Move the writes to Thread_Control::current_priority and
Thread_Control::real_priority into _Thread_Change_priority() under the
protection of the thread lock. Add a filter function to
_Thread_Change_priority() to enable specialized variants.
Avoid race conditions during a thread priority restore with the new
Thread_Control::priority_restore_hint for an important average case
optimizations used by priority inheritance mutexes.
Update #2273.
Use a parameter for _Thread_queue_Enqueue() instead to reduce memory
usage.
Move the complete thread queue enqueue procedure into
_Thread_queue_Enqueue_critical(). It is possible to use the thread
queue lock to protect state of the object embedding the thread queue.
This enables per object fine grained locking in the future.
Delete _Thread_queue_Enter_critical_section().
Update #2273.
Add watchdog header parameter to _Watchdog_Remove() to be in line with
the other operations. Add _Watchdog_Remove_ticks() and
_Watchdog_Remove_seconds() for convenience.
Update #2307.
usage.
The thread control block contains fields that point to application
configuration dependent memory areas, like the scheduler information,
the API control blocks, the user extension context table, the RTEMS
notepads and the Newlib re-entrancy support. Account for these areas in
the configuration and avoid extra workspace allocations for these areas.
This helps also to avoid heap fragementation and reduces the per thread
memory due to a reduced heap allocation overhead.
It is no longer necessary to protect the workspace allocations with the
Giant lock due to the thread life cycle re-implementation.
The thread deletion is now supported on SMP.
This change fixes the following PRs:
PR1814: SMP race condition between stack free and dispatch
PR2035: psxcancel reveals NULL pointer access in _Thread_queue_Extract()
The POSIX cleanup handler are now called in the right context (should be
called in the context of the terminating thread).
http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_09.html
Add a user extension the reflects a thread termination event. This is
used to reclaim the Newlib reentrancy structure (may use file
operations), the POSIX cleanup handlers and the POSIX key destructors.
Run the thread restart extensions in the context of the restarted
thread. Run them with thread dispatching enabled.
Formerly POSIX keys were only enabled when POSIX threads
were enabled. Because they are a truly safe alternative
to per-task variables in an SMP system, they are being
enabled in all configurations.
With the addition of pthread affinity information in pthread_attr_t,
the existing code for pthread_attr_t had to be adjusted.
Provide support for latest Newlib <pthread.h> change. The cleanup
contexts are stored on the thread stack. This is conformant with the
POSIX requirements for the pthread_cleanup_push() and
pthread_cleanup_pop() statement pair.
Passing an invalid pointer as the routine to pthread_cleanup_push() is
now a usage error and the behaviour is undefined.
Move implementation specific parts of key.h and key.inl into new header
file keyimpl.h. The key.h contains now only the application visible
API.
This patch enables unlimited model in POSIX key manger and have a decent
runtime on POSIX key searching, adding and deleting operations. Memory
overhead is lower than current implementation when the size of key and key
value becomes big.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
Remove superfluous header file includes from various files.
Move implementation specific parts of watchdog.h and watchdog.inl into
new header file watchdogimpl.h. The watchdog.h contains now only the
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
http://www.google-melange.com/gci/task/view/google/gci2012/8003213
This file contains the parts of <rtems/posix/psignal.h> that are only
necessary for the POSIX API implementation.
Move post switch hook from API_extensions_Control to new
API_extensions_Post_switch_control. Rename
_API_extensions_Run_postswitch() in _API_extensions_Run_post_switch().
Add _API_extensions_Post_switch_list and
_API_extensions_Add_post_switch().
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
* posix/src/pthread.c: Fix typos.
* posix/src/pthread.c (_POSIX_Threads_Default_attributes): Add
missing initializer.
* posix/src/pthread.c: Make
_POSIX_Threads_Create_extension,_POSIX_Threads_Delete_extension,
_POSIX_Threads_Exitted_extension,
_POSIX_Threads_Initialize_user_threads static.
PR 1855/cpukit
* posix/src/psignal.c, posix/src/pthread.c, posix/src/pthreadjoin.c:
Correct signal processing during pthread_join. We are supposed to
unblock the thread waiting on a pthread_join(), dispatch the signal
handler, account for it potentially overwriting errno, and then have
the thread return to blocking within pthread_join().
* posix/src/pthread.c, posix/src/pthreadjoin.c: Revert accidental
commit.
PR 1856/cpukit
* posix/src/pthread.c, posix/src/pthreadjoin.c,
score/src/rbtreeextract.c: Do not derefence NULL.
* libmisc/capture/capture.c, posix/src/keyfreememory.c,
posix/src/pthread.c, score/include/rtems/score/wkspace.h,
score/src/objectextendinformation.c,
score/src/objectnamespaceremove.c, score/src/objectsetname.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/wkspace.c: Many places were checking for a NULL pointer
before calling _Workspace_Free. By moving the check into
_Workspace_Free, we eliminate a number of conditional paths and make
it harder to return a NULL pointer.
* Makefile.am, configure.ac, posix/Makefile.am, posix/src/pthread.c:
* posix/src/pthreadattrgetguardsize.c, posix/src/pthreadattrgetstack.c,
posix/src/pthreadattrsetguardsize.c, posix/src/pthreadattrsetstack.c:
New files.
* posix/src/pthread.c: Make default pthread_attr_t match the
conditionals in the version in newlib. This way it will always be
right.
* libmisc/capture/capture.c, posix/src/pthread.c, rtems/src/tasks.c,
score/include/rtems/score/userext.h: Eliminate use of deprecated
rtems_extension. Re-add prototype for _User_extensions_Add_API_set.
* posix/src/pthread.c: Address sporadic server edge cases. Do not
change priority if thread is holding a priority ceiling or
inheritance mutex. Do not change it if it looks like the thread has
manually changed its priority. Style cleanup on file with new
comments added.
* posix/src/psxtransschedparam.c, posix/src/pthread.c: Add error checks
for 0 time on sporadic scheduler replenish period and initial budget.
This avoids having to correct for it in the TSR, so we can eliminate
the check for ticks == 0 there.
* itron/src/task.c, posix/src/pthread.c, rtems/src/tasks.c,
sapi/src/exinit.c, score/include/rtems/score/apiext.h,
score/src/apiext.c: No APIs currently implemented use the
predriver_hook so disable it until such time as it is used.
* posix/src/killinfo.c, posix/src/mutexinit.c, posix/src/psignal.c,
posix/src/psignalchecksignal.c, posix/src/pthread.c,
posix/src/pthreadexit.c, posix/src/pthreadinitthreads.c: Remove
includes of <assert.h> where possible. Make other uses conditional on
ifdef RTEMS_DEBUG.
* posix/Makefile.am, posix/include/rtems/posix/priority.h,
posix/inline/rtems/posix/priority.inl, posix/src/killinfo.c,
posix/src/pthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadsetschedparam.c: Various modifications to improve
binary code coverage analysis. Some of these are to mark code as
debug only. Some are to break conditional expressions into multiple
lines. Some are to move inline methods that are not time critical
into subroutines to make them easier to test. Inlining them multiple
times means that their logic paths are spread across multiple
methods. This explodes the test cases required.
* posix/src/psxpriorityisvalid.c, posix/src/psxtransschedparam.c: New files.
