with interrupts disabled.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
were done by Joel.
Added correct include file.
+ Added messsage size check
+ Debugged and yellowed out routine
+ Yellow line tested source.
+ Removed extra flag attribute from message queue structure.
+ Yellow-lined all posix message queue routines.
queues as well as the messages.
was pending. Reported by Wayne Bullaughey <wayneb@cacdsp.com>.
for APIs that are not configured. This resulted in weird behavior
when ITRON was disabled on some targets.
+ Added priority validation
+ Changed to call correct core routine.
+ Added priority conversion
+ Resolved return type problems.
+ Added ability to return message priority from the core.
+ Added oflag tracking.
+ Added checks for valid attribute maxmsg and msgsize
+ Added check for ENAMETOOLONG
Addtional major bugs:
+ Cleaned up code.
+ Corrected enable/disable of dispatch.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
