path: root/cpukit/posix/src/pthreadattrgetinheritsched.c (unfollow)
2004-04-15Remove stray white spaces.Ralf Corsepius1-1/+0
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* include/rtems/posix/cond.h, include/rtems/posix/condmp.h, include/rtems/posix/config.h, include/rtems/posix/intr.h, include/rtems/posix/key.h, include/rtems/posix/mqueue.h, include/rtems/posix/mqueuemp.h, include/rtems/posix/mutex.h, include/rtems/posix/mutexmp.h, include/rtems/posix/posixapi.h, include/rtems/posix/pthread.h, include/rtems/posix/pthreadmp.h, include/rtems/posix/ptimer.h, include/rtems/posix/semaphore.h, include/rtems/posix/semaphoremp.h, inline/rtems/posix/cond.inl, inline/rtems/posix/intr.inl, inline/rtems/posix/key.inl, inline/rtems/posix/mqueue.inl, inline/rtems/posix/mutex.inl, inline/rtems/posix/pthread.inl, inline/rtems/posix/semaphore.inl, inline/rtems/posix/timer.inl, macros/rtems/posix/cond.inl, macros/rtems/posix/intr.inl, macros/rtems/posix/key.inl, macros/rtems/posix/mqueue.inl, macros/rtems/posix/mutex.inl, macros/rtems/posix/pthread.inl, macros/rtems/posix/semaphore.inl, macros/rtems/posix/timer.inl, src/alarm.c, src/kill.c, src/killinfo.c, src/mqueuetranslatereturncode.c, src/pause.c, src/pthreadattrdestroy.c, src/pthreadattrgetdetachstate.c, src/pthreadattrgetinheritsched.c, src/pthreadattrgetschedparam.c, src/pthreadattrgetschedpolicy.c, src/pthreadattrgetscope.c, src/pthreadattrgetstackaddr.c, src/pthreadattrgetstacksize.c, src/pthreadattrinit.c, src/pthreadattrsetdetachstate.c, src/pthreadattrsetinheritsched.c, src/pthreadattrsetschedparam.c, src/pthreadattrsetschedpolicy.c, src/pthreadattrsetscope.c, src/pthreadattrsetstackaddr.c, src/pthreadattrsetstacksize.c, src/pthreadcreate.c, src/pthreaddetach.c, src/pthreadequal.c, src/pthreadexit.c, src/pthreadgetcpuclockid.c, src/pthreadgetcputime.c, src/pthreadgetschedparam.c, src/pthreadjoin.c, src/pthreadkill.c, src/pthreadonce.c, src/pthreadself.c, src/pthreadsetcputime.c, src/pthreadsetschedparam.c, src/pthreadsigmask.c, src/sigaction.c, src/sigaddset.c, src/sigdelset.c, src/sigemptyset.c, src/sigfillset.c, src/sigismember.c, src/signal_2.c, src/sigpending.c, src/sigprocmask.c, src/sigqueue.c, src/sigsuspend.c, src/sigtimedwait.c, src/sigwait.c, src/sigwaitinfo.c, src/ualarm.c: URL for license changed.
2001-01-242001-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+3
* configure.in: Add src/config.h * src/Makefile.am: Add INCLUDES += -I. to pickup config.h * src/.cvsignore: Add config.h and stamp-h * src/*.c: Add config.h support.
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1999-01-25Split most of POSIX Threads Manager into multiple files.Joel Sherrill1-13/+10
1998-11-23Added base version of file system infrastructure. This includes a majorJoel Sherrill1-7/+14
1998-05-22Added tcdrain(), cfgetospeed(0, cfsetospeed(), cfgetispeed(), andJoel Sherrill1-0/+26
cfsetispeed().
