Use a parameter for _Thread_queue_Enqueue() instead to reduce memory
usage.
Move the complete thread queue enqueue procedure into
_Thread_queue_Enqueue_critical(). It is possible to use the thread
queue lock to protect state of the object embedding the thread queue.
This enables per object fine grained locking in the future.
Delete _Thread_queue_Enter_critical_section().
Update #2273.
A thread join is twofold. There is one thread that exists and an
arbitrary number of threads that wait for the thread exit (one-to-many
relation). The exiting thread may want to wait for a thread that wants
to join its exit (STATES_WAITING_FOR_JOIN_AT_EXIT in
_POSIX_Thread_Exit()). On the other side we need a thread queue for all
the threads that wait for the exit of one particular thread
(STATES_WAITING_FOR_JOIN in pthread_join()).
Update #2035.
usage.
The function to change a thread priority was too complex. Simplify it
with a new scheduler operation. This increases the average case
performance due to the simplified logic. The interrupt disabled
critical section is a bit prolonged since now the extract, update and
enqueue steps are executed atomically. This should however not impact
the worst-case interrupt latency since at least for the Deterministic
Priority Scheduler this sequence can be carried out with a wee bit of
instructions and no loops.
Add _Scheduler_Change_priority() to replace the sequence of
- _Thread_Set_transient(),
- _Scheduler_Extract(),
- _Scheduler_Enqueue(), and
- _Scheduler_Enqueue_first().
Delete STATES_TRANSIENT, _States_Is_transient() and
_Thread_Set_transient() since this state is now superfluous.
With this change it is possible to get rid of the
SCHEDULER_SMP_NODE_IN_THE_AIR state. This considerably simplifies the
implementation of the new SMP locking protocols.
Add thread parameter to _Thread_queue_Enqueue_with_handler() to avoid
access to global _Thread_Executing.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
Remove superfluous header file includes from various files.
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
Add and use _Objects_Put_without_thread_dispatch(). These two functions
pair with the _Objects_Get() function. This helps to introduce object
specific SMP locks to avoid lock contention.
http://www.google-melange.com/gci/task/view/google/gci2012/7945218
PR 1855/cpukit
* posix/src/psignal.c, posix/src/pthread.c, posix/src/pthreadjoin.c:
Correct signal processing during pthread_join. We are supposed to
unblock the thread waiting on a pthread_join(), dispatch the signal
handler, account for it potentially overwriting errno, and then have
the thread return to blocking within pthread_join().
PR 1867/cpukit
* posix/src/pthreadexit.c, posix/src/pthreadjoin.c: Correct
implementation of pthread_exit() and pthread_join() to support the
case where a thread is joinable but calls pthread_exit() before a
thread has attempted to join.
* posix/src/pthread.c, posix/src/pthreadjoin.c: Revert accidental
commit.
PR 1856/cpukit
* posix/src/pthread.c, posix/src/pthreadjoin.c,
score/src/rbtreeextract.c: Do not derefence NULL.
PR 1759/cpukit
* posix/src/cancel.c, posix/src/pthreaddetach.c,
posix/src/pthreadequal.c, posix/src/pthreadgetschedparam.c,
posix/src/pthreadjoin.c, posix/src/pthreadkill.c,
posix/src/pthreadsetschedparam.c: Some POSIX pthread services did not
support using Classic API Task Ids.
* posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mqueuetranslatereturncode.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/pbarrierdestroy.c,
posix/src/pbarriertranslatereturncode.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktranslatereturncode.c, posix/src/prwlocktryrdlock.c,
posix/src/prwlocktrywrlock.c, posix/src/prwlockunlock.c,
posix/src/prwlockwrlock.c, posix/src/pspindestroy.c,
posix/src/pspinlock.c, posix/src/pspinlocktranslatereturncode.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/msgqtranslatereturncode.c, rtems/src/semobtain.c,
rtems/src/timerfireafter.c, score/include/rtems/system.h,
score/include/rtems/score/coresem.h: Restructed to move the
OBJECTS_LOCAL case to the top of the switch statement and
eliminate the fall-through return of POSIX_BOTTOM_REACHED. These
changes produced simplier assembly code and allowed for complete
test coverage. Also applied some consistency to the functions
that translate the core status codes to POSIX status codes.
* posix/src/mutextranslatereturncode.c,
posix/src/semaphoretranslatereturncode.c: New files.
* posix/src/mutexfromcorestatus.c: Removed.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskrestart.c, rtems/src/taskresume.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
* src/cancelrun.c, src/pthreadexit.c, src/pthreadjoin.c,
src/sigtimedwait.c: Remove unnecessary typecasts in assignments to
thread->Wait.return_argument.
* include/rtems/posix/cond.h, include/rtems/posix/condmp.h,
include/rtems/posix/config.h, include/rtems/posix/intr.h,
include/rtems/posix/key.h, include/rtems/posix/mqueue.h,
include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h,
include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h,
include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h,
include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h,
include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl,
inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl,
inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl,
inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl,
inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl,
macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl,
macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl,
macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl,
macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c,
src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c,
src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c,
src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c,
src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c,
src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c,
src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c,
src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c,
src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c,
src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c,
src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c,
src/pthreadexit.c, src/pthreadgetcpuclockid.c,
src/pthreadgetcputime.c, src/pthreadgetschedparam.c,
src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c,
src/pthreadself.c, src/pthreadsetcputime.c,
src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c,
src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c,
src/sigfillset.c, src/sigismember.c, src/signal_2.c,
src/sigpending.c, src/sigprocmask.c, src/sigqueue.c,
src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c,
src/sigwaitinfo.c, src/ualarm.c: URL for license changed.
