Avoid void pointer arithmetic.
Updates #2859.
Use the libio mutex lock instead of the mmap mappings lock.
Updates #2859.
Operarations are already protected by mmap_mappings_lock.
Updates #2859.
The loop that checks if the current address is already mapped uses
the same local variable for the chanin node as the newly allocated
chain node so the allocated chain node gets over written.
Added a new local variable for the loop that checks the address
Updates #2859.
Added a mmap file handler to struct _rtems_filesystem_file_handlers_r.
Updated each file handler object to support the default mmap handler.
Updated mmap() to call the mmap handler for MAP_SHARED.
Added a mmap file handler for shm
Added support for MAP_ANON in mmap().
Updates #2859
The original CPU_COPY() support of Newlib <sys/cpuset.h> had the
parameters in the wrong order. This is fixed in Newlib since
2017-05-22.
Update #3023.
Close #3010.
Update #2859.
This version of mmap comes from early work done
on the RTL code base circa 2012.
Update #2859.
Closes #2957.
Update #2859.
Add the special thread queue name _Thread_queue_Object_name to mark
thread queues embedded in an object with identifier. Using the special
thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for
this purpose since the thread wait information and thread state are
protected by different SMP locks in separate critical sections. Remove
STATES_THREAD_QUEUE_WITH_IDENTIFIER.
Add and use _Thread_queue_Object_initialize().
Update #2858.
Update #2859.
Add POSIX shared memory manager (Shm). Includes a hook-based
approach for the backing memory storage that defaults to the
Workspace, and a test is provided using the heap. A test is
also provided for the basic use of mmap'ing a shared memory
object. This test currently fails at the mmap stage due to
no support for mmap.
Add pthread_getname_np() and pthread_setname_np().
Update #2858.
Replace STATES_DELAYING with STATES_WAITING_FOR_TIME.
There is no need for separate timeout thread states. The
Thread_Control::Timer::header and Watchdog_Control::cpu members can be
used to figure out the kind of timeout.
Avoid to change the CPU of the watchdog right in the middle of the
critical section. This would corrupt the watchdog lock states.
Add thread state bit to identify thread queues that are embedded in an
Update #2825.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Initialize thread queue context early preferably outside the critical
section.
Remove implicit _Thread_queue_Context_initialize() from
_Thread_Wait_acquire().
Update #2674.
Initialize the thread queue context with invalid data in debug
configurations to catch missing set up steps.
Move thread state for _Thread_queue_Enqueue() to the thread queue
context. This reduces the parameter count of _Thread_queue_Enqueue()
from five to four (ARM for example has only four function parameter
registers). Since the thread state is used after several function calls
inside _Thread_queue_Enqueue() this parameter was saved on the stack
previously.
Update #2674.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
Delete unused _Thread_queue_Enqueue() and rename
_Thread_queue_Enqueue_critical() to _Thread_queue_Enqueue().
Replace the expected thread dispatch disable level with a thread queue
enqueue callout. This enables the use of _Thread_Dispatch_direct() in
the thread queue enqueue procedure. This avoids impossible exection
paths, e.g. Per_CPU_Control::dispatch_necessary is always true.
This function is useful for operations which synchronously block, e.g.
self restart, self deletion, yield, sleep. It helps to detect if these
operations are called in the wrong context. Since the thread dispatch
necessary indicator is not used, this is more robust in some SMP
situations.
Update #2751.
The POSIX cleanup list must be proteced from asynchronous thread
deletion. Here local interrupt disable is sufficient.
Use right object class.
Replace Thread_Scheduler_control::control and
Thread_Scheduler_control::own_control with new
Thread_Scheduler_control::home.
Update #2556.
Do not overwrite timer interval with initial interval in
_POSIX_Timer_Insert().
Close #2798.
Update #2798.
Use the Thread_Control::resource_count for the no protocol mutexes.
Merge the no protocol and priority inherit CORE mutex seize/surrender
operations.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Avoid direct access to thread internal data fields.
