Update #3342.
Update #3343.
Use the thread CPU budget algorithm to determine the scheduler policy.
This fixes also pthread_getschedparam() for Classic tasks.
Update #2514.
Instead of lowering the priority in case the initial budget is consumed
raise the priority for each new period. Restore the normal priority
once the initial budget is consumed. This makes it later easier to
combine the high priority phase with temporary priority boosts (e.g. via
priority ceiling and inheritance).
Use the thread lock to protect the POSIX thread attributes instead of
the thread state lock. This makes it easier to change the thread
priority and keep the POSIX attributes consistent.
Fixes a false positive use of uninitialized variable warning.
Rename _POSIX_Absolute_timeout_to_ticks() to
_TOD_Absolute_timeout_to_ticks() and move it to the score directory.
Delete empty <rtems/posix/time.h>.
Move implementation specific parts of pthread.h and pthread.inl into new
header file pthreadimpl.h. The pthread.h contains now only the
application visible API.
Move implementation specific parts of priority.h and priority.inl into
new header file priorityimpl.h. Remove priority.h since there is no
http://www.google-melange.com/gci/task/view/google/gci2012/7958218
* posix/src/psxtransschedparam.c, posix/src/pthread.c: Add error checks
for 0 time on sporadic scheduler replenish period and initial budget.
This avoids having to correct for it in the TSR, so we can eliminate
the check for ticks == 0 there.
* posix/src/psxtransschedparam.c: Restructure to avoid untestable code
being generated by switch.
* posix/Makefile.am, posix/include/rtems/posix/priority.h,
posix/inline/rtems/posix/priority.inl, posix/src/killinfo.c,
posix/src/pthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadsetschedparam.c: Various modifications to improve
binary code coverage analysis. Some of these are to mark code as
debug only. Some are to break conditional expressions into multiple
lines. Some are to move inline methods that are not time critical
into subroutines to make them easier to test. Inlining them multiple
times means that their logic paths are spread across multiple
methods. This explodes the test cases required.
* posix/src/psxpriorityisvalid.c, posix/src/psxtransschedparam.c: New files.
