* src/psignal.c: Remove duplication from rtems/posix/psignal.h.
* src/adjtime.c: New file -- adjtime() support required by the
Network Time Protocol (NTP) port to RTEMS.
* src/Makefile.am: Modified to reflect above.
* src/cancelrun.c: Remove check for PTHREAD_CANCELED not being defined
to ensure that newlib patch includes it.
* src/mqueuecreatesupp.c: #include <stdlib.h> (malloc).
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* src/Makefile.am: Use AM_CPPFLAGS instead of INCLUDES.
* include/rtems/posix/cancel.h, src/cancel.c, src/cancelrun.c,
src/mqueue.c, src/pthread.c, src/semaphore.c, src/setcancelstate.c,
src/setcanceltype.c, src/testcancel.c: Per PR164, corrected the
behavior of thread cancellation and did some cleanup as a side-effect.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/rtems/posix/key.h, src/cond.c, src/condinit.c, src/intr.c,
src/key.c, src/keycreate.c, src/keydelete.c, src/killinfo.c,
src/mqueue.c, src/mqueuecreatesupp.c, src/mutex.c, src/mutexinit.c,
src/psignal.c, src/pthread.c, src/semaphore.c,
src/semaphorecreatesupp.c: Modified as part of above.
* configure.ac: Remove references to RTEMS_BSP.
* src/Makefile.am: Add libposix.a.
Use ../aclocal.
* inline/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* macros/Makefile.am: Include $(top_srcdir)/../automake/*.am.
* include/sys/utsname.h: Remove.
* include/Makefile.am: Reflect changes above.
* src/utsname.c: Remove.
* src/Makefile.am: Reflect changes above.
* include/rtems/posix/mqueue.h, inline/rtems/posix/mqueue.inl,
src/mqueue.c, src/mqueueclose.c, src/mqueuecreatesupp.c,
src/mqueuegetattr.c, src/mqueuenotify.c, src/mqueueopen.c,
src/mqueuerecvsupp.c, src/mqueuesendsupp.c, src/mqueuesetattr.c:
Per PR81 reworked to add a message queue descriptor separate from
the underlying message queue. This allows non-blocking to follow
the "open" not the underlying queue.
* src/psignal.c: Include <stdlib.h>.
* Per PR142, make task switch extension its own list.
* src/pthread.c (_POSIX_Threads_User_extensions): Reflect above.
* src/getegid.c: Remove <errno.h>.
* src/geteuid.c: Ditto.
* src/getgid.c: Ditto.
* src/getuid.c: Ditto.
* src/getlogin.c: Move <errno.h>.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/pthreadonce.c: Task is not preemptable while running a
pthread_once init function. This is slightly less heavy handed
than disabling dispatching and seems better than consuming a mutex.
* src/getegid.c: Add #include <rtems/userenv.h>.
Remove #include <rtems/libio_.h>.
* src/getlogin.c: Ditto.
* configure.ac: AC_CONFIG_SRCDIR([src/pthreads.c])
* src/psignal.c: #include <string.h>.
* src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one.
* src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one.
* src/killinfo.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one.
* src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one.
* src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one.
* src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one.
* src/sched.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one.
* src/semclose.c: Apply rtems_set_errno_and_return_minus_one.
* src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one.
* src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one.
* src/seminit.c: Apply rtems_set_errno_and_return_minus_one.
* src/semopen.c: Apply rtems_set_errno_and_return_minus_one.
* src/sempost.c: Apply rtems_set_errno_and_return_minus_one.
* src/semunlink.c: Apply rtems_set_errno_and_return_minus_one.
* src/setpgid.c: Apply rtems_set_errno_and_return_minus_one.
* src/setsid.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaction.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigismember.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigpending.c: Apply rtems_set_errno_and_return_minus_one.
* src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one.
* src/utsname.c: Apply rtems_set_errno_and_return_minus_one.
* optman/Makefile.am: Add multilib support. Remove ASM4FLAGS.
* src/Makefile.am: Add multilib support.
* src/mqueueopen.c, src/semopen.c: Clarify type on va_arg.
* optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5 happy.
* src/Makefile.am: Adapt INCLUDES to make automake-1.5 happy.
* src/sysconf.c: Fix typo syntax error accidentally committed.
* src/mprotect.c: New file. Stub required by some gcc's to pass tests.
In particular, about 350 ACATS tests fail if this is not present.
* src/getpagesize.c: Ditto.
* src/sysconf.c: Addition of Solaris value for _SC_STACK_PROT required
to pass about 350 ACATS test cases.
* src/Makefile.am: Added new files.
* src/mqueuesendsupp.c: Account for possibly blocking during the
core send operation.
* src/mqueuesendsupp.c: Unblocking message queue operations should
by Suvrat Gupta <suvrat@utstar.com>.
* src/getegid.c, src/geteuid.c, src/getgid.c, src/getlogin.c,
src/getuid.c: Now save their values in private user environment.
* src/alarm.c: Eliminated use of C++ style comments.
* src/clockgetres.c: Fixed match problem. We are not converting
an interval to a timespec -- it is actually a real number of
microseconds.
* include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl,
src/ptimer1.c, include/rtems/posix/semaphore.h,
inline/rtems/posix/semaphore.inl, src/alarm.c, src/ptimer1.c,
src/semaphorenametoid.c, src/semopen.c, src/semunlink.c:
Modifications to make CodeWarrior happy.
* src/README.mqueue: Enhanced example.
* src/pthreadgetschedparam.c: Do not set output parameters if
the pointers are NULL.
* src/pthreadgetcpuclockid.c: Add include of <rtems/system.h> to
eliminate warning.
* src/sysconf.c: Add support for _SC_CLK_TCK and _SC_OPEN_MAX.
* include/Makefile.am: Updated to reflect files merged into newlib.
This resulted in some definitions moving to other files and thus
some secondary effects in RTEMS source code.
* include/unistd.h: Removed. Now use newlib's.
* include/rtems/posix/mqueue.h: Add include of <signal.h>.
* include/rtems/posix/threadsup.h: Add include of <sys/signal.h>
* src/execv.c: Corrected prototype to agree with newlib.
* src/execve.c: Corrected prototype to agree with newlib.
* src/execvp.c: Corrected prototype to agree with newlib.
* src/psignal.c: Rewrote reference to <siginfo.h> in comment since
that file no longer exists.
* src/pthreadkill.c: Added include of <signal.h>.
* src/sigaction.c: Added include of <signal.h>.
* src/sigtimedwait.c: Rewrote reference to <siginfo.h> in comment since
all APIs.
* inline/rtems/posix/timer.inl, include/rtems/posix/timer.h,
inline/rtems/posix/Makefile.am, src/ptimer1.c: Redid the
style of src/ptimer1.c. Continued effort to make the
POSIX Timer implementation match that of other managers.
Added data structures required to use SuperCore Object Handler.
* src/ptimer1.c: Minor formatting fixes.
* src/ptimer1.c: Removed unused routine PRINT_ERRNO_S.
* src/ptimer1.c: Removed unnecessary routine COPY_ITIMERSPEC_S
and used structure copy instead.
* src/ptimer1.c: Renamed timer_alive_t to POSIX_Timer_Control.
* include/rtems/posix/timer.h: Ditto.
* posix/src/ptimer1.c: Switched to using set_errno_and_return_minus_one()
to ensure that errno was always set.
* posix/src/ptimer1.c (timer_settime): Converted use of rtems_clock_get
to use SuperCore _TOD_Current variable.
where alarm() did not correctly account for the watchdog start_time
and stop_time fields being based on ticks not seconds. This resulted
in alarm() returning a bogus number of seconds remaining.
significant things:
and PowerPC
same code base.
