path: root/cpukit/posix/src/pthreadinitthreads.c (follow)
* doxygen: Switch @brief and @ingroupSebastian Huber2020-04-281-1/+2
| | | | This order change fixes the Latex documentation build via Doxygen.
* config: Remove CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLESebastian Huber2020-02-251-44/+31
| | | | | | | | | | | | | | | | | | | The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_* configuration options. These two options are probably unused, see also: * https://lists.rtems.org/pipermail/users/2019-April/033129.html * https://lists.rtems.org/pipermail/users/2019-April/033130.html Removing them simplifies the configuration. If there is a real user need which shows up after the removal, we can resurrect them on demand. Using CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE would have required the use of the undocumented CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME and CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE configuration options. Update #3874.
* Remove superfluous <rtems/system.h> includesSebastian Huber2019-03-141-1/+0
* posix: Split posix_api_configuration_tableSebastian Huber2018-10-291-2/+2
| | | | | | Use separate configuration variables to avoid false dependencies. Update #2514.
* INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULLSebastian Huber2017-11-221-7/+1
| | | | | | Delete superfluous INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL. Update #3243.
* score: Simplify global constructionSebastian Huber2017-11-221-22/+4
| | | | Update #3243.
* score: Introduce _Internal_error()Sebastian Huber2016-12-121-8/+2
* Add INTERNAL_ERROR_POSIX_INIT_THREAD_CREATE_FAILEDSebastian Huber2016-12-121-2/+6
| | | | Update #2825.
* score: Remove fatal is internal indicatorSebastian Huber2016-12-091-1/+0
| | | | | | | | | The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825.
* posix: Rework thread cancellationSebastian Huber2016-05-201-1/+0
| | | | | | | | Add Thread_Life_state::THREAD_LIFE_CHANGE_DEFERRED and rework the POSIX thread cancellation to use the thread life states. Update #2555. Update #2626.
* Delete unused API extensionsSebastian Huber2016-02-031-1/+0
* score: Introduce Thread_Entry_informationSebastian Huber2016-01-111-2/+5
| | | | | | | This avoids potential dead code in _Thread_Handler(). It gets rid of the dangerous function pointer casts. Update #2514.
* score: Avoid dead code in global constructionSebastian Huber2016-01-081-1/+10
| | | | Update #2514.
* score: Add fatal errors for NULL entry init tasksSebastian Huber2016-01-081-1/+8
| | | | | | This simplifies the global construction. Update #2514.
* score: Rename _POSIX_Absolute_timeout_to_ticks()Sebastian Huber2015-07-281-1/+0
| | | | | | Rename _POSIX_Absolute_timeout_to_ticks() to _TOD_Absolute_timeout_to_ticks() and move it to the score directory. Delete empty <rtems/posix/time.h>.
* score: Rework global constructionSebastian Huber2014-10-131-2/+15
| | | | | | Ensure that the global construction is performed in the context of the first initialization thread. On SMP this was not guaranteed in the previous implementation.
* posix: Update to the pthread_once changes.Chris Johns2013-08-231-8/+11
| | | | | | Implement the reeview changes. Add a POSIX Fatal error domain. Fix confdefs.h to correctly handle the internal POSIX mutexes.
* posix: Create key implementation headerSebastian Huber2013-08-061-1/+0
| | | | | | Move implementation specific parts of key.h and key.inl into new header file keyimpl.h. The key.h contains now only the application visible API.
* posix: Create pthread implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of pthread.h and pthread.inl into new header file pthreadimpl.h. The pthread.h contains now only the application visible API.
* posix: Create priority implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of priority.h and priority.inl into new header file priorityimpl.h. Remove priority.h since there is no application visible API.
* posix: Doxygen Enhancement Task #2Alex Ivanov2012-12-151-11/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7988213
* posix: Add and use <rtems/posix/psignalimpl.h>Sebastian Huber2012-12-051-1/+0
| | | | | This file contains the parts of <rtems/posix/psignal.h> that are only necessary for the POSIX API implementation.
* score: Add and use <rtems/score/userextimpl.h>Sebastian Huber2012-11-221-1/+0
| | | | | This file contains the parts of <rtems/score/userext.h> that are only necessary for the RTEMS implementation.
* 2011-12-05 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-051-1/+1
| | | | * posix/src/pthreadinitthreads.c: Fix typos.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script.
* 2009-06-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-06-291-1/+0
| | | | | | | | * posix/src/killinfo.c, posix/src/mutexinit.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/pthread.c, posix/src/pthreadexit.c, posix/src/pthreadinitthreads.c: Remove includes of <assert.h> where possible. Make other uses conditional on ifdef RTEMS_DEBUG.
* Eliminate TRUE/FALSE.Ralf Corsepius2009-02-031-1/+1
* 2008-12-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-171-4/+5
| | | | | | | | | | | | | | | | | | | | * posix/include/rtems/posix/barrier.h, posix/include/rtems/posix/cond.h, posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h, posix/include/rtems/posix/mutex.h, posix/include/rtems/posix/psignal.h, posix/include/rtems/posix/pthread.h, posix/include/rtems/posix/ptimer.h, posix/include/rtems/posix/rwlock.h, posix/include/rtems/posix/semaphore.h, posix/include/rtems/posix/spinlock.h, posix/include/rtems/posix/timer.h, posix/src/cond.c, posix/src/key.c, posix/src/mqueue.c, posix/src/mutex.c, posix/src/pbarrier.c, posix/src/prwlock.c, posix/src/psignal.c, posix/src/pspin.c, posix/src/pthread.c, posix/src/pthreadinitthreads.c, posix/src/ptimer.c, posix/src/semaphore.c, sapi/src/posixapi.c: Convert POSIX manager initialization routines to directly pull parameters from configuration table.
* 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-01-311-9/+8
| | | | * posix/src/pthreadinitthreads.c: Clean up error paths.
* 2008-01-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-071-1/+1
| | | | | * posix/src/pthreadcreate.c: Add commit. * posix/src/pthreadinitthreads.c: Fix line length.
* 2007-04-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-04-171-0/+88
* itron/Makefile.am, itron/src/eventflags.c, itron/src/fmempool.c, itron/src/itronintr.c, itron/src/itrontime.c, itron/src/network.c, itron/src/port.c, itron/src/sysmgmt.c, itron/src/task.c, itron/src/vmempool.c, posix/Makefile.am, posix/src/pthread.c, rtems/src/taskinitusers.c, rtems/src/tasks.c, sapi/include/confdefs.h, sapi/src/io.c: Various modification to reduce executable size. Most were refactoring of files. Split ITRON API files. Implemented mechanism to avoid initialization task/thread loop being linked in when that style of task initialization was not being used. * itron/src/acp_por.c, itron/src/act_cyc.c, itron/src/cal_por.c, itron/src/chg_iXX.c, itron/src/clr_flg.c, itron/src/cre_flg.c, itron/src/cre_mpf.c, itron/src/cre_mpl.c, itron/src/cre_por.c, itron/src/def_alm.c, itron/src/def_cyc.c, itron/src/def_exc.c, itron/src/def_int.c, itron/src/def_svc.c, itron/src/del_flg.c, itron/src/del_mpf.c, itron/src/del_mpl.c, itron/src/del_por.c, itron/src/dis_int.c, itron/src/dly_tsk.c, itron/src/ena_int.c, itron/src/fwd_por.c, itron/src/get_blf.c, itron/src/get_blk.c, itron/src/get_tim.c, itron/src/get_ver.c, itron/src/itroninittasks.c, itron/src/loc_cpu.c, itron/src/nget_nod.c, itron/src/nget_ver.c, itron/src/nrea_dat.c, itron/src/nwri_dat.c, itron/src/pacp_por.c, itron/src/pcal_por.c, itron/src/pget_blf.c, itron/src/pget_blk.c, itron/src/pol_flg.c, itron/src/ref_alm.c, itron/src/ref_cfg.c, itron/src/ref_cyc.c, itron/src/ref_flg.c, itron/src/ref_iXX.c, itron/src/ref_mpf.c, itron/src/ref_mpl.c, itron/src/ref_por.c, itron/src/ref_sys.c, itron/src/rel_blf.c, itron/src/rel_blk.c, itron/src/ret_int.c, itron/src/ret_tmr.c, itron/src/ret_wup.c, itron/src/rpl_rdv.c, itron/src/set_flg.c, itron/src/set_tim.c, itron/src/tacp_por.c, itron/src/tcal_por.c, itron/src/tget_blf.c, itron/src/tget_blk.c, itron/src/twai_flg.c, itron/src/unl_cpu.c, itron/src/wai_flg.c, posix/src/pthreadinitthreads.c: New files.
