The man-page for pthread_setspecific does not define the EAGAIN return value.
Further without this patch it was not possible to set keys that have been
already set a new value.
Add test for setting a new value to a already set key.
Enable pthread_once() for all configurations. The pthread_once()
function is one means to initialize POSIX keys. Another use case is the
C++ support.
Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
This partially reverts commit 1215fd4d9426a59d568560e9a485628560363133.
In order to support profiling of SMP locks and provide a future
compatible SMP locks API it is necessary to add an SMP lock destroy
function. Since the commit above adds an SMP lock to each chain control
we would have to add a rtems_chain_destroy() function as well. This
complicates the chain usage dramatically. Thus revert the patch above.
A global SMP lock for all chains is used to implement the protected
chain operations.
Advantages:
* The SAPI chain API is now identical on SMP and non-SMP
configurations.
* The size of the chain control is reduced and is then equal to the
Score chains.
* The protected chain operations work correctly on SMP.
Disadvantage:
* Applications using many different chains and the protected operations
may notice lock contention.
The chain control size drop is a huge benefit (SAPI chain controls are
66% larger than the Score chain controls). The only disadvantage is not
really a problem since these applications can use specific interrupt
locks and unprotected chain operations to avoid this issue.
Formerly POSIX keys were only enabled when POSIX threads
were enabled. Because they are a truly safe alternative
to per-task variables in an SMP system, they are being
enabled in all configurations.
This is a useful POSIX thread API helper which is found in
`GNU/Linux and *BSD.
This patch adds the following methods:
+ pthread_get_affinity_np
+ pthread_set_affinity_np
+ pthread_attr_get_affinity_np
+ pthread_attr_set_affinity_np
With the addition of pthread affinity information in pthread_attr_t,
the existing code for pthread_attr_t had to be adjusted.
Reproducable crashes occur when using pthreads and the capture engine
at the same time. 'pthread_create()' is the culprit. It creates a SCORE thread
and then calls Thread_Start( ) without disabling thread-dispatching.
This is highly unlikely and would indicate a serious bug
in the system or corruption. But it is better to be cautious.
This error check was commented out because it is not in the POSIX
specification. However, the GNU/Linux manual page does document
that EPERM is to be returned in this situation.
Provide support for latest Newlib <pthread.h> change. The cleanup
contexts are stored on the thread stack. This is conformant with the
POSIX requirements for the pthread_cleanup_push() and
pthread_cleanup_pop() statement pair.
Passing an invalid pointer as the routine to pthread_cleanup_push() is
now a usage error and the behaviour is undefined.
+ timer_create()
+ timer_settime()
Add ISR lock to chain control for proper SMP protection. Replace
rtems_chain_extract() with rtems_chain_explicit_extract() and
rtems_chain_insert() with rtems_chain_explicit_insert() on SMP
configurations. Use rtems_chain_explicit_extract() and
rtems_chain_explicit_insert() to provide SMP support.
Add and use _POSIX_signals_Release(). The post-switch handler is not
protected by disabled thread dispatching. Use proper SMP lock for
signal management.
Do not disable interrupts since the caller did this already.
Assume the sigaction() is called only from thread context. Protect
against concurrent sigaction() invocations by different threads.
Add thread parameter to _Thread_queue_Enqueue_with_handler() to avoid
access to global _Thread_Executing.
Implement the reeview changes.
Add a POSIX Fatal error domain.
Fix confdefs.h to correctly handle the internal POSIX mutexes.
Change pthread_once from using disabled pre-emption to using a
pthread mutex making it SMP safe. GCC using a posix threading
model uses pthread_once.
The pthread mutex requires at least 1 mutex is configured so
confdefs.h has been updated to account for the internal
mutex.
The recursive field in the pthread_mutexattr_t is now not used. The
code in pthread_mutexattr_settype only sets the type field and not
the recursive field.
Use the POSIX configuration value directly. Use right type early and
avoid casts. Use proper unlimited objects API. Check workspace
allocation. Make functions static.
Move implementation specific parts of key.h and key.inl into new header
file keyimpl.h. The key.h contains now only the application visible
API.
