.c,
score/src/timespeclessthan.c, score/src/timespecsubtract.c,
score/src/timespectoticks.c: New files.
* posix/src/posixintervaltotimespec.c,
posix/src/posixtimespecsubtract.c,
posix/src/posixtimespectointerval.c: Removed.
* posix/Makefile.am, score/src/objectgetnoprotection.c: Eliminate some
dead code.
* posix/src/time.c: Removed.
* posix/include/rtems/posix/timer.h, posix/src/alarm.c,
posix/src/posixtimespectointerval.c, posix/src/ptimer1.c,
posix/src/sysconf.c, posix/src/ualarm.c, rtems/src/clockget.c,
rtems/src/clocktodvalidate.c, score/include/rtems/score/tod.h,
score/inline/rtems/score/tod.inl, score/src/coretod.c: Eliminate
TOD_Ticks_per_second variable.
* itron/src/itrontime.c, libcsupport/src/__gettod.c,
posix/src/clockgettime.c, posix/src/clocksettime.c,
posix/src/nanosleep.c, posix/src/posixtimespecsubtract.c,
posix/src/sleep.c, rtems/Makefile.am,
rtems/include/rtems/rtems/clock.h, rtems/include/rtems/rtems/timer.h,
rtems/include/rtems/rtems/types.h, rtems/src/clockget.c,
rtems/src/clockset.c, rtems/src/clocktodtoseconds.c,
rtems/src/clocktodvalidate.c, rtems/src/taskwakewhen.c,
score/Makefile.am, score/include/rtems/score/tod.h,
score/src/coretodset.c: Convert from Classic API style TOD_Control as
fundamental time structure to POSIX struct timespec. Add
clock_get_uptime().
* rtems/src/clockgetuptime.c, score/src/coretodget.c,
score/src/coretodgetuptime.c: New files.
* score/src/coretodtickle.c, score/src/coretodtoseconds.c,
score/src/coretodvalidate.c: Removed.
PR 1231/cpukit
* posix/src/adasupp.c, posix/src/clockgetcpuclockid.c,
posix/src/clockgetenableattr.c, posix/src/clockgetres.c,
posix/src/clockgettime.c, posix/src/clocksetenableattr.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c,
posix/src/mutexlocksupp.c, posix/src/mutexmp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c,
posix/src/mutextrylock.c, posix/src/mutexunlock.c,
posix/src/nanosleep.c, posix/src/posixintervaltotimespec.c,
posix/src/psignalunblockthread.c, posix/src/ptimer.c,
posix/src/ptimer1.c, posix/src/sched.c, posix/src/time.c: Remove
unneeded includes of assert.h
PR 1221/cpukit
* posix/src/pthreadequal.c: Fix critical section nesting.
* posix/src/sysconf.c: Add support for _SC_PAGESIZE (PR 1215).
* posix/src/mqueuesendsupp.c: Remove cast to make broken const cast
visible.
* posix/include/aio.h: s/aoi_lio_opcode/aio_lio_opcode/
(BZ 1203).
* posix/src/prwlockunlock.c, rtems/Makefile.am,
rtems/src/barrierrelease.c, rtems/src/barrierwait.c,
score/src/corerwlockobtainread.c, score/src/corerwlockrelease.c:
Complete implementation of barrier as the rest of the test code is
now implemented. Also add blocking code to rwlock.
* posix/src/semtimedwait.c: Used wrong constant for blocking with bad
timeout value.
* posix/src/semtimedwait.c: Reverse accidentally included
semtimedwait.c.
* posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/semtimedwait.c: Correct indexing of key data to use api and
index NOT class and index. Class is always 1.
* posix/Makefile.am: Add file missed in previous commit.
* posix/src/posixtimespecabsolutetimeout.c: New file.
* libcsupport/src/termios.c, posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/config.h, posix/include/rtems/posix/time.h,
sapi/src/posixapi.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/threadq.h,
score/src/corerwlockobtainread.c, score/src/threadqenqueue.c,
score/src/threadqtimeout.c: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/src/pbarrier.c, posix/src/pbarrierdestroy.c,
posix/src/pbarrierinit.c, posix/src/pbarriertranslatereturncode.c,
posix/src/pbarrierwait.c, posix/src/prwlock.c,
posix/src/prwlockdestroy.c, posix/src/prwlockinit.c,
posix/src/prwlockrdlock.c, posix/src/prwlocktimedrdlock.c,
posix/src/prwlocktimedwrlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspin.c,
posix/src/pspindestroy.c, posix/src/pspininit.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c: New files.
PR 841/rtems
* itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c,
posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c,
posix/src/semwait.c, rtems/src/semobtain.c,
rtems/src/semtranslatereturncode.c,
score/include/rtems/score/coresem.h, score/src/coresemseize.c: Make
sem_timedwait more conformant to Open Group specification.
* configure.ac, itron/Makefile.am, itron/preinstall.am,
posix/Makefile.am, posix/preinstall.am, rtems/Makefile.am,
rtems/preinstall.am, sapi/Makefile.am, sapi/preinstall.am,
score/Makefile.am, score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/thread.h, score/src/chain.c,
score/src/coremutexseize.c, score/src/threadget.c: Remove all macro
implementations and use only the static inline. Static inline
functions are now well supported so there is no reason for duplicate
maintenance.
* itron/macros/rtems/itron/eventflags.inl,
itron/macros/rtems/itron/fmempool.inl,
itron/macros/rtems/itron/intr.inl, itron/macros/rtems/itron/mbox.inl,
itron/macros/rtems/itron/msgbuffer.inl,
itron/macros/rtems/itron/network.inl,
itron/macros/rtems/itron/port.inl,
itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/sysmgmt.inl,
itron/macros/rtems/itron/task.inl, itron/macros/rtems/itron/time.inl,
itron/macros/rtems/itron/vmempool.inl,
posix/macros/rtems/posix/cond.inl, posix/macros/rtems/posix/key.inl,
posix/macros/rtems/posix/mqueue.inl,
posix/macros/rtems/posix/mutex.inl,
posix/macros/rtems/posix/priority.inl,
posix/macros/rtems/posix/pthread.inl,
posix/macros/rtems/posix/semaphore.inl,
posix/macros/rtems/posix/timer.inl, rtems/macros/rtems/rtems/asr.inl,
rtems/macros/rtems/rtems/attr.inl,
rtems/macros/rtems/rtems/barrier.inl,
rtems/macros/rtems/rtems/dpmem.inl,
rtems/macros/rtems/rtems/event.inl,
rtems/macros/rtems/rtems/eventset.inl,
rtems/macros/rtems/rtems/message.inl,
rtems/macros/rtems/rtems/modes.inl,
rtems/macros/rtems/rtems/options.inl,
rtems/macros/rtems/rtems/part.inl,
rtems/macros/rtems/rtems/ratemon.inl,
rtems/macros/rtems/rtems/region.inl,
rtems/macros/rtems/rtems/sem.inl,
rtems/macros/rtems/rtems/status.inl,
rtems/macros/rtems/rtems/support.inl,
rtems/macros/rtems/rtems/tasks.inl,
rtems/macros/rtems/rtems/timer.inl, sapi/macros/rtems/extension.inl,
score/macros/README, score/macros/rtems/score/address.inl,
score/macros/rtems/score/chain.inl,
score/macros/rtems/score/corebarrier.inl,
score/macros/rtems/score/coremsg.inl,
score/macros/rtems/score/coremutex.inl,
score/macros/rtems/score/corerwlock.inl,
score/macros/rtems/score/coresem.inl,
score/macros/rtems/score/corespinlock.inl,
score/macros/rtems/score/heap.inl, score/macros/rtems/score/isr.inl,
score/macros/rtems/score/mppkt.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/objectmp.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/stack.inl,
score/macros/rtems/score/states.inl,
score/macros/rtems/score/sysstate.inl,
score/macros/rtems/score/thread.inl,
score/macros/rtems/score/threadmp.inl,
score/macros/rtems/score/tod.inl,
score/macros/rtems/score/tqdata.inl,
score/macros/rtems/score/userext.inl,
score/macros/rtems/score/watchdog.inl,
score/macros/rtems/score/wkspace.inl: Removed.
Add missing #include <limits.h>.
* posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/timer.h, posix/src/ptimer.c,
posix/src/ptimer1.c, sapi/src/posixapi.c,
score/include/rtems/score/object.h:
* itron/src/trcv_mbf.c, posix/src/semopen.c,
rtems/src/taskvariableadd.c, score/macros/rtems/score/heap.inl: Fix
warnings.
* posix/inline/rtems/posix/mutex.inl,
posix/inline/rtems/posix/timer.inl,
posix/macros/rtems/posix/timer.inl: Fix warnings.
* itron/macros/rtems/itron/semaphore.inl,
itron/macros/rtems/itron/task.inl: Fix warnings.
* posix/macros/rtems/posix/cond.inl: Fix typo.
* score/macros/rtems/score/heap.inl: Fix missed type change.
* posix/inline/rtems/posix/cond.inl, posix/macros/rtems/posix/cond.inl,
posix/src/conddestroy.c: Remove warnings.
* posix/include/intr.h, posix/include/rtems/posix/intr.h
posix/inline/rtems/posix/intr.inl.
posix/macros/rtems/posix/intr.inl, posix/src/intr.c:
Remove (Unused, dead).
* posix/Makefile.am: Reflect changes above. Rework.
* posix/Makefile.am: Build devctl.
