the timer_create() method can use CLOCK_MONOTONIC
but there was no test for this.
Also it implements the functionality to
create a CLOCK_MONOTONIC timer and gettime() .
Closes #3888
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
This simplifies the handling with local-only objects.
Update #2555.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
TOD_MILLISECONDS_TO_TICKS().
Move implementation specific parts of watchdog.h and watchdog.inl into
new header file watchdogimpl.h. The watchdog.h contains now only the
application visible API.
Move implementation specific parts of timer.h and timer.inl into new
header file timerimpl.h. The timer.h contains now only the application
visible API.
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
http://www.google-melange.com/gci/task/view/google/gci2012/7945218
* posix/include/rtems/posix/timer.h, posix/src/cleanuppop.c,
posix/src/cleanuppush.c, posix/src/mqueueclose.c,
posix/src/timergettime.c, posix/src/timersettime.c,
score/include/rtems/score/timespec.h:
* posix/src/timergettime.c: Include rtems/score/timespec.h
* posix/Makefile.am, posix/preinstall.am,
posix/include/rtems/posix/timer.h, score/src/objectget.c: Split POSIX
Timer implementation into multiple files. Add obvious error checks
for NULL parameters. Attempt to reduce include files.
* posix/src/timercreate.c, posix/src/timerdelete.c,
posix/src/timergetoverrun.c, posix/src/timergettime.c,
posix/src/timerinserthelper.c, posix/src/timersettime.c,
posix/src/timertsr.c: New files.
* posix/src/ptimer1.c: Removed.
