The thread POSIX API control must be fully initialized in
_POSIX_Threads_Create_extension(), otherwise a pthread_setschedparam()
is broken for all threads not created with pthread_create().
Update #2514.
Update #2514.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
Replace Thread_Scheduler_control::control and
Thread_Scheduler_control::own_control with new
Thread_Scheduler_control::home.
Update #2556.
* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Do not access data of the executing thread without proper locks.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
Move POSIX API priority validation into _POSIX_Priority_To_core().
Instead of lowering the priority in case the initial budget is consumed
raise the priority for each new period. Restore the normal priority
once the initial budget is consumed. This makes it later easier to
combine the high priority phase with temporary priority boosts (e.g. via
priority ceiling and inheritance).
Use the thread lock to protect the POSIX thread attributes instead of
the thread state lock. This makes it easier to change the thread
priority and keep the POSIX attributes consistent.
Fixes a false positive use of uninitialized variable warning.
This field was redundant.
Update #2738.
Add Thread_Life_state::THREAD_LIFE_CHANGE_DEFERRED and rework the POSIX
thread cancellation to use the thread life states.
Update #2555.
Update #2626.
Update #2555.
Rework pthread_join() to use _Thread_Join().
Close #2402.
Update #2555.
Update #2626.
Close #2714.
Update #2555.
Update #2555.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
Rename _POSIX_Absolute_timeout_to_ticks() to
_TOD_Absolute_timeout_to_ticks() and move it to the score directory.
Delete empty <rtems/posix/time.h>.
Store the floating-point unit property in the thread control block
regardless of the CPU_HARDWARE_FP and CPU_SOFTWARE_FP settings. Make
sure the floating-point unit is only enabled for the corresponding
multilibs. This helps targets which have a volatile only floating point
context like SPARC for example.
Clustered/partitioned scheduling helps to control the worst-case
latencies in the system. The goal is to reduce the amount of shared
state in the system and thus prevention of lock contention. Modern
multi-processor systems tend to have several layers of data and
instruction caches. With clustered/partitioned scheduling it is
possible to honour the cache topology of a system and thus avoid
expensive cache synchronization traffic.
We have clustered scheduling in case the set of processors of a system
is partitioned into non-empty pairwise-disjoint subsets. These subsets
are called clusters. Clusters with a cardinality of one are partitions.
Each cluster is owned by exactly one scheduler instance.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Use allocator mutex for objects allocate/free. This prevents that the
thread dispatch latency depends on the workspace/heap fragmentation.
With the addition of pthread affinity information in pthread_attr_t,
the existing code for pthread_attr_t had to be adjusted.
Reproducable crashes occur when using pthreads and the capture engine
at the same time. 'pthread_create()' is the culprit. It creates a SCORE thread
and then calls Thread_Start( ) without disabling thread-dispatching.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Move implementation specific parts of stack.h and stack.inl into new
header file stackimpl.h. The stack.h contains now only the application
visible API.
Move implementation specific parts of watchdog.h and watchdog.inl into
new header file watchdogimpl.h. The watchdog.h contains now only the
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
Add and use _Scheduler_Start_idle().
http://www.google-melange.com/gci/task/view/google/gci2012/7948216
PR 1573/cpukit
* configure.ac, posix/src/killinfo.c,
posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadkill.c, posix/src/pthreadsigmask.c,
rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/context.h, score/include/rtems/score/isr.h,
score/include/rtems/score/thread.h, score/src/isr.c,
score/src/isrthreaddispatch.c, score/src/thread.c,
score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu
data structure which contains the information required by RTEMS for
each CPU core. This encapsulates information such as thread
executing, heir, idle and dispatch needed.
* score/include/rtems/score/percpu.h, score/src/percpu.c: New files.
* posix/Makefile.am, posix/include/rtems/posix/priority.h,
posix/inline/rtems/posix/priority.inl, posix/src/killinfo.c,
posix/src/pthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadsetschedparam.c: Various modifications to improve
binary code coverage analysis. Some of these are to mark code as
debug only. Some are to break conditional expressions into multiple
lines. Some are to move inline methods that are not time critical
into subroutines to make them easier to test. Inlining them multiple
times means that their logic paths are spread across multiple
methods. This explodes the test cases required.
* posix/src/psxpriorityisvalid.c, posix/src/psxtransschedparam.c: New files.
