* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 1 | -0/+51 |
* | updates to fix typos | Joel Sherrill | 1996-05-24 | 1 | -13/+7 |
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 13 | -7/+23 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 1 | -1/+1 |
| | | | | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. The removed files were moved to newlib as they were duplicates of files already included there. | ||||
* | fixed typo | Joel Sherrill | 1996-05-10 | 1 | -1/+1 |
* | added correct use of _Thread_queue_Enter_critical_section | Joel Sherrill | 1995-12-08 | 1 | -0/+1 |
* | Insert mode argument to _Watchdog_Insert removed. Now are watchdog timers | Joel Sherrill | 1995-12-01 | 1 | -5/+1 |
| | | | | are automatically activated upon insertion. | ||||
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -2/+1 |
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 23 | -0/+28 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 44 | -0/+7502 |
