Use the new Priority_Group_order enum instead of a boolean to indicated if a
priority should be inserted as the first or last node into its priority group.
This makes the code more expressive. It is also a bit more efficient since a
branch in _Scheduler_Node_set_priority() is avoided and a simple bitwise or
operation can be used.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Initialize thread queue context early preferably outside the critical
section.
Remove implicit _Thread_queue_Context_initialize() from
_Thread_Wait_acquire().
Replace Thread_Scheduler_control::control and
Thread_Scheduler_control::own_control with new
Thread_Scheduler_control::home.
Update #2556.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Avoid direct access to thread internal data fields.
Move POSIX API priority validation into _POSIX_Priority_To_core().
Instead of lowering the priority in case the initial budget is consumed
raise the priority for each new period. Restore the normal priority
once the initial budget is consumed. This makes it later easier to
combine the high priority phase with temporary priority boosts (e.g. via
priority ceiling and inheritance).
Use the thread lock to protect the POSIX thread attributes instead of
the thread state lock. This makes it easier to change the thread
priority and keep the POSIX attributes consistent.
Fixes a false positive use of uninitialized variable warning.
This field was redundant.
Close #2734.
