path: root/cpukit/posix (follow)
* 2002-02-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-166-12/+20
| | | | | | | | | * src/getegid.c: Add #include <rtems/userenv.h>. Remove #include <rtems/libio_.h>. * src/geteuid.c: Ditto. * src/getgid.c: Ditto. * src/getlogin.c: Ditto. * src/getuid.c: Ditto.
* 2001-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-162-1/+6
| | | | | * inline/rtems/posix/mutex.inl (_POSIX_Mutex_Get_support): Corrected name of routine in header.
* 2002-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-071-0/+5
| | | | | * optman/, optman/.cvsignore, optman/Makefile.am: Removed entire contents of optman/ directory since it has been moved.
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-063-1/+7
| | | | | * configure.ac: AC_CONFIG_SRCDIR([src/pthreads.c]) * src/psignal.c: #include <string.h>.
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-0437-108/+109
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one. * src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one. * src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one. * src/killinfo.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one. * src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one. * src/sched.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semclose.c: Apply rtems_set_errno_and_return_minus_one. * src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one. * src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one. * src/seminit.c: Apply rtems_set_errno_and_return_minus_one. * src/semopen.c: Apply rtems_set_errno_and_return_minus_one. * src/sempost.c: Apply rtems_set_errno_and_return_minus_one. * src/semunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/setpgid.c: Apply rtems_set_errno_and_return_minus_one. * src/setsid.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaction.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigismember.c: Apply rtems_set_errno_and_return_minus_one. * src/sigpending.c: Apply rtems_set_errno_and_return_minus_one. * src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one. * src/utsname.c: Apply rtems_set_errno_and_return_minus_one.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-043-2/+6
| | | | | * configure.ac: Remove optman/Makefile from CONFIG_FILES. * Makefile.am: Remove optman from SUBDIRS.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-192-1/+6
| | | | | * optman/Makefile.am: Add multilib support. Remove ASM4FLAGS. * src/Makefile.am: Add multilib support.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-165-21/+101
| | | | | | | | | | | | | | * include/sys/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/rtems/posix/Makefile.am: Remove. * include/Makefile.am: Handle subdirs. * inline/rtems/Makefile.am: Remove. * inline/rtems/posix/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs. * macros/rtems/Makefile.am: Remove. * macros/rtems/posix/Makefile.am: Remove. * macros/Makefile.am: Handle subdirs. * configure.ac: Reflect changes above.
* 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-113-0/+74
* 2001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-283-2/+6
| | | | * src/mqueueopen.c, src/semopen.c: Clarify type on va_arg.
* 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-272-1/+9
| | | | | | | | * include/sys/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/posix/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-242-1/+6
| | | | | * optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5 happy. * src/Makefile.am: Adapt INCLUDES to make automake-1.5 happy.
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-132-1/+5
| | | | * src/sysconf.c: Fix typo syntax error accidentally committed.
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-135-5/+67
| | | | | | | | | * src/mprotect.c: New file. Stub required by some gcc's to pass tests. In particular, about 350 ACATS tests fail if this is not present. * src/getpagesize.c: Ditto. * src/sysconf.c: Addition of Solaris value for _SC_STACK_PROT required to pass about 350 ACATS test cases. * src/Makefile.am: Added new files.
* 2001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-302-1/+7
| | | | * macros/rtems/posix/mqueue.inl: Add cast so negation works.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-161-0/+5
| | | | | * src/mqueuesendsupp.c: Account for possibly blocking during the core send operation.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-161-1/+12
* 2001-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-092-3/+11
| | | | | | | * src/mqueuesendsupp.c: Unblocking message queue operations should NOT use _Thread_Executing for return status since it is permissible to invoke message send operations from an ISR. This was reported by Suvrat Gupta <suvrat@utstar.com>.
* 2000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill2001-05-246-1/+43
| | | | | * src/getegid.c, src/geteuid.c, src/getgid.c, src/getlogin.c, src/getuid.c: Now save their values in private user environment.
* 2001-04-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-071-0/+4
| | | | * configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* 2001-03-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-191-0/+4
| | | | * sys/utsname.h: Added C++ wrapper.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-052-8/+11
| | | | | | | * include/Makefile.am, include/rtems/posix/Makefile.am, include/sys/Makefile.am, inline/rtems/posix/Makefile.am, macros/rtems/posix/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-24182-0/+689
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* 2001-01-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-232-1/+5
| | | | * src/alarm.c: Eliminated use of C++ style comments.
* 2001-01-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-222-2/+11
| | | | | | * src/clockgetres.c: Fixed match problem. We are not converting an interval to a timespec -- it is actually a real number of microseconds.
* 2001-01-22 Michael Hamel <mhamel@adi.co.nz>Joel Sherrill2001-01-228-11/+19
| | | | | | | | * include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl, src/ptimer1.c, include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl, src/alarm.c, src/ptimer1.c, src/semaphorenametoid.c, src/semopen.c, src/semunlink.c: Modifications to make CodeWarrior happy.
* 2001-01-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-122-1/+16
| | | | * src/README.mqueue: Enhanced example.
* 2000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-192-4/+12
| | | | | * src/pthreadgetschedparam.c: Do not set output parameters if the pointers are NULL.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-062-0/+7
| | | | | * src/pthreadgetcpuclockid.c: Add include of <rtems/system.h> to eliminate warning.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-012-0/+8
| | | | | | * include/rtems/posix/cond.h: #if 0'ed out prototype of _POSIX_Condition_variables_Get to avoid conflict with macro implementation.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-0111-0/+566
| | | | | | | | | | | | | * Added macro support to POSIX API. This is known to compile. * macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/priority.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl: New files. * configure.in: Removed error check for enabling macros. * rtems/posix/mutex.h: #if 0'ed out prototypes for inlined routines since you cannot have prototypes for macros. * macros/rtems/posix/Makefile.am: Added files.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-302-1/+6
| | | | * inline/rtems/posix/mqueue.inl: Removed explicit dependency on abs().
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-0/+19
| | | | * src/sysconf.c: Add support for _SC_CLK_TCK and _SC_OPEN_MAX.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-1/+5
| | | | | * configure.in: Cleanup comments. * bsp_specs: Add qnolinkcmds.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-3111-10/+28
| | | | | | | | | | | | | | | | | | | * include/Makefile.am: Updated to reflect files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * include/unistd.h: Removed. Now use newlib's. * include/rtems/posix/mqueue.h: Add include of <signal.h>. * include/rtems/posix/threadsup.h: Add include of <sys/signal.h> * src/execv.c: Corrected prototype to agree with newlib. * src/execve.c: Corrected prototype to agree with newlib. * src/execvp.c: Corrected prototype to agree with newlib. * src/psignal.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. * src/pthreadkill.c: Added include of <signal.h>. * src/sigaction.c: Added include of <signal.h>. * src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. *
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * src/Makefile.am, optman/Makefile.am: Include compile.am.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-3077-76/+82
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-254-43/+117
| | | | | | | | * inline/rtems/posix/timer.inl, include/rtems/posix/timer.h, inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the style of src/ptimer1.c. Continued effort to make the POSIX Timer implementation match that of other managers. Added data structures required to use SuperCore Object Handler.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-152-12/+5
| | | | * src/ptimer1.c: Minor formatting fixes.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-154-47/+26
| | | | | | | | * src/ptimer1.c: Removed unused routine PRINT_ERRNO_S. * src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S and used structure copy instead. * src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control. * include/rtems/posix/timer.h: Ditto.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-152-48/+25
| | | | | * posix/src/ptimer1.c: Switched to using set_errno_and_return_minus_one() to ensure that errno was always set.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-152-10/+10
| | | | | * posix/src/ptimer1.c (timer_settime): Converted use of rtems_clock_get to use SuperCore _TOD_Current variable.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-1/+6
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Fixed problem reported by Victor V. Vengerov <Victor.Vengerov@oktet.ru>Joel Sherrill2000-07-071-1/+7
| | | | | | where alarm() did not correctly account for the watchdog start_time and stop_time fields being based on ticks not seconds. This resulted in alarm() returning a bogus number of seconds remaining.
* Switched to using _POSIX_Mutex_Get_interrupt_disable to improve performance.Joel Sherrill2000-07-061-3/+4
* Added support for converting a mutex id to a pointer and returningJoel Sherrill2000-07-061-21/+39
| | | | with interrupts disabled.
