path: root/cpukit/posix/src/pthreadattrsetstack.c (follow)
* score: Create stack implementation headerSebastian Huber2013-07-231-3/+4
| | | | | | Move implementation specific parts of stack.h and stack.inl into new header file stackimpl.h. The stack.h contains now only the application visible API.
* posix: Create pthread implementation headerSebastian Huber2013-07-221-1/+1
| | | | | | Move implementation specific parts of pthread.h and pthread.inl into new header file pthreadimpl.h. The pthread.h contains now only the application visible API.
* cpukit/posix: Doxygen group is POSIXAPIJoel Sherrill2013-01-101-1/+1
* posix: Doxygen Enhancement Task #10Alex Ivanov2012-12-191-0/+7
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7997223
* 2010-10-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-041-0/+42
* Makefile.am, configure.ac, posix/Makefile.am, posix/src/pthread.c: * posix/src/pthreadattrgetguardsize.c, posix/src/pthreadattrgetstack.c, posix/src/pthreadattrsetguardsize.c, posix/src/pthreadattrsetstack.c: New files.
