* src/ptimer1.c: Removed unused routine PRINT_ERRNO_S.
* src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S
and used structure copy instead.
* src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control.
* include/rtems/posix/timer.h: Ditto.
* posix/src/ptimer1.c: Switched to using set_errno_and_return_minus_one()
to ensure that errno was always set.
* posix/src/ptimer1.c (timer_settime): Converted use of rtems_clock_get
to use SuperCore _TOD_Current variable.
where alarm() did not correctly account for the watchdog start_time
and stop_time fields being based on ticks not seconds. This resulted
in alarm() returning a bogus number of seconds remaining.
with interrupts disabled.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
were done by Joel.
Added correct include file.
+ Added messsage size check
+ Debugged and yellowed out routine
+ Yellow line tested source.
+ Removed extra flag attribute from message queue structure.
+ Yellow-lined all posix message queue routines.
queues as well as the messages.
was pending. Reported by Wayne Bullaughey <wayneb@cacdsp.com>.
for APIs that are not configured. This resulted in weird behavior
when ITRON was disabled on some targets.
+ Added priority validation
+ Changed to call correct core routine.
+ Added priority conversion
+ Resolved return type problems.
+ Added ability to return message priority from the core.
+ Added oflag tracking.
+ Added checks for valid attribute maxmsg and msgsize
+ Added check for ENAMETOOLONG
Addtional major bugs:
+ Cleaned up code.
+ Corrected enable/disable of dispatch.
