#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
http://www.google-melange.com/gci/task/view/google/gci2012/7987221
* posix/Makefile.am: Add dummy vfork() implementation.
* posix/src/vfork.c: New file.
