path: root/cpukit/posix/src/sigprocmask.c (follow)
* doxygen: Switch @brief and @ingroupSebastian Huber2020-04-281-1/+2
| | | | This order change fixes the Latex documentation build via Doxygen.
* signal methods: Add restrict keywordBryan Dunsmore2013-11-291-2/+2
* cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill2013-01-101-1/+1
* posix: Doxygen Enhancement Task #2Alex Ivanov2012-12-151-4/+12
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7988213
* Provide stub if RTEMS_POSIX_API is disabled.Ralf Corsepius2009-12-101-0/+4
* Remove unnecessary includes.Ralf Corsepius2009-12-041-5/+0
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/posix/cond.h, include/rtems/posix/condmp.h, include/rtems/posix/config.h, include/rtems/posix/intr.h, include/rtems/posix/key.h, include/rtems/posix/mqueue.h, include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h, include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h, include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h, include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h, include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl, inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl, inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl, inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl, inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c, src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c, src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c, src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c, src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c, src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c, src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c, src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c, src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c, src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c, src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c, src/pthreadexit.c, src/pthreadgetcpuclockid.c, src/pthreadgetcputime.c, src/pthreadgetschedparam.c, src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c, src/pthreadself.c, src/pthreadsetcputime.c, src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c, src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c, src/sigfillset.c, src/sigismember.c, src/signal_2.c, src/sigpending.c, src/sigprocmask.c, src/sigqueue.c, src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c, src/sigwaitinfo.c, src/ualarm.c: URL for license changed.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+3
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* Split psignal.c into many more files. This reduced the amount ofJoel Sherrill1999-01-311-0/+37
object code that has to be loaded just for initializing the signal manager.
