* | Include missing <string.h> | Sebastian Huber | 2017-08-25 | 1 | -0/+1 |
| | | | | Update #2133. | ||||
* | posix: fix warnings with mmap from heap/wkspace | Gedare Bloom | 2017-07-24 | 1 | -1/+1 |
| | | | | | | Avoid void pointer arithmetic. Updates #2859. | ||||
* | posix/mman: add mmap support for shm objects | Gedare Bloom | 2017-05-05 | 1 | -0/+17 |
| | | | | Update #2859. | ||||
* | posix: shared memory support | Gedare Bloom | 2017-01-13 | 1 | -0/+78 |
Add POSIX shared memory manager (Shm). Includes a hook-based approach for the backing memory storage that defaults to the Workspace, and a test is provided using the heap. A test is also provided for the basic use of mmap'ing a shared memory object. This test currently fails at the mmap stage due to no support for mmap. |
