* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/posix/cond.h, include/rtems/posix/condmp.h, include/rtems/posix/config.h, include/rtems/posix/intr.h, include/rtems/posix/key.h, include/rtems/posix/mqueue.h, include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h, include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h, include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h, include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h, include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl, inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl, inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl, inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl, inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c, src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c, src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c, src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c, src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c, src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c, src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c, src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c, src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c, src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c, src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c, src/pthreadexit.c, src/pthreadgetcpuclockid.c, src/pthreadgetcputime.c, src/pthreadgetschedparam.c, src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c, src/pthreadself.c, src/pthreadsetcputime.c, src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c, src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c, src/sigfillset.c, src/sigismember.c, src/signal_2.c, src/sigpending.c, src/sigprocmask.c, src/sigqueue.c, src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c, src/sigwaitinfo.c, src/ualarm.c: URL for license changed. | ||||
* | 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-04 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one. * src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one. * src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one. * src/killinfo.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one. * src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one. * src/sched.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semclose.c: Apply rtems_set_errno_and_return_minus_one. * src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one. * src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one. * src/seminit.c: Apply rtems_set_errno_and_return_minus_one. * src/semopen.c: Apply rtems_set_errno_and_return_minus_one. * src/sempost.c: Apply rtems_set_errno_and_return_minus_one. * src/semunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/setpgid.c: Apply rtems_set_errno_and_return_minus_one. * src/setsid.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaction.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigismember.c: Apply rtems_set_errno_and_return_minus_one. * src/sigpending.c: Apply rtems_set_errno_and_return_minus_one. * src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one. * src/utsname.c: Apply rtems_set_errno_and_return_minus_one. | ||||
* | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-24 | 1 | -0/+3 |
| | | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | ||||
* | 2000-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-08-30 | 1 | -1/+1 |
| | | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs. | ||||
* | Split psignal.c into many more files. This reduced the amount of | Joel Sherrill | 1999-01-31 | 1 | -0/+45 |
object code that has to be loaded just for initializing the signal manager. |
