* | doxygen: Switch @brief and @ingroup | Sebastian Huber | 2020-04-28 | 1 | -1/+2 |
| | | | | This order change fixes the Latex documentation build via Doxygen. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | score: RTEMS_PREDICT_TRUE(), RTEMS_PREDICT_FALSE() | Sebastian Huber | 2018-07-25 | 1 | -1/+1 |
| | | | | | | | Add RTEMS_PREDICT_TRUE() and RTEMS_PREDICT_FALSE() for static branch prediction hints. Close #3475. | ||||
* | score: Move thread queue timeout handling | Sebastian Huber | 2017-10-24 | 1 | -18/+5 |
| | | | | | Update #3117. Update #3182. | ||||
* | score: Rename function threadq support function | Sebastian Huber | 2017-10-24 | 1 | -1/+1 |
| | | | | | | | | | Rename _Thread_queue_Context_set_do_nothing_enqueue_callout() into _Thread_queue_Context_set_enqueue_do_nothing_extra(). More _Thread_queue_Context_set_enqueue_*() functions will follow. Update #3117. Update #3182. | ||||
* | posix: Implement self-contained POSIX semaphores | Sebastian Huber | 2017-10-05 | 1 | -47/+50 |
| | | | | | | | | | | | | | | For semaphore object pointer and object validation see POSIX_SEMAPHORE_VALIDATE_OBJECT(). Destruction or close of a busy semaphore returns an error status. The object is not flushed. POSIX semaphores are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3116. | ||||
* | posix: cond_timedwait remember and use clock from condattr | Gedare Bloom | 2016-07-25 | 1 | -1/+1 |
| | | | | updates #2745 | ||||
* | score: Rename _POSIX_Absolute_timeout_to_ticks() | Sebastian Huber | 2015-07-28 | 1 | -9/+9 |
| | | | | | | Rename _POSIX_Absolute_timeout_to_ticks() to _TOD_Absolute_timeout_to_ticks() and move it to the score directory. Delete empty <rtems/posix/time.h>. | ||||
* | score: Create object implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | | Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API. | ||||
* | POSIX Semaphore: Add restrict keyword per Single UNIX Specification | Sahil Patnayakunii | 2013-07-24 | 1 | -2/+2 |
* | posix: Create semaphore implementation header | Sebastian Huber | 2013-07-22 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of semaphore.h and semaphore.inl into new header file semaphoreimpl.h. The semaphore.h contains now only the application visible API. | ||||
* | posix: Doxygen Enhancement Task #7 | Mathew Kallada | 2012-12-16 | 1 | -0/+7 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/7958218 | ||||
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | 2010-08-23 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-08-23 | 1 | -9/+5 |
| | | | | | | | | | | | CID 79/DEADCODE CID 78/DEADCODE CID 77/DEADCODE CID 76/DEADCODE * posix/src/condtimedwait.c, posix/src/mutextimedlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/semtimedwait.c: Resolve various dead code issues identified by Coverity scanner. | ||||
* | 2010-06-21 Peter Dufault <dufault@hda.com> | Joel Sherrill | 2010-06-21 | 1 | -2/+2 |
| | | | | | | PR 1570/cpukit * posix/src/semtimedwait.c: This routine is supposed to return -1/errno NOT the status directly. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | 2009-10-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-10-10 | 1 | -10/+6 |
| | | | | | | | | * posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/semtimedwait.c: Switch from switch to if's because only one value needed to be tested. This shrinks the code and makes it easier to do coverage analysis on. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-04 | 1 | -3/+3 |
* | 2008-07-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-07-18 | 1 | -22/+41 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1291/cpukit * itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c, posix/include/mqueue.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/time.h, posix/src/condtimedwait.c, posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c, posix/src/mutextranslatereturncode.c, posix/src/posixtimespecabsolutetimeout.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/semaphoretranslatereturncode.c, posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semwait.c, posix/src/sigtimedwait.c, posix/src/timersettime.c, posix/src/ualarm.c, rtems/src/semobtain.c, rtems/src/semtranslatereturncode.c, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/src/coresemseize.c: This patch addresses issues on implementation of the timeout on the following POSIX services. Some of these services incorrectly took a timeout as a relative time. Others would compute a 0 delta to timeout if the absolute time and the current time were equal and thus incorrectly block the caller forever. The root of the confusion is that POSIX specifies that if the timeout is incorrect (e.g. in the past, is now, or is numerically invalid), that it does not matter if the call would succeed without blocking. This is in contrast to RTEMS programming style where all errors are checked before any critical sections are entered. This fix implemented a more uniform way of handling POSIX absolute time timeouts. + pthread_cond_timedwait - could block forever + mq_timedreceive - used relative not absolute time + mq_timedsend - used relative not absolute time + pthread_mutex_timedlock - used relative not absolute time + pthread_rwlock_timedrdlock- used relative not absolute time + pthread_rwlock_timedwrlock- used relative not absolute time + sem_timedwait - could block forever | ||||
* | 2007-04-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2007-04-05 | 1 | -14/+13 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/Makefile.am, posix/include/rtems/posix/time.h, posix/src/adjtime.c, posix/src/alarm.c, posix/src/clockgetres.c, posix/src/condtimedwait.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mutextimedlock.c, posix/src/nanosleep.c, posix/src/posixtimespecabsolutetimeout.c, posix/src/pthread.c, posix/src/pthreadcreate.c, posix/src/pthreadsetschedparam.c, posix/src/ptimer1.c, posix/src/sched.c, posix/src/semtimedwait.c, posix/src/sigtimedwait.c, posix/src/ualarm.c, rtems/src/clocktodtoseconds.c, score/Makefile.am, score/preinstall.am, score/include/rtems/score/tod.h, score/inline/rtems/score/tod.inl, score/src/coretod.c, score/src/coretodget.c, score/src/coretodgetuptime.c, score/src/coretodset.c, score/src/coretodtickle.c: Provide timespec manipulation routines in the SuperCore. Use them everywhere possible. This lead to significant cleanup in the API routines and eliminated some of the same code from the POSIX API. At this point, the SuperCore keeps time in POSIX timespec format properly from 1970. You just cannot set it before 1988 in keeping with RTEMS traditional behavior. * score/include/rtems/score/timespec.h, score/src/timespecaddto.c, score/src/timespecfromticks.c, score/src/timespecisvalid.c, score/src/timespeclessthan.c, score/src/timespecsubtract.c, score/src/timespectoticks.c: New files. * posix/src/posixintervaltotimespec.c, posix/src/posixtimespecsubtract.c, posix/src/posixtimespectointerval.c: Removed. | ||||
* | 2006-11-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-11-17 | 1 | -6/+6 |
| | | | | | * posix/src/semtimedwait.c: Used wrong constant for blocking with bad timeout value. | ||||
| | | | | | * posix/src/semtimedwait.c: Reverse accidentally included semtimedwait.c. | ||||
| | | | | | | * posix/src/keygetspecific.c, posix/src/keysetspecific.c, posix/src/semtimedwait.c: Correct indexing of key data to use api and index NOT class and index. Class is always 1. | ||||
* | 2006-10-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2006-10-30 | 1 | -23/+26 |
| | | | | | | | | | | | | PR 841/rtems * itron/inline/rtems/itron/semaphore.inl, itron/src/twai_sem.c, posix/include/rtems/posix/semaphore.h, posix/inline/rtems/posix/semaphore.inl, posix/src/semaphorewaitsupp.c, posix/src/semtimedwait.c, posix/src/semwait.c, rtems/src/semobtain.c, rtems/src/semtranslatereturncode.c, score/include/rtems/score/coresem.h, score/src/coresemseize.c: Make sem_timedwait more conformant to Open Group specification. | ||||
* | 2005-09-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2005-09-01 | 1 | -6/+34 |
| | | | | | | | PR 796/rtems * posix/src/semtimedwait.c: sem_timedwait is supposed to use absolute time for timeout specification. This patch is a modified version of the one suggested by Peter Dufault. | ||||
* | 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-01-24 | 1 | -0/+4 |
| | | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support. | ||||
* | 2000-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-08-30 | 1 | -1/+1 |
| | | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs. | ||||
* | Split the POSIX semaphore manager into multiple files. | Joel Sherrill | 1999-11-02 | 1 | -0/+36 |
