path: root/cpukit/posix/src/setcancelstate.c (follow)
* posix: Obtain _Thread_Executing in proper contextSebastian Huber2013-07-221-3/+6
* posix: Create pthread implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of pthread.h and pthread.inl into new header file pthreadimpl.h. The pthread.h contains now only the application visible API.
* cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill2013-01-101-1/+1
* posix: Doxygen enhancement task #4Mathew Kallada2012-12-131-0/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7955219
* 2009-07-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-211-1/+1
| | | | | | | * posix/include/rtems/posix/cancel.h, posix/src/cancel.c, posix/src/canceleval.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c: Fix a minor bug in the previous modification which resulted in psxcancel failing.
* 2009-07-21 Santosh G Vattam <vattam.santosh@gmail.com>Joel Sherrill2009-07-211-12/+7
| | | | | | | | | * posix/Makefile.am, posix/include/rtems/posix/cancel.h, posix/src/cancel.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c: Add _POSIX_Thread_Evaluate_cancellation_and_enable_dispatch method to avoid duplication of code and ease coverage analysis. * posix/src/canceleval.c: New file.
* Convert to "bool".Ralf Corsepius2008-09-041-2/+2
* 2008-05-22 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-05-221-4/+7
| | | | | | | | | | | | | * itron/include/rtems/itron/task.h, itron/src/del_tsk.c, itron/src/exd_tsk.c, itron/src/task.c, posix/include/rtems/posix/threadsup.h, posix/src/cancel.c, posix/src/cancelrun.c, posix/src/pthread.c, posix/src/pthreadexit.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c, posix/src/testcancel.c, rtems/src/taskdelete.c, score/inline/rtems/score/object.inl, score/src/objectclose.c, score/src/threadclose.c: Make all task delete/exit/cancel routines follow the same critical section pattern. Also ensure that POSIX cancelation routines are run at thread exit.
* 2007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-171-0/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h, posix/include/mqueue.h, posix/include/sched.h, posix/include/semaphore.h, posix/include/rtems/posix/cancel.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/priority.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c, posix/src/keycreate.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mqueue.c, posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c, posix/src/mqueueopen.c, posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/ptimer.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c, posix/src/sysconf.c, posix/src/testcancel.c: Add missing copyright statements.
* Remove stray white spaces.Ralf Corsepius2004-04-161-6/+6
* 2002-07-05 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-051-6/+17
| | | | | | | * include/rtems/posix/cancel.h, src/cancel.c, src/cancelrun.c, src/mqueue.c, src/pthread.c, src/semaphore.c, src/setcancelstate.c, src/setcanceltype.c, src/testcancel.c: Per PR164, corrected the behavior of thread cancellation and did some cleanup as a side-effect.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+4
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* Renamed POSIX_Thread_cancel_run to _POSIX_Thread_cancel_run since RTEMSJoel Sherrill1999-11-031-1/+1
| | | | internal symbols are supposed to have leading underscores.
* Split cancel.c into multiple files.Joel Sherrill1999-11-021-0/+46
