* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | posix: Fix shm_unlink() | Sebastian Huber | 2018-12-11 | 1 | -1/+10 |
| | | | | This function is untested. | ||||
* | posix/mman: add mmap support for shm objects | Gedare Bloom | 2017-05-05 | 1 | -2/+2 |
| | | | | Update #2859. | ||||
* | posix: shared memory support | Gedare Bloom | 2017-01-13 | 1 | -2/+28 |
| | | | | | | | | | Add POSIX shared memory manager (Shm). Includes a hook-based approach for the backing memory storage that defaults to the Workspace, and a test is provided using the heap. A test is also provided for the basic use of mmap'ing a shared memory object. This test currently fails at the mmap stage due to no support for mmap. | ||||
* | posix: add stub implementations for mman functions | Gedare Bloom | 2017-01-13 | 1 | -0/+26 |
