path: root/cpukit/posix/src/timercreate.c (follow)
* Whitespace removal.Ralf Corsepius2009-11-301-2/+2
* 2008-01-23 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-231-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * itron/include/rtems/itron/object.h, itron/src/cre_tsk.c, libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c, libmisc/capture/capture.c, libmisc/monitor/mon-manager.c, libmisc/stackchk/check.c, posix/src/condinit.c, posix/src/keycreate.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c, posix/src/mqueueopen.c, posix/src/mqueueunlink.c, posix/src/mutexinit.c, posix/src/pbarrierinit.c, posix/src/prwlockinit.c, posix/src/pspininit.c, posix/src/pthreadcreate.c, posix/src/pthreadexit.c, posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c, posix/src/timercreate.c, rtems/src/barrierident.c, rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c, rtems/src/ratemonident.c, rtems/src/regionident.c, rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c, sapi/src/extensionident.c, score/Makefile.am, score/include/rtems/score/object.h, score/inline/rtems/score/object.inl, score/src/apimutexallocate.c, score/src/objectextendinformation.c, score/src/objectgetnameasstring.c, score/src/objectmp.c, score/src/objectnametoid.c: Convert the Objects_Name type from a simple type to a union of an unsigned 32 bit integer and a pointer. This should help eliminate weird casts between u32 and pointers in various places. The APIs now have to explicitly call _u32 or _string versions of helper routines. This should also simplify things and eliminate the need for ugly casts in some cases. * score/src/objectclearname.c, score/src/objectcomparenameraw.c, score/src/objectcomparenamestring.c, score/src/objectcopynameraw.c, score/src/objectcopynamestring.c: Removed.
* 2007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-171-0/+97
* posix/Makefile.am, posix/preinstall.am, posix/include/rtems/posix/timer.h, score/src/objectget.c: Split POSIX Timer implementation into multiple files. Add obvious error checks for NULL parameters. Attempt to reduce include files. * posix/src/timercreate.c, posix/src/timerdelete.c, posix/src/timergetoverrun.c, posix/src/timergettime.c, posix/src/timerinserthelper.c, posix/src/timersettime.c, posix/src/timertsr.c: New files. * posix/src/ptimer1.c: Removed.
