path: root/cpukit/posix (follow)
* 2000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill2001-05-246-1/+43
| | | | | * src/getegid.c, src/geteuid.c, src/getgid.c, src/getlogin.c, src/getuid.c: Now save their values in private user environment.
* 2001-04-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-071-0/+4
| | | | * configure.in: Add [-ansi -fasm] to RTEMS_PROG_CC_FOR_TARGET.
* 2001-03-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-03-191-0/+4
| | | | * sys/utsname.h: Added C++ wrapper.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-052-8/+11
| | | | | | | * include/Makefile.am, include/rtems/posix/Makefile.am, include/sys/Makefile.am, inline/rtems/posix/Makefile.am, macros/rtems/posix/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-24182-0/+689
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* 2001-01-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-232-1/+5
| | | | * src/alarm.c: Eliminated use of C++ style comments.
* 2001-01-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-222-2/+11
| | | | | | * src/clockgetres.c: Fixed match problem. We are not converting an interval to a timespec -- it is actually a real number of microseconds.
* 2001-01-22 Michael Hamel <mhamel@adi.co.nz>Joel Sherrill2001-01-228-11/+19
| | | | | | | | * include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl, src/ptimer1.c, include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl, src/alarm.c, src/ptimer1.c, src/semaphorenametoid.c, src/semopen.c, src/semunlink.c: Modifications to make CodeWarrior happy.
* 2001-01-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-122-1/+16
| | | | * src/README.mqueue: Enhanced example.
* 2000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-192-4/+12
| | | | | * src/pthreadgetschedparam.c: Do not set output parameters if the pointers are NULL.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-062-0/+7
| | | | | * src/pthreadgetcpuclockid.c: Add include of <rtems/system.h> to eliminate warning.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-012-0/+8
| | | | | | * include/rtems/posix/cond.h: #if 0'ed out prototype of _POSIX_Condition_variables_Get to avoid conflict with macro implementation.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-0111-0/+566
| | | | | | | | | | | | | * Added macro support to POSIX API. This is known to compile. * macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/priority.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl: New files. * configure.in: Removed error check for enabling macros. * rtems/posix/mutex.h: #if 0'ed out prototypes for inlined routines since you cannot have prototypes for macros. * macros/rtems/posix/Makefile.am: Added files.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-302-1/+6
| | | | * inline/rtems/posix/mqueue.inl: Removed explicit dependency on abs().
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-272-0/+19
| | | | * src/sysconf.c: Add support for _SC_CLK_TCK and _SC_OPEN_MAX.
* 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-092-1/+5
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-022-1/+5
* 2000-10-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-311-1/+5
| | | | | * configure.in: Cleanup comments. * bsp_specs: Add qnolinkcmds.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-3111-10/+28
| | | | | | | | | | | | | | | | | | | * include/Makefile.am: Updated to reflect files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * include/unistd.h: Removed. Now use newlib's. * include/rtems/posix/mqueue.h: Add include of <signal.h>. * include/rtems/posix/threadsup.h: Add include of <sys/signal.h> * src/execv.c: Corrected prototype to agree with newlib. * src/execve.c: Corrected prototype to agree with newlib. * src/execvp.c: Corrected prototype to agree with newlib. * src/psignal.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. * src/pthreadkill.c: Added include of <signal.h>. * src/sigaction.c: Added include of <signal.h>. * src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. *
* 2000-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-10-252-1/+6
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * src/Makefile.am, optman/Makefile.am: Include compile.am.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-3077-76/+82
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-254-43/+117
| | | | | | | | * inline/rtems/posix/timer.inl, include/rtems/posix/timer.h, inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the style of src/ptimer1.c. Continued effort to make the POSIX Timer implementation match that of other managers. Added data structures required to use SuperCore Object Handler.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-152-12/+5
| | | | * src/ptimer1.c: Minor formatting fixes.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-154-47/+26
| | | | | | | | * src/ptimer1.c: Removed unused routine PRINT_ERRNO_S. * src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S and used structure copy instead. * src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control. * include/rtems/posix/timer.h: Ditto.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-152-48/+25
| | | | | * posix/src/ptimer1.c: Switched to using set_errno_and_return_minus_one() to ensure that errno was always set.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-152-10/+10
| | | | | * posix/src/ptimer1.c (timer_settime): Converted use of rtems_clock_get to use SuperCore _TOD_Current variable.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-1/+6
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Fixed problem reported by Victor V. Vengerov <Victor.Vengerov@oktet.ru>Joel Sherrill2000-07-071-1/+7
| | | | | | where alarm() did not correctly account for the watchdog start_time and stop_time fields being based on ticks not seconds. This resulted in alarm() returning a bogus number of seconds remaining.
* Switched to using _POSIX_Mutex_Get_interrupt_disable to improve performance.Joel Sherrill2000-07-061-3/+4
* Added support for converting a mutex id to a pointer and returningJoel Sherrill2000-07-061-21/+39
| | | | with interrupts disabled.
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-121-1/+1
| | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-1210-39/+55
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-1311-0/+33
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-2/+1
* Removed unused variable warning.Joel Sherrill2000-01-141-1/+0
* Removed no prototype of kill() warning.Joel Sherrill2000-01-141-0/+2
* POSIX message queues now include complete functionality includingJoel Sherrill2000-01-131-2/+0
| | | | | | | | | | | | | | | | blocking sends when the queue is full. The SuperCore was enhanced to support blocking on send. The existing POSIX API was debugged and numerous test cases were added to psxmsgq01 by Jennifer Averett. SuperCore enhancements and resulting modifications to other APIs were done by Joel. There is one significant point of interpretation for the POSIX API. What happens to threads already blocked on a message queue when the mode of that same message queue is changed from blocking to non-blocking? We decided to unblock all waiting tasks with an EAGAIN error just as if a non-blocking version of the same operation had returned unsatisfied. This case is not discussed in the POSIX standard and other implementations may have chosen differently.
* + Comment cleanupJennifer Averett2000-01-134-15/+12
* Removed referance to rtems error.Jennifer Averett2000-01-131-1/+2
| | | | Added correct include file.
* Debugged and yellow line tested routines.Jennifer Averett2000-01-123-41/+71
* + Modified return codesJennifer Averett2000-01-121-16/+27
| | | | | + Added messsage size check + Debugged and yellowed out routine
* + Added signal processing.Jennifer Averett2000-01-121-1/+3
| | | | + Yellow line tested source.
* + Modified to correct return codes.Jennifer Averett2000-01-121-2/+5
| | | | | + Removed extra flag attribute from message queue structure. + Yellow-lined all posix message queue routines.
* + Changed call from core flush to core close routine. This flushes waitingJennifer Averett2000-01-121-2/+4
| | | | queues as well as the messages.
* + Removed name validation code (this was already done in nametoid.Jennifer Averett2000-01-121-41/+6
* Fixed spacing.Joel Sherrill2000-01-111-1/+1
* This code did not return properly when a process oriented signalJoel Sherrill2000-01-111-6/+5
| | | | was pending. Reported by Wayne Bullaughey <wayneb@cacdsp.com>.
* Don't look at the object information structure for threads/tasksJoel Sherrill2000-01-102-17/+28
| | | | | for APIs that are not configured. This resulted in weird behavior when ITRON was disabled on some targets.
