path: root/cpukit/posix/src/sched.c (follow)
* 2001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-241-0/+4
| | | | | | | * configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-1/+1
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* Honor 0 as PID of caller.Joel Sherrill1999-07-011-1/+1
* fixed typo .. changed == to !=Joel Sherrill1996-08-271-1/+1
* sched_rr_get_interval: converted assert condition into a standard errorJoel Sherrill1996-08-151-1/+5
| | | | code and added check for a NULL interval being passed in.
* sched_yield: was not invoking the dispatcher.Joel Sherrill1996-08-091-1/+3
* changed code which set errno and then returned -1 to use the macroJoel Sherrill1996-06-071-12/+7
| | | | set_errno_and_return_minus_one.
* Removed assert's from routines which return the error ENOSYS.Joel Sherrill1996-06-061-12/+0
* process oriented scheduler routines now return ENOSYSJoel Sherrill1996-06-061-4/+8
* changed sched_rr_get_interval to use the interval to timespec routine.Joel Sherrill1996-06-041-3/+2
* added interpretation of scheduling policy and parameter information toJoel Sherrill1996-06-041-10/+30
| | | | | | | | pthread_create initial implementation of get/set id routines better argument checking on scheduler functions.
* renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the WatchdogJoel Sherrill1996-05-311-0/+1
| | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency.
* added checks to validate values passed to set attribute routinesJoel Sherrill1996-05-311-1/+17
* comment clean upJoel Sherrill1996-05-291-2/+1
* removed all ifdef's on NOT_IMPLEMENTED.Joel Sherrill1996-05-291-4/+0
* These files have been modified in the initial pass at getting the portionJoel Sherrill1996-05-221-0/+2
| | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have.
* fixed missing CVS IDsJoel Sherrill1995-10-061-0/+1
* posix support initially addedJoel Sherrill1995-09-261-0/+126
