1999-12-23 | + Added check for name greater than PATH_MAX | Jennifer Averett | 1 | -0/+14 | |
1999-12-23 | + Debugged. | Jennifer Averett | 2 | -40/+61 | |
1999-12-23 | + Filled in routine. | Jennifer Averett | 1 | -1/+15 | |
1999-12-23 | + Initial debug | Jennifer Averett | 1 | -0/+6 | |
1999-12-23 | + Made work | Jennifer Averett | 1 | -15/+55 | |
+ Added checks for valid attribute maxmsg and msgsize + Added check for ENAMETOOLONG | |||||
1999-12-23 | + Fixed errno response to match the POSIX manual. | Jennifer Averett | 1 | -1/+1 | |
1999-11-29 | Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2 | -7/+20 | |
which (among other things) converted the mptests to automake. SUB_DIRS was used instead of SUBDIRS in some Makefile.ins (apparently a leftover from moving the start* directories) Addtional major bugs: * psxtests/include was empty (incomplete psxtests changes). * bogus handling of *.scn in itrontests (screens/sptests vs. screens/itrontests installation dirs) In addition I have added a few more changes (I couldn't resist) * automake support for itrontests * OPERATION_COUNT support in tmitrontests/ * automake support for tmitrontests * automake suppport for mptests * Some (minor) corrections to several configure.in/Makefile.ams => c/src/tests/ is completly under automake control, now. => we could start to sort out the structural issues with c/src/tests (tests/support, stubdr, tools, get "make dist" working) | |||||
1999-11-29 | Made sure POSIX would build with MP enabled. | Joel Sherrill | 7 | -10/+127 | |
1999-11-23 | Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 3 | -3/+113 | |
to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib." | |||||
1999-11-22 | Fixed dispatching and cleaned up code. | Jennifer Averett | 2 | -30/+14 | |
1999-11-22 | + Corrected enable/disable of dispatch. | Jennifer Averett | 1 | -23/+31 | |
+ Cleaned up code. | |||||
1999-11-22 | + Updated comments. | Jennifer Averett | 1 | -9/+20 | |
+ Corrected enable/disable of dispatch. | |||||
1999-11-22 | + Corrected bug in error check. | Jennifer Averett | 1 | -2/+1 | |
1999-11-22 | + Added description of routine to comment. | Jennifer Averett | 1 | -0/+4 | |
1999-11-22 | + Corrected error processing code. | Jennifer Averett | 1 | -14/+15 | |
1999-11-22 | + Added checks for NULL and NULL string names (for sem_open & sem_unlink). | Jennifer Averett | 1 | -1/+7 | |
1999-11-22 | + Cleaned up comments. | Jennifer Averett | 1 | -6/+16 | |
1999-11-22 | Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 1 | -6/+6 | |
.. a major configuration cleanup ... major enhancement of automake support. ... and it contains a *major* breakthough: Automake support for libchip and libmisc *LEAF* directories. To implement this I have used several nasty tricks * The basical trick is to wrap an old Makefile.in's contents into a Makefile.am and still continue to use (i.e include) the old *.cfg files. * Replaced each INSTALL_IF_CHANGE and INSTALL_VARIANT with make dependencies * Add a gnu-make ifdef AUTOMAKE to main.cfg to avoid conflicts between automake and RTEMS make rules * Replaced each install:: and preinstall:: rule with make dependencies * Replaced SUB_DIRS with SUBDIRS in all Makefile.ins (Automake convention) * Removed each manually added autoconf substitution which automake performs automatically. This is not yet full automake support, because using the temporary installation directory, preinstallation in general and building variants are in contradiction to automake's basic working principles ... ... the new Makefile.ams work still somewhat clumsy ... nevertheless they work (quite well). WARNING: At first glance this patch is small, but * it affects the whole configuration system. * it opens the road to introducing automake to all Makefile.ins currently not being under automake control. JOEL> Does this remove or add any files? Both, all Makefile.ins below libchip and libmisc get replaced with Makefile.ams. | |||||
1999-11-18 | Added EINVAL for passing a NULL pointer in. | Jennifer Averett | 1 | -0/+4 | |
1999-11-18 | + Debuged to the point that you could open, unlink and close a semaphore. | Jennifer Averett | 4 | -30/+29 | |
but all paths have not been checked, yet. | |||||
1999-11-18 | Added a routine to remove a semaphore name from its namespace. | Jennifer Averett | 1 | -0/+15 | |
1999-11-17 | Updated copyright notice. | Joel Sherrill | 69 | -138/+69 | |
1999-11-16 | Return a reasonable error other than ENOSYS. | Joel Sherrill | 1 | -1/+1 | |
1999-11-16 | Added call to _Watchdog_Remove to remove the sporadic timer. It was | Joel Sherrill | 1 | -0/+1 | |
being reinserted onto the ticks chain. | |||||
1999-11-15 | Removed nanosleep() since it is now in its own file. | Joel Sherrill | 1 | -21/+0 | |
1999-11-09 | This patch adds the basic framework for the ITRON 3.0 API implementation | Joel Sherrill | 1 | -1/+1 | |
for RTEMS. | |||||
1999-11-09 | sem_close was accidentally lost in the split. | Joel Sherrill | 1 | -0/+47 | |
1999-11-05 | Split unistd.c file into sysconf.c and sleep.c. | Joel Sherrill | 2 | -0/+68 | |
1999-11-03 | Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since RTEMS | Joel Sherrill | 5 | -8/+9 | |
internal symbols are supposed to have leading underscores. | |||||
1999-11-03 | Added prototype of _POSIX_Semaphore_Delete to avoid warnings. | Joel Sherrill | 1 | -0/+12 | |
1999-11-03 | Added prototype of POSIX_Thread_cancel_run to avoid warnings. | Joel Sherrill | 1 | -0/+12 | |
1999-11-02 | Split types.s into individual files. | Joel Sherrill | 11 | -171/+302 | |
1999-11-02 | Final tuning required to drop out POSIX timers. | Joel Sherrill | 3 | -46/+58 | |
1999-11-02 | *** empty log message *** | Joel Sherrill | 3 | -921/+979 | |
1999-11-02 | Split cancel.c into multiple files. | Joel Sherrill | 7 | -182/+272 | |
1999-11-02 | Missed these in the initial split up. | Joel Sherrill | 2 | -0/+177 | |
1999-11-02 | Split key.c into multiple files. | Joel Sherrill | 6 | -225/+290 | |
1999-11-02 | Wrong routine was initially cut into this file. | Joel Sherrill | 1 | -14/+6 | |
1999-11-02 | Split time.c into multiple files. | Joel Sherrill | 13 | -365/+573 | |
1999-11-02 | Split condition variables into multiple files. | Joel Sherrill | 14 | -482/+537 | |
1999-11-02 | Split the POSIX semaphore manager into multiple files. | Joel Sherrill | 17 | -585/+829 | |
1999-11-02 | Split some more stuff out of psignal.c. | Joel Sherrill | 6 | -235/+341 | |
1999-11-02 | Split mutex.c into multiple files. | Joel Sherrill | 22 | -702/+1029 | |
1999-11-02 | Split mqueue into multiple files. | Joel Sherrill | 1 | -0/+28 | |
1999-11-02 | Removed warnings. | Joel Sherrill | 1 | -2/+2 | |
1999-11-02 | Split mqueue.c into a variety of files. | Joel Sherrill | 16 | -672/+1120 | |
1999-11-02 | Now much closer to working. | Joel Sherrill | 1 | -7/+61 | |
1999-11-02 | Added assert in case _Objects_Get_information fails since this | Joel Sherrill | 1 | -0/+4 | |
should NEVER occur. | |||||
1999-11-02 | Commented out lines causing warning. | Joel Sherrill | 1 | -0/+2 | |
1999-11-02 | Added #define for SEM_FAILED. | Joel Sherrill | 1 | -0/+2 | |
