* | Changed all EFAULTs to EINVALs | Mark Johannes | 1996-08-19 | 1 | -7/+14 | |
* | pthread_mutex_init: added error messages for NULL mutex and EBUSY | Mark Johannes | 1996-08-19 | 1 | -6/+22 | |
* | changed ENOMEM error message | Mark Johannes | 1996-08-15 | 1 | -1/+4 | |
* | clock_gettime: changed assert condition to a standard error code | Joel Sherrill | 1996-08-15 | 1 | -2/+3 | |
| | | | | clock_getres: now checking for a null pointer being passed in | |||||
* | sched_rr_get_interval: converted assert condition into a standard error | Joel Sherrill | 1996-08-15 | 1 | -1/+5 | |
| | | | | code and added check for a NULL interval being passed in. | |||||
* | added constant to indicate there is no mutex associated with this | Joel Sherrill | 1996-08-15 | 1 | -0/+7 | |
| | | | | condition variable | |||||
* | pthread_kill: fixed the move of SIG_IGN not SA_SIGINFO | Mark Johannes | 1996-08-15 | 1 | -4/+6 | |
* | pthread_kill: moved check for SA_SIGINFO to allow for validation of all | Mark Johannes | 1996-08-15 | 1 | -7/+7 | |
| | | | | parameters. Also changed returns to macro of -1 and errno set. | |||||
* | fixed typo for NOTSUP -> ENOTSUP | Mark Johannes | 1996-08-15 | 1 | -13/+12 | |
* | commented of ENOTSUP until fixed in newlib | Mark Johannes | 1996-08-14 | 1 | -0/+1 | |
* | pthread_cond_timedwait: added error cases for abstime | Mark Johannes | 1996-08-14 | 1 | -0/+11 | |
* | pthread_cond_destroy: added enable dispatch to EBUSY case | Mark Johannes | 1996-08-13 | 1 | -1/+3 | |
* | pthread_codn_destroy: EBUSY case moved and uses Thread_queue_First | Mark Johannes | 1996-08-13 | 1 | -3/+3 | |
* | pthread_cond_destroy: EBUSY case now uses Thread_queue_First | Mark Johannes | 1996-08-13 | 1 | -1/+1 | |
* | deleted a line for spacing correction | Joel Sherrill | 1996-08-13 | 1 | -1/+0 | |
* | _POSIX_Condition_variables_Wait_support: changed status of lock and unlock ↵ | Mark Johannes | 1996-08-13 | 1 | -2/+2 | |
| | | | | to return EINVAL is there is an error | |||||
* | _POSIX_Condition_variables_Wait_support: fixed the timeout sequence. | Mark Johannes | 1996-08-13 | 1 | -7/+25 | |
* | removed errors for TOD not set yet. | Joel Sherrill | 1996-08-13 | 1 | -9/+9 | |
| | | | | made nanosleep return -1/EINTR for being interrupted for a signal. | |||||
* | clock_getres: added error check for NULL pointer being passed in. | Joel Sherrill | 1996-08-12 | 1 | -0/+3 | |
* | nanosleep: verify rqtp parameter is non-NULL. | Joel Sherrill | 1996-08-12 | 1 | -0/+7 | |
| | | | | nanosleep: return 0 time remaining for a yield case. | |||||
* | time: It is not an error if the TOD is not set. | Joel Sherrill | 1996-08-12 | 1 | -2/+4 | |
* | Wait_support: removed the calls to mutex core to posix status codes | Mark Johannes | 1996-08-12 | 1 | -2/+2 | |
* | mutex.h: removes the promotion of core status code to POSXI status codes | Mark Johannes | 1996-08-12 | 1 | -12/+0 | |
* | fixed spacing ; moved a dummy MP support routine to clean up printout. | Joel Sherrill | 1996-08-12 | 1 | -9/+10 | |
* | _POSIX_Mutex_Get: made null id an error | Joel Sherrill | 1996-08-12 | 1 | -0/+5 | |
* | pthread_mutex_getprioceiling: added error check for null old_ceiling | Joel Sherrill | 1996-08-12 | 1 | -2/+4 | |
| | | | | | pthread_mutex_setprioceiling: added comment indicating an error was impossible to generate. | |||||
* | mutex.h: promoted out _POSIX_Mutex_From_core_mutex_status | Mark Johannes | 1996-08-12 | 1 | -0/+12 | |
* | _POSIX_Condition_variables_Wait_support: added ↵ | Mark Johannes | 1996-08-12 | 1 | -4/+5 | |
| | | | | _POSIX_Mutex_From_core_mutex_status for the two calls to the mutex manager | |||||
* | _POSIX_Condition_variables_Signal_support: added setting mutex back to NULL | Mark Johannes | 1996-08-12 | 1 | -5/+7 | |
| | | | | | | if the queue has been emptied of waiting tasks. _POSIX_Condition_variables_Wait_support: added error check for different mutexesfor the same condition variable. Also added _Thread_queue_Enter_critical_section | |||||
* | pthread_mutexattr_setprioceiling: fixed typo | Joel Sherrill | 1996-08-12 | 1 | -1/+1 | |
* | pthread_mutexattr_setprioceiling: valid priority ceiling check looked at | Joel Sherrill | 1996-08-12 | 1 | -1/+1 | |
| | | | | value in attribute structure instead of passed in priority | |||||
* | pthread_mutexattr_getprotocol: added check for attribute structure being | Joel Sherrill | 1996-08-12 | 1 | -1/+1 | |
| | | | | initialized | |||||
* | added code to catch NULL pointers for return values passed to get routines | Joel Sherrill | 1996-08-09 | 1 | -6/+9 | |
* | sched_yield: was not invoking the dispatcher. | Joel Sherrill | 1996-08-09 | 1 | -1/+3 | |
* | merged remote object id and invalid id error cases. | Joel Sherrill | 1996-08-09 | 1 | -6/+3 | |
* | _POSIX_signals_Clear_signals: added this routine | Mark Johannes | 1996-08-08 | 1 | -12/+36 | |
| | | | | _POSIX_signals_Get_highest: changed initial starting signal to SIGHUP, still needs SIGFIRSTNOTRT | |||||
* | added ss_high_priority field to support sporadic server. | Joel Sherrill | 1996-08-08 | 1 | -0/+1 | |
* | sporadic server debugged and working. This required minor changes in all | Joel Sherrill | 1996-08-07 | 1 | -20/+40 | |
| | | | | sporadic server related routines. | |||||
* | _POSIX_Mutex_From_core_mutex_status: added priority ceiling violation case | Mark Johannes | 1996-08-07 | 1 | -0/+2 | |
* | _POSIX_Threads_Delete_extension: reorder to eliminate use of local pointer | Joel Sherrill | 1996-08-06 | 1 | -6/+9 | |
| | | | | | | variable before set. pthread_join: using local variable so user can pass NULL pointer as argument | |||||
* | POSIX_Mutex_Default_attributes: changed prio_ceiling to maximum priority | Mark Johannes | 1996-08-06 | 1 | -1/+2 | |
* | pthread_getspecific: use local variable so references to tcb are completed | Joel Sherrill | 1996-08-06 | 1 | -1/+6 | |
| | | | | before enabling dispatching | |||||
* | added page delimiters for comment blocks | Joel Sherrill | 1996-08-01 | 2 | -11/+25 | |
* | Fixed default vectors initialization, sigaction which had a redundant | Mark Johannes | 1996-07-15 | 1 | -42/+64 | |
| | | | | if clause for DFT action. | |||||
* | basic test cases passed | Joel Sherrill | 1996-07-04 | 1 | -4/+35 | |
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 16 | -64/+64 | |
* | *** empty log message *** | Joel Sherrill | 1996-07-02 | 1 | -1/+22 | |
* | initial modifications to support sigtimedwait. | Joel Sherrill | 1996-06-15 | 1 | -9/+30 | |
* | fields for init threads stuff said tasks. | Joel Sherrill | 1996-06-14 | 1 | -2/+2 | |
* | sigtimedwait passes initial test cases of timeout and simple satisfaction. | Mark Johannes | 1996-06-13 | 1 | -1/+5 | |
