path: root/cpukit/posix/src/semopen.c (follow)
* semopen.c: Switch to using RTEMS_COMPILER_UNUSED_ATTRIBUTEJoel Sherrill2013-09-221-11/+8
* semopen.c: Address set but unused variable warningJoel Sherrill2013-09-211-0/+9
* score: Create object implementation headerSebastian Huber2013-07-261-1/+0
| | | | | | Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API.
* posix: Create semaphore implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of semaphore.h and semaphore.inl into new header file semaphoreimpl.h. The semaphore.h contains now only the application visible API.
* cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill2013-01-101-1/+1
* posix: Doxygen Enhancement Task #9Ayush Awasthi2012-12-191-0/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7948216
* 2011-12-13 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-12-131-7/+7
| | | | | | | | | | | | | | | | | | | | | | * posix/src/mqueuenametoid.c, posix/src/semaphorenametoid.c: Removed files. * posix/src/psxnametoid.c: New file. * posix/Makefile.am: Reflect changes above. * posix/include/rtems/posix/config.h: Fixed integer types. * posix/include/rtems/posix/posixapi.h: Declare _POSIX_Name_to_id(). * posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/mqueue.inl: Changed parameter of _POSIX_Message_queue_Create_support(). _POSIX_Message_queue_Name_to_id() is now inline. * posix/include/rtems/posix/semaphore.h, posix/inline/rtems/posix/semaphore.inl: Changed parameter of _POSIX_Semaphore_Create_support(). _POSIX_Semaphore_Name_to_id() is now inline. * posix/src/mqueuecreatesupp.c, posix/src/semaphorecreatesupp.c: Use _Workspace_String_duplicate(). * posix/src/mqueuesendsupp.c, posix/src/mqueueopen.c, posix/src/mqueueunlink.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/semunlink.c: Update due to API changes.
* 2011-12-01 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-011-1/+1
| | | | * posix/src/semopen.c: Use va_arg(..., mode_t) to retrieve mode.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* 2009-05-03 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-05-031-1/+1
| | | | | | * posix/src/condtimedwait.c, posix/src/mutextimedlock.c, posix/src/prwlocktimedrdlock.c, posix/src/prwlocktimedwrlock.c, posix/src/semopen.c: Silence warnings.
* Eliminate TRUE/FALSE.Ralf Corsepius2009-02-031-1/+1
* 2009-01-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-01-051-6/+10
| | | | | | | | | | | | | | | | | | | | | | | * libcsupport/src/gxx_wrappers.c, posix/include/mqueue.h, posix/include/rtems/posix/semaphore.h, posix/inline/rtems/posix/barrier.inl, posix/inline/rtems/posix/key.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/rwlock.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/spinlock.inl, posix/inline/rtems/posix/timer.inl, posix/src/condget.c, posix/src/mqueuenametoid.c, posix/src/mutexget.c, posix/src/semaphorenametoid.c, posix/src/semopen.c, sapi/src/itronapi.c, sapi/src/posixapi.c: Make changes necessary for all tests to run on SPARC with 16-bit Ids. This required ensuring that all POSIX and compilering binding code makes a distinction between the public Id type (e.g. pthread_t, etc.) and the RTEMS Object_Id type. All POSIX Object Get routines should not take the POSIX Id type as the argument. Sixteen bit RTEMS Ids should be placed into the 32-bits reserved by the POSIX API type in a uniform manner now. This removed all assumptions that the external Id types in POSIX and ITRON are the same as the internal Object Id type.
* 2007-12-17 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-12-171-0/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * posix/preinstall.am, posix/include/aio.h, posix/include/devctl.h, posix/include/mqueue.h, posix/include/sched.h, posix/include/semaphore.h, posix/include/rtems/posix/cancel.h, posix/include/rtems/posix/priority.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/threadsup.h, posix/include/rtems/posix/timer.h, posix/inline/rtems/posix/priority.inl, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cancel.c, posix/src/cancelrun.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/key.c, posix/src/keycreate.c, posix/src/keydelete.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mqueue.c, posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenametoid.c, posix/src/mqueuenotify.c, posix/src/mqueueopen.c, posix/src/mqueuereceive.c, posix/src/mqueuerecvsupp.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/ptimer.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/setcancelstate.c, posix/src/setcanceltype.c, posix/src/sysconf.c, posix/src/testcancel.c: Add missing copyright statements.
* 2006-06-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-06-031-3/+6
| | | | | | * itron/src/trcv_mbf.c, posix/src/semopen.c, rtems/src/taskvariableadd.c, score/macros/rtems/score/heap.inl: Fix warnings.
* Remove stray white spaces.Ralf Corsepius2004-04-161-9/+9
* Remove stray white spaces.Ralf Corsepius2004-04-151-2/+0
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * src/clockgetres.c: Apply rtems_set_errno_and_return_minus_one. * src/clockgettime.c: Apply rtems_set_errno_and_return_minus_one. * src/clocksettime.c: Apply rtems_set_errno_and_return_minus_one. * src/killinfo.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueclose.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuegetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuenotify.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueopen.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuerecvsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesendsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueuesetattr.c: Apply rtems_set_errno_and_return_minus_one. * src/mqueueunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/nanosleep.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadkill.c: Apply rtems_set_errno_and_return_minus_one. * src/pthreadsigmask.c: Apply rtems_set_errno_and_return_minus_one. * src/ptimer1.c: Apply rtems_set_errno_and_return_minus_one. * src/sched.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorecreatesupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semaphorewaitsupp.c: Apply rtems_set_errno_and_return_minus_one. * src/semclose.c: Apply rtems_set_errno_and_return_minus_one. * src/semdestroy.c: Apply rtems_set_errno_and_return_minus_one. * src/semgetvalue.c: Apply rtems_set_errno_and_return_minus_one. * src/seminit.c: Apply rtems_set_errno_and_return_minus_one. * src/semopen.c: Apply rtems_set_errno_and_return_minus_one. * src/sempost.c: Apply rtems_set_errno_and_return_minus_one. * src/semunlink.c: Apply rtems_set_errno_and_return_minus_one. * src/setpgid.c: Apply rtems_set_errno_and_return_minus_one. * src/setsid.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaction.c: Apply rtems_set_errno_and_return_minus_one. * src/sigaddset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigdelset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigemptyset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigfillset.c: Apply rtems_set_errno_and_return_minus_one. * src/sigismember.c: Apply rtems_set_errno_and_return_minus_one. * src/sigpending.c: Apply rtems_set_errno_and_return_minus_one. * src/sigtimedwait.c: Apply rtems_set_errno_and_return_minus_one. * src/utsname.c: Apply rtems_set_errno_and_return_minus_one.
* 2001-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-09-281-1/+1
| | | | * src/mqueueopen.c, src/semopen.c: Clarify type on va_arg.
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+4
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* 2001-01-22 Michael Hamel <mhamel@adi.co.nz>Joel Sherrill2001-01-221-1/+1
| | | | | | | | * include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl, src/ptimer1.c, include/rtems/posix/semaphore.h, inline/rtems/posix/semaphore.inl, src/alarm.c, src/ptimer1.c, src/semaphorenametoid.c, src/semopen.c, src/semunlink.c: Modifications to make CodeWarrior happy.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-1/+1
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* + Updated comments.Jennifer Averett1999-11-221-9/+20
| | | | + Corrected enable/disable of dispatch.
* + Debuged to the point that you could open, unlink and close a semaphore.Jennifer Averett1999-11-181-18/+18
| | | | but all paths have not been checked, yet.
* Split the POSIX semaphore manager into multiple files.Joel Sherrill1999-11-021-0/+109
