* | score: Merge tod implementation into one file | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | Delete TOD_MICROSECONDS_PER_SECOND, TOD_MICROSECONDS_TO_TICKS() and TOD_MILLISECONDS_TO_TICKS(). | ||||
* | posix: Create priority implementation header | Sebastian Huber | 2013-07-22 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of priority.h and priority.inl into new header file priorityimpl.h. Remove priority.h since there is no application visible API. | ||||
* | cpukit/posix: Doxygen group is POSIXAPI | Joel Sherrill | 2013-01-10 | 1 | -1/+1 |
* | posix: Doxygen Enhancement Task #8 | Mathew Kallada | 2012-12-15 | 1 | -3/+7 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8003213 | ||||
* | Add __attribute__((unused)) to unused function args. | Ralf Corsepius | 2009-01-02 | 1 | -3/+3 |
* | 2007-12-13 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-13 | 1 | -0/+36 |
* posix/Makefile.am, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/devctl.c, posix/src/execl.c, posix/src/execle.c, posix/src/execlp.c, posix/src/execv.c, posix/src/execve.c, posix/src/execvp.c, posix/src/fork.c, posix/src/mutexinit.c, posix/src/pthreadatfork.c, posix/src/pthreadgetcpuclockid.c, posix/src/pthreadkill.c, posix/src/semaphorecreatesupp.c, posix/src/sysconf.c, posix/src/wait.c, posix/src/waitpid.c: Split files into one function per file. * posix/src/aio_cancel.c, posix/src/aio_error.c, posix/src/aio_fsync.c, posix/src/aio_read.c, posix/src/aio_return.c, posix/src/aio_suspend.c, posix/src/aio_write.c, posix/src/lio_listio.c, posix/src/sched_getparam.c, posix/src/sched_getprioritymax.c, posix/src/sched_getprioritymin.c, posix/src/sched_getscheduler.c, posix/src/sched_rr_get_interval.c, posix/src/sched_setparam.c, posix/src/sched_setscheduler.c, posix/src/sched_yield.c: New files. * posix/src/aio.c, posix/src/sched.c, posix/src/types.c: Removed. |
