path: root/cpukit/posix/src/setitimer.c (follow)
* cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill2013-01-101-1/+1
* posix: Doxygen Enhancement Task #12Ayush Awasthi2012-12-181-0/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/8003214
* 2009-05-15 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-05-151-5/+13
| | | | | * posix/src/getitimer.c, posix/src/setitimer.c: Add error checks and clean up so coverage analysis is possible.
* 2008-11-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-11-201-0/+35
* posix/Makefile.am, posix/include/rtems/posix/psignal.h: Add stubs for gettimer() and setitimer(). * posix/src/getitimer.c, posix/src/setitimer.c: New files.
