path: root/cpukit/posix/src (follow)
* 2002-02-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-061-0/+1
| | | | | * configure.ac: AC_CONFIG_SRCDIR([src/pthreads.c]) * src/psignal.c: #include <string.h>.
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-0437-108/+109
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one. * src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one. * src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one. * src/killinfo.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one. * src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one. * src/sched.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semclose.c: Apply rtems_set_errno_and_return_minus_one. * src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one. * src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one. * src/seminit.c: Apply rtems_set_errno_and_return_minus_one. * src/semopen.c: Apply rtems_set_errno_and_return_minus_one. * src/sempost.c: Apply rtems_set_errno_and_return_minus_one. * src/semunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/setpgid.c: Apply rtems_set_errno_and_return_minus_one. * src/setsid.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaction.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigismember.c: Apply rtems_set_errno_and_return_minus_one. * src/sigpending.c: Apply rtems_set_errno_and_return_minus_one. * src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one. * src/utsname.c: Apply rtems_set_errno_and_return_minus_one.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-191-1/+1
| | | | | * optman/Makefile.am: Add multilib support. Remove ASM4FLAGS. * src/Makefile.am: Add multilib support.
* 2001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-282-2/+2
| | | | * src/mqueueopen.c, src/semopen.c: Clarify type on va_arg.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-1/+1
| | | | | * optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5 happy. * src/Makefile.am: Adapt INCLUDES to make automake-1.5 happy.
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-131-1/+1
| | | | * src/sysconf.c: Fix typo syntax error accidentally committed.
* 2001-09-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-134-5/+58
| | | | | | | | | * src/mprotect.c: New file. Stub required by some gcc's to pass tests. In particular, about 350 ACATS tests fail if this is not present. * src/getpagesize.c: Ditto. * src/sysconf.c: Addition of Solaris value for _SC_STACK_PROT required to pass about 350 ACATS test cases. * src/Makefile.am: Added new files.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-161-1/+12
| | | | | * src/mqueuesendsupp.c: Account for possibly blocking during the core send operation.
* 2001-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-091-3/+4
| | | | | | | * src/mqueuesendsupp.c: Unblocking message queue operations should NOT use _Thread_Executing for return status since it is permissible to invoke message send operations from an ISR. This was reported by Suvrat Gupta <suvrat@utstar.com>.
* 2000-05-24 Fernando Ruiz Casas <fernando.ruiz@ctv.es>Joel Sherrill2001-05-245-1/+38
| | | | | * src/getegid.c, src/geteuid.c, src/getgid.c, src/getlogin.c, src/getuid.c: Now save their values in private user environment.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-24181-0/+682
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* 2001-01-23 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-231-1/+1
| | | | * src/alarm.c: Eliminated use of C++ style comments.
* 2001-01-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-221-2/+5
| | | | | | * src/clockgetres.c: Fixed match problem. We are not converting an interval to a timespec -- it is actually a real number of microseconds.
* 2001-01-22 Michael Hamel <mhamel@adi.co.nz>Joel Sherrill2001-01-225-8/+8
| | | | | | | | * include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl, src/ptimer1.c, include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl, src/alarm.c, src/ptimer1.c, src/semaphorenametoid.c, src/semopen.c, src/semunlink.c: Modifications to make CodeWarrior happy.
* 2001-01-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-121-1/+12
| | | | * src/README.mqueue: Enhanced example.
* 2000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-191-4/+7
| | | | | * src/pthreadgetschedparam.c: Do not set output parameters if the pointers are NULL.
* 2000-12-06 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-061-0/+2
| | | | | * src/pthreadgetcpuclockid.c: Add include of <rtems/system.h> to eliminate warning.
* 2000-11-27 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-271-0/+15
| | | | * src/sysconf.c: Add support for _SC_CLK_TCK and _SC_OPEN_MAX.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-317-7/+7
| | | | | | | | | | | | | | | | | | | * include/Makefile.am: Updated to reflect files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * include/unistd.h: Removed. Now use newlib's. * include/rtems/posix/mqueue.h: Add include of <signal.h>. * include/rtems/posix/threadsup.h: Add include of <sys/signal.h> * src/execv.c: Corrected prototype to agree with newlib. * src/execve.c: Corrected prototype to agree with newlib. * src/execvp.c: Corrected prototype to agree with newlib. * src/psignal.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. * src/pthreadkill.c: Added include of <signal.h>. * src/sigaction.c: Added include of <signal.h>. * src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since that file no longer exists. *
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | * src/Makefile.am, optman/Makefile.am: Include compile.am.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-3076-76/+76
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* 2000-08-25 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2000-08-251-43/+5
| | | | | | | | * inline/rtems/posix/timer.inl, include/rtems/posix/timer.h, inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the style of src/ptimer1.c. Continued effort to make the POSIX Timer implementation match that of other managers. Added data structures required to use SuperCore Object Handler.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-151-12/+1
| | | | * src/ptimer1.c: Minor formatting fixes.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-152-43/+14
| | | | | | | | * src/ptimer1.c: Removed unused routine PRINT_ERRNO_S. * src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S and used structure copy instead. * src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control. * include/rtems/posix/timer.h: Ditto.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-151-48/+20
| | | | | * posix/src/ptimer1.c: Switched to using set_errno_and_return_minus_one() to ensure that errno was always set.
* 2000-08-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-151-10/+5
| | | | | * posix/src/ptimer1.c (timer_settime): Converted use of rtems_clock_get to use SuperCore _TOD_Current variable.
* Port of RTEMS to the Texas Instruments C3x/C4x DSP families includingJoel Sherrill2000-07-261-1/+6
| | | | | | | | | | | a BSP (c4xsim) supporting the simulator included with gdb. This port was done by Joel Sherrill and Jennifer Averett of OAR Corporation. Also included with this port is a space/time optimization to eliminate FP context switch management on CPUs without hardware or software FP. An issue with this port was that sizeof(unsigned32) = sizeof(unsigned8) on this CPU. This required addressing alignment checks and assumptions as well as fixing code that assumed sizeof(unsigned32) == 4.
* Fixed problem reported by Victor V. Vengerov <Victor.Vengerov@oktet.ru>Joel Sherrill2000-07-071-1/+7
| | | | | | where alarm() did not correctly account for the watchdog start_time and stop_time fields being based on ticks not seconds. This resulted in alarm() returning a bogus number of seconds remaining.
* Switched to using _POSIX_Mutex_Get_interrupt_disable to improve performance.Joel Sherrill2000-07-061-3/+4
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-121-1/+1
| | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-128-29/+43
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-2/+1
* Removed unused variable warning.Joel Sherrill2000-01-141-1/+0
* Removed no prototype of kill() warning.Joel Sherrill2000-01-141-0/+2
* + Comment cleanupJennifer Averett2000-01-134-15/+12
* Removed referance to rtems error.Jennifer Averett2000-01-131-1/+2
| | | | Added correct include file.
* Debugged and yellow line tested routines.Jennifer Averett2000-01-123-41/+71
* + Modified return codesJennifer Averett2000-01-121-16/+27
| | | | | + Added messsage size check + Debugged and yellowed out routine
* + Added signal processing.Jennifer Averett2000-01-121-1/+3
| | | | + Yellow line tested source.
* + Modified to correct return codes.Jennifer Averett2000-01-121-2/+5
| | | | | + Removed extra flag attribute from message queue structure. + Yellow-lined all posix message queue routines.
* + Changed call from core flush to core close routine. This flushes waitingJennifer Averett2000-01-121-2/+4
| | | | queues as well as the messages.
* + Removed name validation code (this was already done in nametoid.Jennifer Averett2000-01-121-41/+6
* Fixed spacing.Joel Sherrill2000-01-111-1/+1
* This code did not return properly when a process oriented signalJoel Sherrill2000-01-111-6/+5
| | | | was pending. Reported by Wayne Bullaughey <wayneb@cacdsp.com>.
* Don't look at the object information structure for threads/tasksJoel Sherrill2000-01-102-17/+28
| | | | | for APIs that are not configured. This resulted in weird behavior when ITRON was disabled on some targets.
* Added support for simple binary semaphores in addition to the highJoel Sherrill2000-01-051-1/+5
| | | | | | | | | | | | power binary/mutex style semaphores already supported by RTEMS. This was done at the request of Eric Norum <eric@cls.usask.ca> in support of his effort to port EPICS to RTEMS. This change consisted of changing the nesting_allowed boolean into a lock_nesting_behavior enumerated value as well as allowing the core mutex object to optionally support ensuring that the holder of a binary semaphore released it. Finally, a more subtle enhancement was to allow the non-holder to release a priority inheritance/ceiling mutex and still allow the holding task to return to its original priority.
* + Changed priority to the POSIX priority type.Jennifer Averett2000-01-051-9/+46
| | | | | | | + Added priority validation + Changed to call correct core routine. + Added priority conversion + Resolved return type problems.
* + Added check for reading from a write only queue.Jennifer Averett2000-01-051-1/+12
| | | | + Added ability to return message priority from the core.
* + Added check for name greater than PATH_MAX.Jennifer Averett2000-01-051-0/+3
