* | 2000-08-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-08-30 | 1 | -1/+1 |
| | | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs. | ||||
* | Honor 0 as PID of caller. | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | fixed typo .. changed == to != | Joel Sherrill | 1996-08-27 | 1 | -1/+1 |
* | sched_rr_get_interval: converted assert condition into a standard error | Joel Sherrill | 1996-08-15 | 1 | -1/+5 |
| | | | | code and added check for a NULL interval being passed in. | ||||
* | sched_yield: was not invoking the dispatcher. | Joel Sherrill | 1996-08-09 | 1 | -1/+3 |
* | changed code which set errno and then returned -1 to use the macro | Joel Sherrill | 1996-06-07 | 1 | -12/+7 |
| | | | | set_errno_and_return_minus_one. | ||||
* | Removed assert's from routines which return the error ENOSYS. | Joel Sherrill | 1996-06-06 | 1 | -12/+0 |
* | process oriented scheduler routines now return ENOSYS | Joel Sherrill | 1996-06-06 | 1 | -4/+8 |
* | changed sched_rr_get_interval to use the interval to timespec routine. | Joel Sherrill | 1996-06-04 | 1 | -3/+2 |
* | added interpretation of scheduling policy and parameter information to | Joel Sherrill | 1996-06-04 | 1 | -10/+30 |
| | | | | | | | | pthread_create initial implementation of get/set id routines better argument checking on scheduler functions. | ||||
* | renamed _TOD_Ticks_since_boot as _Watchdog_Ticks_since_boot so the Watchdog | Joel Sherrill | 1996-05-31 | 1 | -0/+1 |
| | | | | | Handler could timestamp the starting and stopping of timers. Since TOD is built on top of Watchdog, this avoided a circular dependency. | ||||
* | added checks to validate values passed to set attribute routines | Joel Sherrill | 1996-05-31 | 1 | -1/+17 |
* | comment clean up | Joel Sherrill | 1996-05-29 | 1 | -2/+1 |
* | removed all ifdef's on NOT_IMPLEMENTED. | Joel Sherrill | 1996-05-29 | 1 | -4/+0 |
* | These files have been modified in the initial pass at getting the portion | Joel Sherrill | 1996-05-22 | 1 | -0/+2 |
| | | | | | | of the POSIX API necessary to support the GNAT runtime to initially compile. We now have verified that the specifications for the necessary routines are correct per the POSIX standards we have. | ||||
* | fixed missing CVS IDs | Joel Sherrill | 1995-10-06 | 1 | -0/+1 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -0/+126 |
