* itron/include/rtems/itron/task.h, itron/src/del_tsk.c,
itron/src/exd_tsk.c, itron/src/task.c,
posix/include/rtems/posix/threadsup.h, posix/src/cancel.c,
posix/src/cancelrun.c, posix/src/pthread.c, posix/src/pthreadexit.c,
posix/src/setcancelstate.c, posix/src/setcanceltype.c,
posix/src/testcancel.c, rtems/src/taskdelete.c,
score/inline/rtems/score/object.inl, score/src/objectclose.c,
score/src/threadclose.c: Make all task delete/exit/cancel routines
follow the same critical section pattern. Also ensure that POSIX
cancelation routines are run at thread exit.
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/objectgetnameasstring.c,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectgetclassinfo.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New files.
* rtems/src/rtemsidtoname.c: Removed.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/prwlockinit.c, posix/src/pspininit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectextendinformation.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
* src/cancelrun.c, src/pthreadexit.c, src/pthreadjoin.c,
src/sigtimedwait.c: Remove unnecessary typecasts in assignments to
thread->Wait.return_argument.
* include/rtems/posix/cond.h, include/rtems/posix/condmp.h,
include/rtems/posix/config.h, include/rtems/posix/intr.h,
include/rtems/posix/key.h, include/rtems/posix/mqueue.h,
include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h,
include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h,
include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h,
include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h,
include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl,
inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl,
inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl,
inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl,
inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl,
macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl,
macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl,
macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl,
macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c,
src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c,
src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c,
src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c,
src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c,
src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c,
src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c,
src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c,
src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c,
src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c,
src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c,
src/pthreadexit.c, src/pthreadgetcpuclockid.c,
src/pthreadgetcputime.c, src/pthreadgetschedparam.c,
src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c,
src/pthreadself.c, src/pthreadsetcputime.c,
src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c,
src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c,
src/sigfillset.c, src/sigismember.c, src/signal_2.c,
src/sigpending.c, src/sigprocmask.c, src/sigqueue.c,
src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c,
src/sigwaitinfo.c, src/ualarm.c: URL for license changed.
should NEVER occur.
