* | + Filled in routine. | Jennifer Averett | 1999-12-23 | 1 | -1/+15 | |
* | + Initial debug | Jennifer Averett | 1999-12-23 | 1 | -0/+6 | |
* | + Made work | Jennifer Averett | 1999-12-23 | 1 | -15/+55 | |
| | | | | | + Added checks for valid attribute maxmsg and msgsize + Added check for ENAMETOOLONG | |||||
* | + Fixed errno response to match the POSIX manual. | Jennifer Averett | 1999-12-23 | 1 | -1/+1 | |
* | Made sure POSIX would build with MP enabled. | Joel Sherrill | 1999-11-29 | 7 | -10/+127 | |
* | Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+109 | |
| | | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib." | |||||
* | Fixed dispatching and cleaned up code. | Jennifer Averett | 1999-11-22 | 2 | -30/+14 | |
* | + Corrected enable/disable of dispatch. | Jennifer Averett | 1999-11-22 | 1 | -23/+31 | |
| | | | | + Cleaned up code. | |||||
* | + Updated comments. | Jennifer Averett | 1999-11-22 | 1 | -9/+20 | |
| | | | | + Corrected enable/disable of dispatch. | |||||
* | + Corrected bug in error check. | Jennifer Averett | 1999-11-22 | 1 | -2/+1 | |
* | + Added description of routine to comment. | Jennifer Averett | 1999-11-22 | 1 | -0/+4 | |
* | + Corrected error processing code. | Jennifer Averett | 1999-11-22 | 1 | -14/+15 | |
* | + Added checks for NULL and NULL string names (for sem_open & sem_unlink). | Jennifer Averett | 1999-11-22 | 1 | -1/+7 | |
* | + Cleaned up comments. | Jennifer Averett | 1999-11-22 | 1 | -6/+16 | |
* | Added EINVAL for passing a NULL pointer in. | Jennifer Averett | 1999-11-18 | 1 | -0/+4 | |
* | + Debuged to the point that you could open, unlink and close a semaphore. | Jennifer Averett | 1999-11-18 | 4 | -30/+29 | |
| | | | | but all paths have not been checked, yet. | |||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 48 | -96/+48 | |
* | Return a reasonable error other than ENOSYS. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
* | Added call to _Watchdog_Remove to remove the sporadic timer. It was | Joel Sherrill | 1999-11-16 | 1 | -0/+1 | |
| | | | | being reinserted onto the ticks chain. | |||||
* | Removed nanosleep() since it is now in its own file. | Joel Sherrill | 1999-11-15 | 1 | -21/+0 | |
* | sem_close was accidentally lost in the split. | Joel Sherrill | 1999-11-09 | 1 | -0/+47 | |
* | Split unistd.c file into sysconf.c and sleep.c. | Joel Sherrill | 1999-11-05 | 2 | -0/+68 | |
* | Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since RTEMS | Joel Sherrill | 1999-11-03 | 4 | -5/+5 | |
| | | | | internal symbols are supposed to have leading underscores. | |||||
* | Split types.s into individual files. | Joel Sherrill | 1999-11-02 | 11 | -171/+302 | |
* | Final tuning required to drop out POSIX timers. | Joel Sherrill | 1999-11-02 | 2 | -46/+33 | |
* | *** empty log message *** | Joel Sherrill | 1999-11-02 | 2 | -921/+947 | |
* | Split cancel.c into multiple files. | Joel Sherrill | 1999-11-02 | 7 | -182/+272 | |
* | Missed these in the initial split up. | Joel Sherrill | 1999-11-02 | 2 | -0/+177 | |
* | Split key.c into multiple files. | Joel Sherrill | 1999-11-02 | 6 | -225/+290 | |
* | Wrong routine was initially cut into this file. | Joel Sherrill | 1999-11-02 | 1 | -14/+6 | |
* | Split time.c into multiple files. | Joel Sherrill | 1999-11-02 | 13 | -365/+573 | |
* | Split condition variables into multiple files. | Joel Sherrill | 1999-11-02 | 13 | -482/+501 | |
* | Split the POSIX semaphore manager into multiple files. | Joel Sherrill | 1999-11-02 | 15 | -584/+791 | |
* | Split some more stuff out of psignal.c. | Joel Sherrill | 1999-11-02 | 6 | -235/+341 | |
* | Split mutex.c into multiple files. | Joel Sherrill | 1999-11-02 | 21 | -702/+994 | |
* | Removed warnings. | Joel Sherrill | 1999-11-02 | 1 | -2/+2 | |
* | Split mqueue.c into a variety of files. | Joel Sherrill | 1999-11-02 | 16 | -672/+1120 | |
* | Now much closer to working. | Joel Sherrill | 1999-11-02 | 1 | -7/+61 | |
* | Added assert in case _Objects_Get_information fails since this | Joel Sherrill | 1999-11-02 | 1 | -0/+4 | |
| | | | | should NEVER occur. | |||||
* | Commented out lines causing warning. | Joel Sherrill | 1999-11-02 | 1 | -0/+2 | |
* | Added name to id support routine. | Joel Sherrill | 1999-11-01 | 1 | -0/+15 | |
* | Removed routines that had already been separated into their own files. | Joel Sherrill | 1999-11-01 | 1 | -505/+0 | |
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca> | Joel Sherrill | 1999-10-25 | 1 | -0/+8 | |
| | | | | | to initialize the pthread cancellation fields. This is a patch to _POSIX_Threads_Create_extension that fixes the problem. | |||||
* | Fixed core dump caused when output parameter (otimer) was NULL. | Joel Sherrill | 1999-10-21 | 1 | -3/+7 | |
* | Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca> to add | Joel Sherrill | 1999-08-30 | 1 | -1/+13 | |
| | | | | | support for return codes from POSIX threads that do an implicit exit by returning from the bottom of the main function. | |||||
* | Honor 0 as PID of caller. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 | |
* | New file to implement signal(2). | Joel Sherrill | 1999-07-01 | 1 | -0/+50 | |
* | Removed check for initialized ID at request of Rosimildo DaSilva | Joel Sherrill | 1999-05-14 | 1 | -0/+23 | |
| | | | | | <rdasilva@connecttel.com> who encountered random failures in his port of omniORB2. | |||||
* | Made all calls to _Thread_Yield_processor consistent in how they are | Joel Sherrill | 1999-05-07 | 1 | -2/+3 | |
| | | | | wrapped by calls to _Thread_Enable_dispatch and _Thread_Disable_dispatch. | |||||
* | Patch from Jiri Gaisler <jgais@ws.estec.esa.nl> to allow stacksize | Joel Sherrill | 1999-05-07 | 1 | -1/+1 | |
| | | | | of POSIX Init thread to be user configured. |
