* | Fix building with RTEMS_DEBUG. | Chris Johns | 2013-09-30 | 1 | -3/+17 |
* | sigsuspend.c: Address set but unused variable warning | Joel Sherrill | 2013-09-21 | 1 | -3/+6 |
* | cpukit/posix: Doxygen group is POSIXAPI | Joel Sherrill | 2013-01-10 | 1 | -1/+1 |
* | posix: Doxygen Enhancement Task #9 | Ayush Awasthi | 2012-12-19 | 1 | -0/+7 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7948216 | ||||
* | posix: Add and use <rtems/posix/psignalimpl.h> | Sebastian Huber | 2012-12-05 | 1 | -6/+1 |
| | | | | | This file contains the parts of <rtems/posix/psignal.h> that are only necessary for the POSIX API implementation. | ||||
* | 2010-07-27 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-07-27 | 1 | -1/+3 |
| | | | | * posix/src/sigsuspend.c: Do not assert unless RTEMS_DEBUG is defined. | ||||
* | 2010-07-27 Vinu Rajashekhar <vinutheraj@gmail.com> | Joel Sherrill | 2010-07-27 | 1 | -7/+11 |
| | | | | | | PR 1629/cpukit * posix/src/sigsuspend.c: sigsuspend() was not completely following the POSIX specification. | ||||
* | 2004-05-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-05-21 | 1 | -1/+9 |
| | | | | | | | | | PR 628/rtems * posix/src/killinfo.c, posix/src/pthreadkill.c, posix/src/ptimer1.c, posix/src/sigaction.c, posix/src/sigaddset.c, posix/src/sigsuspend.c: Signal set of 0 is supposed to return EINVAL. In addition timer_create needed to return an error if the clock was not CLOCK_REALTIME. | ||||
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/posix/cond.h, include/rtems/posix/condmp.h, include/rtems/posix/config.h, include/rtems/posix/intr.h, include/rtems/posix/key.h, include/rtems/posix/mqueue.h, include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h, include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h, include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h, include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h, include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl, inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl, inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl, inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl, inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c, src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c, src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c, src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c, src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c, src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c, src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c, src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c, src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c, src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c, src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c, src/pthreadexit.c, src/pthreadgetcpuclockid.c, src/pthreadgetcputime.c, src/pthreadgetschedparam.c, src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c, src/pthreadself.c, src/pthreadsetcputime.c, src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c, src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c, src/sigfillset.c, src/sigismember.c, src/signal_2.c, src/sigpending.c, src/sigprocmask.c, src/sigqueue.c, src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c, src/sigwaitinfo.c, src/ualarm.c: URL for license changed. | ||||
* | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-24 | 1 | -0/+3 |
| | | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | ||||
* | Split psignal.c into many more files. This reduced the amount of | Joel Sherrill | 1999-01-31 | 1 | -0/+43 |
object code that has to be loaded just for initializing the signal manager. |
